Linearly Dependent Sets: Answers to Your Questions
3 replies · 2K views
ichigo444
Do all linearly dependent sets have elements that are linear combinations of each other? Or does this apply only to some of the Linearly Dependent sets?
And as a follow up question: How do you know if a set of 2x2 matrices is linearly dependent or linearly independent?
Thank you and may God bless you. :)
on Phys.org
The usual definition of "linearly dependent" is
"The vectors [itex]\{v_1, v_2, v_3,\cdot\cdot\cdot, v_n\}[/itex] are linearly dependent if and only if there exist scalars [itex]a_1, a_2, a_3, \cdot\cdot\cdot, a_n[/itex], not all 0, such that [itex]a_1v_1+ a_2v_2+ a_3v_3+ \cdot\cdot\cdot+ a_nv_n= 0[/itex]".
Suppose [itex]a_k[/itex] is non-zero. Then we can write [itex]a_1v_1+ \cdot\cdot\cdot+ a_{k-1}v_{k-1}+ a_{k+1}v_{k+1}+ \cdot\cdot\cdot+ a_nv_n= -a_kv_k[/itex]. Now, since [itex]a_k\ne 0[/itex], we can divide both sides of the equation by it to get [itex]v_k[/itex] written as a linear combination of the other vectors in the set.
So, yes, if a set of vectors is linearly dependent, then at least one of them can be written as a linear combination of the others.
That works the other way, also- if at least one of the vectors can be written as a linear combination of the others, then they are linearly dependent. That can be used as an alternate definition of "linearly dependent".
Wow thank you good sir/ma'am. You have been answering all my question for what seems to be ages now. Thank you very much and may i know where you are from?
Sir may i add? May i use invertability as an alternative way of determining the linear independence of a set? Thank you again.
