Local max and min (including a domain)
  • Level: Undergrad
  • Thread starter Thread starter King_Silver
    Domain Local Max
17 replies · 2K views · last reply
King_Silver
I have this function: f(x) = √3x + 2Cos(x)
I have to find the local maxima and minima,where -π ∠ or equal to x ∠ or equal to 2π.
1: Differentiate the function given.
f'(x) = 3/(2√x) -2Sin(x)
2: Find where f'(x) is undefined or = 0 to get critical points.
3: Find f''(x) [The second differential]
4: Sub in critical values for x, if < 0 = Minima, if > 0 = Maxima.
Question 1:What does this domain mean? and how will it affect my answer(s)?
Question 2:Is there any easier way to find where f'(x) is undefined or 0 other than subbing in random values until you get ones that work? I always get stuck at this part despite knowing everything else, without the correct critical values it is pointless to continue with a question.
Is that ##\sqrt{3}x## or ##\sqrt{3x}## in your function?
##\sqrt{3x}##
PeroK said:
Are you sure?
A sugar I misread! its the other one.
Try that one. It might be a little easier.
f'(x) = sqrt(3) - 2Sin(x)
PeroK said:
And where is ##f'(x) = 0##?
Couldn't tell you if my life depended on it.
Been trying numbers such as 0, -1,-2,-3,-4 and 1,2,3,4... etc. but they are giving decimal places. Also does "undefined" just mean like it doesn't give a solution whatsoever?
If you re-arrange it, you get:
##sin(x) = \frac{\sqrt{3}}{2}##
If that doesn't look familiar, then you could use the inverse function ##sin^{-1}##
Ah yea so that is = 60 so one critical point is = 60. So there is a method to find where x = 0 thanks :) !
And what about where it is undefined? :) and where does the domain come into a question like this?
Mathematically, the trig functions are defined in terms of radians, not degrees. Also, trig functions are periodic, so ##sin(x)## will take a given value at more than one point. This is where the domain comes in. You need to find all points where ##sin(x) = \frac{\sqrt{3}}{2}## in the given domain.
You've got a nice, regular function for ##f'(x)## so that's not undefined anywhere. So, in this problem, there's no complexity like that to worry about.
I'm not sure why you're interested in where ##f(x) = 0##. You don't need that to find maxima and minima.
*f'(x) my bad.
So are these steps correct?
1: differentiate f(x)
2: Find where f'(x) is 0 or undefined (i.e. critical value at 60 as calculated)
3: Find f''(x)
4: sub in critical point instead of x
5: If greater than 0 it is a minimum, if less it is a maximum.
But the question stated to find the "local maxima AND minima" I will only find one of these using this method right? And will the domain affect my answers?
King_Silver said:
*f'(x) my bad.
3: Find f''(x)
That's the correct method. You will find all maxima and minima this way. The domain does affect your answer. If you look for any ##x##, your ##f(x)## here has an infinite number of maxima and minima.
You're still working in degrees, I see!
*1/3pi my bad! Thanks! :D
Doesn't ##\sin x = \frac{\sqrt 3}{2}## have another solution when ##-\pi \le x \le 2\pi##?
How about ##x=\frac{2\pi}{3}## (or ##x=120^\circ##)?
No, it is NOT "= 60". It is equal to 60 degrees or [itex]\pi/3[/itex] or simply [itex]\pi/3[/itex]. You can drop the "radians" in such an answer but not degrees.
