Liouville's Theorem: Prove f is Constant
The problem involves demonstrating that an entire function \( f \) is constant under the condition that \( |1000i + f(z)| \geq 1000 \) for all \( z \in \mathbb{C} \). The discussion centers around the application of Liouville's Theorem in the context of complex analysis.
  • Participants discuss the properties of the function \( g(z) = \frac{1000}{1000i + f(z)} \) and its implications for \( f(z) \). There is exploration of whether \( g(z) \) is entire and bounded, as well as the conditions under which Liouville's Theorem can be applied.
Participants have raised questions about the analyticity of \( g(z) \) and its boundedness. Some have suggested that since \( g(z) \) does not have a point of discontinuity, it may be entire, leading to implications for \( f(z) \). There is an acknowledgment of the relationship between the boundedness of \( g(z) \) and the constancy of \( f(z) \), but no explicit consensus has been reached.
Participants note the importance of the inequality \( |1000i + f(z)| \geq 1000 \) in ensuring that the denominator of \( g(z) \) does not vanish, which is critical for the analysis of \( g(z) \) as an entire function.
retrostate
Show that if f is an entire function that satisfies
|1000i + f(z)| ≥ 1000, for all z ∈ C, then f is constant.
(Hint: Consider the function g(z) = 1000/1000i+f(z) , and apply Liouville’s Theorem.)
Ok, so I assume that as f is entire, then for it to be a constant, it must be bounded (Liouville’s Theorem).
Am I right in thinking that as g(z) is the reciprocal of |1000i + f(z)|, Then
1000/1000i+f(z) ≤ 1000/1000 =1
This is as far as I’ve got, I’ve sat here for hours, so any help would be very much appreciated….Thank you
You should write that a little more carefully. Use parentheses where you need them and don't drop the absolute value. But yes,
|1000/(1000i+f(z))|<=1. So the function g(z)=1000/(1000i+f(z)) is bounded, yes? Is it entire? Why? What does that let you say about f(z)?
I would say g(z) is differentiable on the whole C - {-1000i}, and so would be entire within the region {z:Imz > - 1000}. And is bounded above at g(z)=1,Therefore, by Liouvilles Theorem f(z) is a constant? i.e. if f(z)=0 then g(z)=i < 1…?
To apply Liouville's theorem to g(z) it has to be analytic EVERYWHERE. Since g(z) is a quotient of analytic functions it's analytic everywhere that the denominator doesn't vanish. Does the denominator ever vanish? Remember you are given |1000i+f(z)|>=1000.
Ahhh, no the denominator can't vanish because we are dividing 1000 by an inequality which is greater or equal to 1000, therefore, the maximum value g(z) can take is 1 if |1000i+f(z)|=1000.
So, as the denominator does not vanish it must be analytic everywhere
Ok, so if g(z) is bounded and entire what does Liouville tell you about it? What does that imply for f(z)?
That f(z) is constant if and only if g(z) is constant, and because g(z) is bounded and entire, by Liouvilles theorem it is constant, which implies f(z) is constant
Sure, that's it!
Thank you Dick, I can't tell you how much I appreciate the time you have spent helping me.
  • · Replies 18 ·
