Locating center of mass for hollowed out sphere
The discussion focuses on locating the center of mass (CM) for a hollowed-out sphere, specifically a uniform sphere of radius R with a spherical hole of radius r at a distance d from the center. Participants agree that the problem can be modeled as two masses: the original sphere and the negative mass of the hole. The equation for the center of mass is derived as x(cm) = (-r³ * d) / (R³ - r³), where m1 is the mass of the sphere and m2 is the mass of the hole. Simplifying this expression is noted as a potential next step.
  • Understanding of center of mass calculations
  • Familiarity with spherical geometry
  • Knowledge of mass density (ρ) and volume (V) calculations
  • Basic algebra for simplifying equations
  • Learn about the derivation of the center of mass for composite shapes
  • Study the implications of negative mass in physics
  • Explore simplification techniques for algebraic expressions with denominators
  • Investigate applications of center of mass in engineering and physics problems
Students in physics or engineering courses, educators teaching mechanics, and anyone interested in advanced geometry and mass distribution concepts.
astenroo
A uniform sphere of radius R has a spherical hole of radius r removed. The center of the hole is at a distance d from the center of the original sphere. Locate the CM relative to the center of the sphere.
Ok, so, the problem should be considered as two spheres, one with a negative mass (the hole). Due to symmetry the CM should be moved from the center of the original (x,y,z:0,0,0) sphere along one of the axes "backwards" (if hole is on positive x-axis, then CM moves from origin along the x-axis towards negative). My problem is, I'm not sure how to express r in terms of R (d is an irritant here ;)), and where to begin.
think in terms of 2 masses
what are the masses?
The masses are \rhoV,
so for small sphere m=\rho*4/3\pi*r³
Mass for hollowed out sphere is \rho*4/3\pi*R³ - \rho*4/3\pi*r³
then from the equation d_2=M_{s}d_1 / M_{h} where s=small and h=hollowed. But here I still have to contend with d1...
granpa said:
it looks to me like your distances will be -x and x+d
But I'm not sure
uhm...now I'm lost...
you have d1/d2=M2/M1
x = position of new center of mass
d1= x minus position of M1
d2= position of M2 minus x
d = position of M2 minus position of M1
d = position of M2
position of M1 = 0
position of M2 > 0
x < 0
it looks to me like your distances will be x and d-x (where x is negative)
But I'm not sure
yeah. I got ahead of myself and got confused.
Heh, ok. So, your M1 would be the larger sphere and your M2 would be the "hole"? Just to make sure I'm following :)
yeah
I didnt know the formula but i took what you had and did i simple
thought experiment with a rectangle instead of a shere and created a hole
that eliminated one whole half of the rectangle.
So why haven't you done this?
Backing up a bit, you did not cite the relevant equations. So what is the equation for the center of mass of two objects, each of which has some known mass and some known position? There is nothing per se in this particular equation that restricts objects to have positive mass. (Well almost nothing. The equation results in a division by zero if the total mass is zero.)
Why do you feel you need to do so? (Hint: You don't.)
You are making this problem much harder than it is.
hi! Sorry for the late reply here.
Ok so,
equation for solving centre of mass is:
x(cm) = (m1x1 + m2x2)/(m1+m2). From earlier m2 is considered as negative mass, and the expressions of the masses have been posted earlier.
m1=rho*4/3*pi*R³
m2=rho*4/3pi*r³
x1=0, and x2=d. x(cm) then becomes: x(cm) = (-r^3*d)/(R^3-r^3). This expression could perhaps be further simplified, but I am ashamed to admit, that I do not know how...
looks like i made it more complicated than it really is. I do that sometimes.
Sometimes to solve a problem you just have to sleep on it and get a fresh perspective in the morning.
d1M1=d2M2
works fine. its just that one of the distances is negative
think of a fulcrum under the center of mass and then move the fulcrum until it is past one of the masses. as you do so the distance associated with that mass will become smaller and smaller till it becomes negative. the other distance is still positive
and of course one of the masses is negative so the equation still works just fine.
A quick thought experiment with rectangles shows that it works fine.
the first mass is the mass of the original sphere and the second mass is the negative mass of the hole.
the mass of the sphere minus the hole is irrelevant as far as I can see.
Ok, but I think the solution I posted recently is accurate. Now I just need to simplify the expression (-r^3*d)/(R^3 - r^3). It can be done, but I do not know how.
thank you for the help BTW :)
the equation you gave doesn't solve for the distance. it solves for the coordinate of the center of mass given the coordinates of the 2 masses
your equation solves for x0
which is the coordinate for the center of mass
substituting
d1 = x0 - x1
and
d2 = x1 - x0
into
d1M1=d2M2
gives your equation
so the best way to reduce your equation is not to use it in the first place.
the whole question of how to reduce an equation with a sum in the denominator is a fascinating one. I would be very curious to know of any general equation for it.
Your solution is exactly right, and it really isn't overly complex. You could multiply it by 1, with 1 written in the form
1=\frac{1/r^3}{1/r^3}
  • · Replies 25 ·
