(log√125 + log √27 - √8)/ log 15 - log 2 = 3/2
  • Thread starter Thread starter lionely
    Log
16 replies · 6K views
lionely
1)Without using tables, show that
What i tried was
(3/2 log 5 + 3/2 log 3 - 3/2 log 2)/ log 5+log 3 - log2
then from here I don't know where to take it.
2) Find the value of x if log x2/ log a^2 = log y^4/logy
I tried this 2logx - 2loga = 4 log y- log y
2logx = 3logy+ 2 loga
then here I get stuck..
What i tried was
You miss some parentheses.
ehild
What i tried was
Since you want the problem to reduce to something simple (3/2) you should combine the log terms and simplify from there.
lionely said:
1)2) Find the value of x if log x2/ log a^2 = log y^4/logy
If we have
[tex]\log(x)=y[/tex] then what is x?
Yes, so now do the same thing. Set the equation so that it is in the form [itex]\log(x)=y[/itex] and then make x the subject. Oh and y will be some complicated expression.
And once you've done that, remember the rules
[tex]a^{x+y}=a^xa^y[/tex]
[tex]a^{\log_{a}(x)}=x[/tex]
I'm kind of confused if I have this
log x = 3logy - 2loga
I duno how to get rid of log a to make it log (x) = y
log y^4/logy=4log(y)/log(y)=4
ehild
ehild noticed some mistakes which you should first address.
[tex]\frac{\log(a)}{\log(b)}\neq \log(a)-\log(b)[/tex]
What you're thinking of is
[tex]\log\left(\frac{a}{b}\right)=\log(a)-\log(b)[/tex]
Oh, Umm should it should be
log x^2/ log a^2 = 4
2log x = 8 log a
log x = 4log a
10^a^4 = 10^x
x= a^4?
And for the first one
is it (3/2log5 + 3/2log 3 - 3/2log 2)/ (log 5+ log 3) - log 2
= 1/2log log + 1/2log 3 - 1/2log2?
I think you made some mistake when copying the problem. It should be
(log√125 + log √27 - √8)/ (log 15 - log 2 )= 3/2.ehild
2log x = 8 log a
log x = 4log a
10^a^4 = 10^x
x= a^4?
Yes that's correct :smile:
No, again, you want to simplify that expression into a simple answer of 3/2, so what you're aiming to do is to combine each log term, not split them up further. Use the [itex]\log(a)+\log(b)=\log(ab)[/itex] rule.
ehild
Nope the [itex]\sqrt{8}[/itex] should be [itex]\log(\sqrt{8})[/itex]
I still don't get it combine them? But aren't they too big? shouldn't I try to get them down to like small numbers and then try to cancel out?
Yes, combine them! If you get them down to small numbers then you'll end up with the fraction you posted earlier that cannot be canceled further.
Use
[tex]\log(a)+\log(b)-\log(c)=\log\left(\frac{ab}{c}\right)[/tex]
for both the numerator and denominator and see if you notice any nice cancellations.
ehild
Looks like a typo.
How about the first one should be:
(log√125 + log √27 - log√8)/ (log 15 - log 2 )= 3/2
As ehild said early on, you need to use sufficient parentheses .
