Neutrinos02 said:
Hello,
in general relativity we introduce local inertial frames to be such frames where the laws of special relativity holds. Let ξα the coordinates in the local inertial frame, so we get ds²=ηαβdξαdξβ. If we switch the frame of reference to coordinates xμ : ξα=ξα(x0,x1,x2,x3) and with gμν(x)=ηαβ ∂ξα/∂xμ ∂ξβ/∂xν we get:
ds²=gμν(x) dxμdxν
I don't understand why it isn't possible to find a transformation to get ds²=ηαβdξαdξβ on the whole or almost the whole mannifold? Because gμν(x) is still the same on the whole mannifold?
Thanks
Neutrino
The reason is rather similar to the reason why you can't use a flat paper map to give an accurate to-scale representation of distances on the globe. That (hopefully simpler and more familiar) problem involves only the spatial metric rather than the space-time metric, but the principles are the same.
Suppose you have a space-time metric ##g_{\mu\nu} = \eta_{\mu\nu}##. Then, what is the Riemann curvature tensor of this metric? You can do a formal calculation (see for instance the Wiki formula
https://en.wikipedia.org/w/index.php?title=Riemann_curvature_tensor&oldid=667714359)
$$R^\rho{}_{\sigma\mu\nu} =\partial_\mu\Gamma^\rho{}_{\nu\sigma}
- \partial_\nu\Gamma^\rho{}_{\mu\sigma}
+ \Gamma^\rho{}_{\mu\lambda}\Gamma^\lambda{}_{\nu\sigma}
- \Gamma^\rho{}_{\nu\lambda}\Gamma^\lambda{}_{\mu\sigma}$$
To apply this, you need to find the Christoffel symbols for your metric, but since the Christoffel symbols ##\Gamma_{\rho\mu\nu}## are a sum of partial derivatives of the metric, and all of the metric coefficients are constants, ##\Gamma_{\rho\mu\nu} = 0##. When you compute ##\Gamma^{\sigma}{}_{\mu\nu} = g^{\rho\sigma} \, \Gamma_{\rho\mu\nu} ## they're still zero.
So, you wind up with a zero Riemann curvature tensor, when you substitute in the zero values for the Christoffel symbols into the Wiki expression for the Riemann in terms of the Christoffel symbols. This should be expected, it says that ##\eta_{\mu\nu}## is "flat", you can parallel transport a vector around a loop and have it come back unchanged, just like you can do on a flat plane, which has the spatial metric ##ds^2 = dx^2 + dy^2## (or the space-time metric ##-dt^2 + dx^2 + dy^2##).
Now, the question becomes - what coordinate transformation turns an all-zero Riemann tensor into a tensor with non-zero components? The answer to that is simple too - it doesn't happen. The tensor transformation laws say that if all the components of a tensor are zero in one basis, they're zero in any basis. So no such a transformation exists.
Therefore, no matter what transformation you try, you can't transform zero-curvature metric(one with a vanishing Riemann tensor) into a metric with non-zero curvature, or vice-versa.
