Linear Tranformation: Find the kernel of T
  • Thread starter Thread starter MozAngeles
    Kernel Linear
The discussion revolves around finding the kernel of a linear transformation T: P4 → P3 defined by T(p) = p', where p is a polynomial in P4. Participants are exploring the implications of the kernel in relation to polynomial derivatives and the dimensionality of the kernel and range.
  • Participants discuss the expression for the kernel and its dimensionality, questioning the validity of their calculations and assumptions regarding the representation of polynomials in P4. There is an exploration of the meaning of specific vectors in the context of polynomial spaces.
The discussion is ongoing, with participants providing insights and questioning each other's reasoning. Some have identified potential errors in their understanding of the kernel, while others emphasize the importance of clarity regarding the basis used for polynomial representation.
There is a focus on the definitions and properties of kernel spaces in linear transformations, as well as the need for clarity in the representation of polynomials in terms of their coefficients. Participants are navigating the implications of the rank-nullity theorem in this context.
MozAngeles
Let T: P4--->P3 be a linear transformation given by T(p)=p'. What is the kernel of T?
T(a0+a1+a2x2+a3x3+a4x4)=a1+2a2x+3a3x2+4a4x3
Ker(T)= { T(p)=0}
so, a1+2a2x+3a3x2+4a4x3=0
then a1=2a2x+3a3x2+4a4x3
Ker(T)= { (-2,1,0,0), (-3,0,1,0), (-4,0,0,1)}
I solved this based off an example from class. But when I checked the dim[Ker(T)]= 3 and the dim[Rng(T)]=4 since my Rng(T)= {1,x,x2,x3} and dim[P4]=5
using general rank nullity theorem I have 7=5, which doesn't make sense. So I'm wondering where I went wrong.
Thank you for your help.
Ker(T)= { T(p)=0}
Ker(T) contains all polynomials in P4 whose derivative is 0.
Look at your answer: Ker(T)= { (-2,1,0,0), (-3,0,1,0), (-4,0,0,1)}.
A polynomial in P4 is defined by 5 coefficients. What polynomials in P4 do these elements consisting of 4 coefficients represent?
I realize where i went wrong and found my kernel to be (0,0,0,0,1) , which then the rest makes sense
That is correct, sort of.
A good examinator would ask what (0,0,0,0,1) actually represents in P4. In other words, what set of basis vectors are you using? Without that information, (0,0,0,0,1) is meaningless as answer.
Moreover, Ker(T) is not a vector, but a subspace.
If my thinking is correct...
{(0,0,0,0,1)} represents the set of vectors that are an element of P4 such that the linear transformation of these vectors, in P4, is a homogeneous equation
What linear transformation? How does a homogeneous equation come into play? :oldconfused:
Back to basics: Ker(T) is a subspace of P4.
Your answer should say what polynomials are in that subspace. If you want to represent the elements of P4 in some basis, you have to make clear what basis you are using.
You seem to know what the answer is, but you don't convey it clearly at all.
i was using the definition from by book for kernel space. Being that the initial prob stated it was a linear transformation I used the definition: Ker(T)= {v element of V: T(v)=0) which in words is If T: V--> W is any linear transformation, there is an associated homogeneous linear vector equation T(v)=0. In this case Ker(T)= {(a4,a3,a2,a1,a0):(0,0,0,0,a0}
What Samy_S was asking was, what polynomials are in the kernel? P4 is a (function) space of polynomials.
Writing an answer of (0, 0, 0, 0, a0) is meaningless if we don't know what the basis is that you're using. In particular, we don't know what polynomials are represented by this vector.
The helpers basically wanted to know how are the entries in your matrix representation are ordered? When you write ##(a,b,c,d,e)##, are your ordering them according to ##\textrm{coeff}(x^0,x^1,x^2,x^3,x^4)## or ##\textrm{coeff}(x^4,x^3,x^2,x^1,x^0)## or ##\textrm{coeff}(x^3,x^1,x^2,x^4,x^0)## etc?
