Mentor
- 51,098
- 27,128
WannabeNewton said:It makes it seem like even an accelerating observer who adopts a momentarily comoving freely falling frame at ##E## will get SR results identical to those of a freely falling observer at ##E## when in reality he just gets SR results identical to those of the same accelerating observer in SR. Correct?
Yes.
WannabeNewton said:The two frame fields will be different in the small patch of space-time because for the accelerating observer we will need a different freely falling frame at each event along his worldline contained in the patch whereas for the freely falling observer we can trivially have the same freely falling frame at each point along his worldline within the patch since this frame would get parallel transported along the worldline right?
Yes, although I would say it's even simpler: the frames carried by each observer can only match up at a single event, because one is accelerated and the other is inertial.
WannabeNewton said:if we are to think of the "freely falling frame" as really describing a frame field, we can only make sense of it for the freely falling observer since for the accelerating observer we won't have a single "freely falling frame" in the patch, which would make the concept of ascribing a "freely falling frame" to a frame field associated with the accelerating observer ill defined?
Yes.
WannabeNewton said:In what way would the EEP then be too weak with regards to this? Would it then be unable to state the equivalence of local experiments performed by accelerating observers in space-time with identical experiments performed by the same accelerating observers in SR?
If you use the term "freely falling frame" in stating the EEP, then it seems obvious, given the above, that it can only apply to measurements made by a freely falling observer, yes?
WannabeNewton said:(which we know the EEP does state, event by event)
We "know" this because we intuitively extend the EEP to accelerated observers, since that's obviously the intent. But stating the EEP using the term "freely falling frame" does not, strictly speaking, justify this extension of its scope (at least IMO).
