Identifying Critical Points in e^x(1-cosy): Local Extrema or Saddles?
The discussion focuses on identifying critical points of the function f(x,y) = e^x(1 - cos(y)) and classifying them as local maxima, minima, or saddle points. Participants derived the first and second derivatives, concluding that critical points occur periodically at y = 2πn for even n, while x can take any value. The second derivative test proved inconclusive, indicating that there are no local extrema or saddle points, but rather "critical lines" where the function is constant at zero.
  • Understanding of partial derivatives and second derivative tests
  • Familiarity with periodic functions and their properties
  • Knowledge of critical points in multivariable calculus
  • Experience with mathematical software like WolframAlpha for graphing and analysis
  • Study the implications of critical lines in multivariable functions
  • Learn about the classification of critical points in higher dimensions
  • Explore the use of the Hessian matrix in determining local extrema
  • Investigate other functions with periodic behavior and their critical points
Mathematics students, educators, and professionals in fields requiring multivariable calculus, particularly those interested in optimization and critical point analysis.
scubakobe
1. If f(x,y)=e^{x}(1-cos(y)) find critical points and classify them as local maxima, local minima, or saddle points.
I found the partials and mixed partial for the second derivative test as follows:
f_{x}=-e^{x}(cos(y)-1)
f_{y}=e^{x}(sin(y))
f_{xx}=-e^{x}(cos(y)-1)
f_{yy}=e^{x}(cos(y))
Knowing this, and that e^{x} does not equal 0, then the critical points are periodic at 2∏n, where n is even intervals.
However, I get inconclusive when plugging it all into the second derivative test. And a quick query in WolframAlpha shows that there are indeed critical points, however no local maxima,minima or saddle points?
I also referred to another post in this form with a very similar problem, except it was (e^x)(cosy) and it was determined to have no critical points.
Any ideas on this?
Thanks,
Kobbe
f_{y}=e^{x}(sin(y))
Any ideas on this?
Thanks,
Kobbe
Second-order tests involve not only ##f_{xx}## and ##f_{yy}##, but also the mixed-partial ##f_{xy}##.
Yes, sorry forgot to include that:
fxy=exsin(y)
f_{y}=e^{x}(sin(y))
What do you mean with the sentence "the critical points are periodic at 2∏n"? To define a point, you have to give both x and y. The first derivatives are zero if y is equal to even number multiple of ∏, but what should be x?
ehild
ehild
Yes, that's where I'm having trouble. My thought is, and another post (Which I can't find now, sorry) suggested, is that ex cannot equal zero - so x would have to be equal to 0 in order for the ex to become 1.
A graph in WolframAlpha suggests a saddle point; and it does confirm 2∏ as the interval, but if asked about local min, max, or saddle points Wolfram states there are none.
Well, can be x something else? What about the first derivatives if x=10 or anything, and y =2pi?
ehild
ehild
Yes, x can be anything as long as the y=2∏. For both the f_{x} and f_{y}.
So the x can range from 0\rightarrow∞, but the only time the first partials will equal 0 is when y=2∏. Or even multiples, as I had said.
So here's the second order test...
D(x,y)= f_{xx}(x,y)f_{yy}(x,y) - (f_{xy}(x,y))2
D(x,y)= f_{xx}(10,2∏)f_{yy}(10,2∏) - (f_{xy}(10,2∏))2
Which then simplifies to 0.
This means the second order test is inconclusive. However, there clearly are critical points.
They are rather "critical lines", are they not ? The function is constant (zero) along the lines y=0, y=2pi... y=2kpi. There are no local extrema, no saddles, although the function has it minimal value zero along these lines.
ehild
ehild
I guess that's true, however in my classes so far we've only referred to points, and not "critical lines."
So the answer would be no critical points? The 2∏ intervals are simply a recurring minimum value, but not necessarily a local minimum.
I do not know how these lines are called, or they have a name at all. I think you can say that all points (x, k*2pi) are critical as the first derivatives are zero, but there are no local extrema or saddles. ehild
