Is the Function f(x) = x^2 Injective?
The function f(x) = x^2 is not injective because it fails the definition of an injection, which states that if f(a) = f(b), then a must equal b. In this case, f(a) = f(b) leads to a^2 = b^2, resulting in a = b or a = -b, indicating that distinct inputs can produce the same output. A simple counterexample is f(-1) = f(1), where -1 does not equal 1, demonstrating non-injectivity. The discussion also highlights that proving non-injectivity can be achieved through a single counterexample rather than complex logical derivations. Overall, the key takeaway is that the function is not injective due to the existence of multiple inputs yielding the same output.
Korisnik
Prove that ##f: \mathbb{R}\to\mathbb{R}, f(x) = x^2## is not injective.
Definition of an injection: function ##f:A\to B## is an injection if and only if ##\forall a,b \in A, f(a) = f(b) \Rightarrow a = b##.
##f: \mathbb{R}\to\mathbb{R}##
Let ##a,b \in \mathscr{D_f}##, suppose ##f(a) = f(b)##, then ##a^2=b^2##. By solving this equation we get ##a=b\ or \ a = -b##.
This is where I'm stuck. How do I prove that (and is the following what I have to prove) ##\forall a,b \in \mathbb{R}, (a = b \vee a=-b) \Rightarrow (a = b) \equiv F##?
By introducing the substitutions ##A := (a =b), B:= (a = -b)##, the proposition is reduced to ##(A \vee B) \Rightarrow A \equiv F##.
Now, what am I looking for in the truth table? The expression is obviously not always false, but for the ##F## to hold I have to find one case where the proposition does not hold and I've proven my hypothesis. From the truth table, if ##B \equiv T, A \equiv F## we get ##T \Rightarrow F##, which is false; consequently, our problem is solved.
Is my approach correct, and is there another approach? Thank you in advance.
It is as simple of finding a counterexample. In this case, there are many.
Thank you. Would you mind addressing my question? So far I've found one "explanation", where the author says that "it is obvious", after finding the solutions to the equation.
Korisnik said:
Thank you. Would you mind addressing my question? So far I've found one "explanation", where the author says that "it is obvious", after finding the solutions of the equation.
For example we have:
##f(-1) = f(1)## but ## -1 \neq 1## thus f is not injective
The explanation the book provides is: "The solution of the equation is ##|a| = |b|##, that is, we have 4 solutions in ##\mathbb{R}##, which means that the given implication does not hold because ##a## and ##b## obviously don't have to be equal; consequently, the proposition is false."
I'm intrigued as to how the "obvious" step is performed formally and not intuitively.
@Math_QED 's answer has been formally!
Math_QED said:
##f(-1) = f(1)## but ##-1 \neq 1## thus f is not injective
... proves ##\exists a,b \in A \, : \, f(a) = f(b) \wedge a \neq b##, which is the negation of ##f## being injective.
Another approach was to draw a graph of ##y = x^2## and look for two values of ##x## with the same value of ##y##.
...which I could've gotten without the equations obtained by the author of the book. So what is their purpose? I'm not practicing (dis)proving the injectivity, but the logic of proving "obvious" statements formally.
In this case it seems, that a feasible solution depends strongly on the rules of logical deviations and and the amount of arithmetic which you regard as being allowed to use. Neither of it is obvious to us, and assuming the usual logic and arithmetic, the given two(!) answers are enough.
In addition we can't say what the equations obtained by the author of the book and their purpose are, since we don't know them. Maybe it is simply to practice the handling of logical terms.
I can't see why an obvious result should be artificially complicated.
A counterexample even holds in the case you are rejecting indirect proofs or proofs by contradiction. The negation of an all-quantifier is simply an existence-quantifier. Otherwise you should explain what "not injective" means.
Likes Korisnik
You're getting confused about what constitutes a proof. To prove for example that not all whole numbers are odd, you only have to find one that is not odd.
To prove this sort of thing requires only a single counterexample, nothing more.
To prove something positive, such as to prove there are infinitely many primes requires a logical proof.
