Solve Linear System of ODEs: x',y' w/ Initial Conditions x(0),y(0)
In summary, a linear system of ODEs is a set of differential equations that can be written in the form of Ax' + By' = Cx + Dy, where x and y are functions of a single variable, and A, B, C, and D are constants. To solve a linear system of ODEs, various methods such as substitution, elimination, or matrix methods can be used depending on the complexity of the system. Initial conditions, which refer to the values of the dependent variables at a specific point, are important in finding a unique solution for the system. Linear systems of ODEs can have multiple solutions, but each solution must satisfy the given initial conditions. They have real-world applications in fields such as physics
Euge
MHB
POTW Director
2,052
207
Solve the linear system of ODE ##x' = 2x + 3y##, ##y' = -3x + y## with initial conditions ##x(0) = 1, y(0) = 2##.
Likes benorin
The differential equation
\begin{align*}
\frac{d}{dt} \binom{x}{y} =
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\binom{x}{y}
\end{align*}
with initial conditions ##x(0)=1##, ##y(0) = 2## has the solution:
\begin{align*}
\binom{x}{y} = \exp \left\{
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix} t \right\}
\binom{1}{2}
\end{align*}
When the eigenvalues are complex and distinct such that ##\lambda_1 = \overline{\lambda_2} = a+ib## we have that
\begin{align*}
e^{At} = e^{at} \cos (bt) \mathbb{1} + \dfrac{e^{at} \sin (bt)}{b} (A - a \mathbb{1}) \qquad (*) .
\end{align*}
We will prove this formula is correct by showing that ##\frac{d}{dt} (RHS) = A (RHS)## and by noting that the ##RHS = \mathbb{1}## at ##t = 0##. By the Cayley-Hamilton theorem we have ##A^2 = 2a A - (a^2+b^2) \mathbb{1}##. We use this in the form ##A (A - a \mathbb{1}) = aA - (a^2 + b^2) \mathbb{1}## in the proof of ##\frac{d}{dt} (RHS) = A (RHS)##,
\begin{align*}
& \frac{d}{dt} \left[ e^{at} \cos (bt) \mathbb{1} + \dfrac{e^{at} \sin (bt)}{b} (A - a \mathbb{1}) \right]
\nonumber \\
& = a e^{at} \cos (bt) \mathbb{1} - b e^{at} \sin (bt) \mathbb{1} + \dfrac{a e^{at} \sin (bt)}{b} (A - a \mathbb{1}) + e^{at} \cos (bt) (A - a \mathbb{1})
\nonumber \\
& = A e^{at} \cos (bt) \mathbb{1} + \dfrac{e^{at} \sin (bt)}{b} (aA - (a^2 + b^2) \mathbb{1})
\nonumber \\
& = A \left[ e^{at} \cos (bt) \mathbb{1} + \dfrac{e^{at} \sin (bt)}{b} (A - a \mathbb{1}) \right] .
\end{align*}
The eigenvalues are determined by
\begin{align*}
\det
\begin{pmatrix}
2 - \lambda & 3 \\
-3 & 1 - \lambda
\end{pmatrix}
= 0
\end{align*}
or
\begin{align*}
\lambda^2 - 3 \lambda + 11 = 0
\end{align*}
so that
\begin{align*}
\lambda_1 = \frac{3}{2} + \frac{\sqrt{35}}{2} i , \quad \lambda_2 = \frac{3}{2} - \frac{\sqrt{35}}{2} i .
\end{align*}
So that by ##(*)## we have
\begin{align*}
e^{At} & = e^{3 t/2} \cos (\frac{ \sqrt{35} }{2} t)
\begin{pmatrix}
1 & 0 \\
0 & 1
\end{pmatrix}
+ e^{3 t/2} \dfrac{\sin (\frac{ \sqrt{35} }{2} t)}{\sqrt{35}}
\begin{pmatrix}
1 & 6 \\
-6 & -1
\end{pmatrix}
\end{align*}
So
\begin{align*}
\binom{x}{y} = e^{2 t/3} \cos (\frac{ \sqrt{35} }{2}t) \binom{1}{2}
+ e^{2 t/3} \dfrac{\sin (\frac{ \sqrt{35} }{2}t)}{\sqrt{35}} \binom{13}{-8}
\end{align*}
Likes Office_Shredder
In the previous post I wrote down slightly the wrong matrix. I've now written down the correct matrix and recalculated the eigenvalues.
By the way, there are other methods of solving the problem!
The system is equivalent to two second order ODE's
$$ y'' - 3y'+11y , y(0)=2$$
$$ x''-3x'+11x=0, x(0)=1 $$
Algebraic error fixed ( hopefully)...
Likes julian
When working with these types of problems is it implied that x = x(t) and y = y(t).
Yes, they are functions of ##t##.
Because you have a second order differential equation the general solution will involve two unknown constants, so you need ##x(0)## and ##x'(0)##. Now, ##x'(0)## was not specified in the question but that does not present a problem because you are given a formula for ##x'(t)##. Yep?
Do you know how to go about solving your differential equation? It is a homogeneous linear differential equation of second order with constant coefficients.
Using the original equations and given initial conditions we find ## x'(0) = 8, y'(0) = -1##
With an old textbook in front of me... Find the auxiliary equation:
$$m^2 -3m+11 = 0 \implies m = \frac{3}{2} \pm \frac{\sqrt{35}i}{2} $$
I think that implies the general solution ( for ##y## or ##x## - same ODE - different i.c. ):
$$ x(t) = y(t) = e^{ \left( \frac{3}{2}t \right) } \left( c_1 \cos \left( \frac{ \sqrt{35} }{2} t \right) + c_2 \sin \left( \frac{ \sqrt{35} }{2} t \right) \right) $$
Likes julian
There are a couple of other methods of solving the problem.
Start with the "exponential ansatz":
\begin{align*}
\binom{x(t)}{y(t)} = \binom{C}{D} e^{\lambda t} .
\end{align*}
Substituting this into
\begin{align*}
\binom{x'}{y'} =
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\binom{x}{y}
\end{align*}
we arrive at the eigenvector problem
\begin{align*}
\lambda \binom{C}{D} =
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\binom{C}{D}
\end{align*}
Let's find the eigenvalues:
\begin{align*}
\det
\begin{pmatrix}
2 - \lambda & 3 \\
-3 & 1 - \lambda
\end{pmatrix}
= 0
\end{align*}
or
\begin{align*}
\end{align*}
so that
\begin{align*}
\lambda_1 = \frac{3}{2} + i \frac{\sqrt{35}}{2} , \qquad \lambda_2 = \frac{3}{2} - i \frac{\sqrt{35}}{2}
\end{align*}
As the eigenvalues are the complex conjugate of each other one of the eigenvectors will be proportional to the complex conjugate of the other. The eigenvector equation is
\begin{align*}
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\binom{C}{D} =
(\frac{3}{2} + i \frac{\sqrt{35}}{2}) \binom{C}{D}
\end{align*}
or
\begin{align*}
\begin{pmatrix}
4 & 6 \\
-6 & 2
\end{pmatrix}
\binom{C}{D} =
(3 + i \sqrt{35}) \binom{C}{D}
\end{align*}
or
\begin{align*}
\begin{pmatrix}
1 - i \sqrt{35} & 6 \\
-6 & -1 - i \sqrt{35}
\end{pmatrix}
\binom{C}{D} = 0
\end{align*}
or
\begin{align*}
(1 - i \sqrt{35}) C + 6 D = 0
\nonumber \\
-6 C - (1 + i \sqrt{35}) D = 0
\end{align*}
Using the first condition, the two eigenvectors are
\begin{align*}
\vec{v}_1 = \binom{1}{\dfrac{-1 + i \sqrt{35}}{6}} , \qquad (\lambda_1 = \frac{3}{2} + i \frac{\sqrt{35}}{2})
\nonumber \\
\vec{v}_2 = \binom{1}{\dfrac{-1 - i \sqrt{35}}{6}} , \qquad (\lambda_2 = \frac{3}{2} - i \frac{\sqrt{35}}{2})
\end{align*}
The (real) general solution of the homogeneous differential equation is
\begin{align*}
\binom{x}{y} = C \binom{1}{\dfrac{- 1 + i \sqrt{35}}{6}} e^{(\frac{3}{2} + i \frac{\sqrt{35}}{2}) t} + C^* \binom{1}{\dfrac{-1 - i \sqrt{35}}{6}} e^{(\frac{3}{2} - i \frac{\sqrt{35}}{2}) t}
\end{align*}
Writing ##C = C_1 + i C_2##, we have
\begin{align*}
\binom{x}{y} = (C_1 + i C_2) \binom{1}{\dfrac{-1 + i \sqrt{35}}{6}} e^{(\frac{3}{2} + i \frac{\sqrt{35}}{2}) t} + c.c.
\end{align*}
so that
\begin{align*}
\binom{x}{y} = (C_1 + i C_2) \binom{1}{\dfrac{-1 + i \sqrt{35}}{6}} (\cos (\frac{\sqrt{35}}{2} t) + i \sin (\frac{\sqrt{35}}{2} t)) e^{3t/2} + c.c.
\end{align*}
or
\begin{align*}
\binom{x}{y} = \binom{C_1 + i C_2}{\dfrac{(-C_1 - C_2 \sqrt{35}) + i (-C_2 + C_1 \sqrt{35})}{6} } (\cos (\frac{\sqrt{35}}{2} t) + i \sin (\frac{\sqrt{35}}{2} t)) e^{3t/2} + c.c.
\end{align*}
or
\begin{align*}
\binom{x}{y} = 2 \binom{C_1 \cos (\frac{\sqrt{35}}{2} t) - C_2 \sin (\frac{\sqrt{35}}{2} t)}
{\dfrac{-C_1 - C_2 \sqrt{35}}{6} \cos (\frac{\sqrt{35}}{2} t) - \dfrac{-C_2 + C_1 \sqrt{35}}{6} \sin (\frac{\sqrt{35}}{2} t)} e^{3t/2}
\end{align*}
Using ##x(0)=1## and ##y(0)=2##,
\begin{align*}
\binom{1}{2} = 2 \binom{ C_1 }{ - \dfrac{ C_1 + C_2 \sqrt{35} }{6} }
\end{align*}
So ##C_1 = \frac{1}{2}##, ##1 = - \dfrac{ C_1 + C_2 \sqrt{35} }{6}##, ##C_2 = - \dfrac{13}{2 \sqrt{35}}##, and ##\dfrac{4}{\sqrt{35}} = \dfrac{ -C_2 + C_1 \sqrt{35} }{6}##.
So finally we have,
\begin{align*}
+ e^{2 t/3} \dfrac{\sin (\frac{ \sqrt{35} }{2}t)}{\sqrt{35}} \binom{13}{-8} .
\end{align*}
\begin{align*}
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\binom{x}{y}
\end{align*}
\begin{align*}
\begin{pmatrix}
2 & 3 \\
-3 & 1
\binom{1}{2}
\end{align*}
Write
\begin{align*}
A =
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\end{align*}
We will compute ##\exp (At)##.
To that end, consider the eigenvector problem
\begin{align*}
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\binom{C}{D}
= \lambda \binom{C}{D}
\end{align*}
\begin{align*}
\det
\begin{pmatrix}
2 - \lambda & 3 \\
-3 & 1 - \lambda
\end{pmatrix}
= 0
\end{align*}
or
\begin{align*}
\end{align*}
so that
\begin{align*}
\end{align*}
\begin{align*}
\begin{pmatrix}
2 & 3 \\
-3 & 1
\end{pmatrix}
\binom{C}{D} =
\end{align*}
or
\begin{align*}
\begin{pmatrix}
4 & 6 \\
-6 & 2
\end{pmatrix}
\binom{C}{D} =
\end{align*}
or
\begin{align*}
\begin{pmatrix}
\end{pmatrix}
\binom{C}{D} = 0
\end{align*}
or
\begin{align*}
\nonumber \\
\end{align*}
Using the first condition, the two normalised eigenvectors are
\begin{align*}
\vec{v}_1 = \frac{1}{\sqrt{7}} \binom{1}{\dfrac{-1 + i \sqrt{35}}{6}} , \qquad (\lambda_1 = \frac{3}{2} + i \frac{\sqrt{35}}{2})
\nonumber \\
\vec{v}_2 = \frac{1}{\sqrt{7}} \binom{1}{\dfrac{-1 - i \sqrt{35}}{6}} , \qquad (\lambda_2 = \frac{3}{2} - i \frac{\sqrt{35}}{2})
\end{align*}
Form the matrix ##U## whose columns are ##\vec{v}_1## and ##\vec{v}_2##. Then
\begin{align*}
\exp ( A t ) & = U U^{-1} \exp ( A t ) U U^{-1}
\nonumber \\
& = U \left( \mathbb{1} + U^{-1} A U t + \frac{1}{2!} U^{-1} A U U^{-1} A U t^2 + \cdots \right) U^{-1}
\nonumber \\
& = U \exp ( \mathcal{D} t ) U^{-1}
\end{align*}
where
\begin{align*}
\mathcal{D} =
\begin{pmatrix}
\lambda_1 & 0 \\
0 & \lambda_2
\end{pmatrix}
\begin{pmatrix}
\frac{3}{2} + i \frac{\sqrt{35}}{2} & 0 \\
0 & \frac{3}{2} - i \frac{\sqrt{35}}{2}
\end{pmatrix} .
\end{align*}
We have
\begin{align*}
U = \frac{1}{6 \sqrt{7}}
\begin{pmatrix}
6 & 6 \\
-1+i\sqrt{35} & -1-i\sqrt{35}
\end{pmatrix}
\end{align*}
and
\begin{align*}
U^{-1} = \frac{\sqrt{35}}{10 \sqrt{7}}
\begin{pmatrix}
\sqrt{35}-i & -i6 \\
\sqrt{35}+i & i6
\end{pmatrix}
\end{align*}
and
\begin{align*}
\exp (\mathcal{D} t) = e^{3t/2}
\begin{pmatrix}
e^{i \sqrt{35}t/2} & 0 \\
0 & e^{-i \sqrt{35}t/2}
\end{pmatrix}
\end{align*}
We can now compute ##\exp ( At )##,
\begin{align*}
& \exp (At)
\nonumber \\
\frac{e^{3t/2} \sqrt{35}}{420}
\begin{pmatrix}
6 & 6 \\
\end{pmatrix}
\begin{pmatrix}
\end{pmatrix}
\begin{pmatrix}
\sqrt{35}+i & i6
\end{pmatrix}
\nonumber \\
& = \frac{e^{3t/2} \sqrt{35}}{420}
\begin{pmatrix}
6 & 6 \\
\end{pmatrix}
\begin{pmatrix}
(\sqrt{35}-i) e^{i \sqrt{35}t/2} & -i6 e^{i \sqrt{35}t/2} \\
(\sqrt{35}+i) e^{-i \sqrt{35}t/2} & i6 e^{-i \sqrt{35}t/2}
\end{pmatrix}
\nonumber \\
& = \frac{e^{\frac{3}{2}t} \sqrt{35}}{420}
\begin{pmatrix}
6 (\sqrt{35}-i) e^{i \frac{\sqrt{35}}{2}t} + 6 (\sqrt{35}+i) e^{-i \frac{\sqrt{35}}{2}t} & -36 i e^{i \frac{\sqrt{35}}{2}t} + i 36 e^{-i \frac{\sqrt{35}}{2}t} \\
36 i e^{i \frac{\sqrt{35}}{2}t} - i 36 e^{-i \frac{\sqrt{35}}{2}t} & i6 (1-i\sqrt{35}) e^{i \sqrt{35}t/2} - i6 (1+i\sqrt{35}) e^{-i \frac{\sqrt{35}}{2}t}
\end{pmatrix}
\nonumber \\
& = \frac{e^{\frac{3}{2}t} \sqrt{35}}{70}
\begin{pmatrix}
(\sqrt{35}-i) e^{i \frac{\sqrt{35}}{2}t} + (\sqrt{35}+i) e^{-i \frac{\sqrt{35}}{2}t} & -6 i e^{i \frac{\sqrt{35}}{2}t} + i 6 e^{-i \frac{\sqrt{35}}{2}t} \\
6 i e^{i \frac{\sqrt{35}}{2}t} - i 6 e^{-i \frac{\sqrt{35}}{2}t} & (i+\sqrt{35}) e^{i \frac{\sqrt{35}}{2}t} +(-i+\sqrt{35}) e^{-i \frac{\sqrt{35}}{2}t}
\end{pmatrix}
\nonumber \\
& = e^{3t/2}
\begin{pmatrix}
\cos (\sqrt{35}t/2) + \dfrac{\sin (\sqrt{35}t/2)}{\sqrt{35}} & 6 \dfrac{\sin (\sqrt{35}t/2)}{\sqrt{35}} \\
- 6 \dfrac{\sin (\sqrt{35}t/2)}{\sqrt{35}} & \cos (\sqrt{35}t/2) - \dfrac{\sin (\sqrt{35}t/2)}{\sqrt{35}}
\end{pmatrix}
\end{align*}
That is,
\begin{align*}
\begin{pmatrix}
1 & 0 \\
0 & 1
\end{pmatrix}
\begin{pmatrix}
1 & 6 \\
-6 & -1
\end{pmatrix}
\end{align*}
So
\begin{align*}
\end{align*}
But different constants in each case, not the same.
Likes erobz
Yeah, I was just being lazy. Thats why I said the general solution is... the constants would be determined for the initial conditions of each. I would think those constants aren't necessarily distinct in the general solution...so I thought I could get away with it?
Likes bob012345
1. What is a linear system of ODEs?
A linear system of ODEs (ordinary differential equations) is a set of equations that describe the relationship between multiple variables and their derivatives. The equations are linear, meaning that the variables and their derivatives are raised to the first power and there are no products or powers of the variables. An example of a linear system of ODEs is x' = 2x + y and y' = -3x + 4y.
2. How do you solve a linear system of ODEs?
To solve a linear system of ODEs, you can use a variety of methods such as substitution, elimination, or matrix operations. The specific method used will depend on the complexity of the system and the desired form of the solution. In general, the goal is to isolate the variables and their derivatives on one side of the equations and the constants on the other side.
3. What are initial conditions?
Initial conditions refer to the values of the variables at a specific starting point, usually denoted as t = 0. In the context of solving a linear system of ODEs, initial conditions are used to find the specific solution to the system. These initial conditions can be given as specific values or as a set of equations.
4. Why are initial conditions important in solving a linear system of ODEs?
Initial conditions are important because they help determine the specific solution to a linear system of ODEs. Without initial conditions, the solution would be a general solution that applies to all possible values of the variables. However, with initial conditions, the solution can be tailored to fit a specific scenario or problem.
5. What are some real-world applications of solving linear systems of ODEs?
Linear systems of ODEs have many real-world applications, including modeling population growth, chemical reactions, and electrical circuits. They are also used in engineering and physics to model and predict the behavior of systems and processes. In economics, linear systems of ODEs can be used to analyze supply and demand, investment growth, and other economic trends.
  • Math POTW for University Students
  • Differential Equations
