Loading variables from numbered files in a loop with load()
  • Topic: MATLAB
  • Thread starter Thread starter blizzard12345
    Data Matlab Plotting
4 replies · 4K views
blizzard12345
hi i want to load multiple sets of data in a loop and the plot a linear graph each time the loop runs below is my code so far, i can't seem to load any variable from the file names, the variable are for example int_force=[1;2;3;4;5] deflection=[1;2;3;4;5]
function load_data
clear all
clc
%determins the number of saved files in directory
graph = dir('internalforce_*');
k = size(graph);
%starts a loop to load increase values of eg, internalforce_1,
%internalforce_2...
for i = 1 : k(1)
file_name = sprintf('internalforce_%d',i)
variable = load(file_name,'int_force')
file2_name = sprintf('deflection_%d',i)
variabletwo = load(file2_name,'deflection')
plot(variable,variabletwo)
hold on
end
end
Your code doesn't seem to be doing exactly as you're saying. The method I use which works with 100% certainty is by doing this:
Code:
%Begin Loop
intforce_str = strcat('internalforce_', num2str(i),'.txt'); %I assume its a txt file
file_name = fopen(intforce_str,'r')
[I]%this line depends on your data format.
%I like to place the data in a format where textscan simply reads
%your data column by column and places it in a cell corresponding
%to each column. You don't have to do this,
%but this is most intuitive to me.[/I]
variable = textscan(file_name,'%g')
defl_str = strcat('internalforce_', num2str(i));
file2_name = fopen(defl_str,'r')
%same as above
variabletwo = textscan(file2_name,'%g')
hold on
end %end plot loop
%I usually turn hold off by instinct.
hold off
end %end load_data
hi thanks for the reply when i use fopen it returns a value of -1 which I've read to mean it can't read my data?.. does this mean I am saving the data in the wrong format? I am currently using the below code to save a column vector
fn = sprintf('deflection_%s',num2str(ii));
save(fn,'deflection')
along with a loop to determine the number 'ii'
If fopen returns -1 that means your current path is not set to the correct folder or the file does not exist. try using the full path of the file instead.
hi i made the original code work now, i just needed to plot the variable and variabletwo in the form "variable.int_force" so use the saved variable name after it thanks for your help
