Logic gates, truth tables, circuits
25 replies · 6K views · last reply
moenste
(a)
Logic circuit of three NOR gates: inputs A and B each feed a NOR gate with its inputs tied together, outputs C and D feed a final NOR gate giving output E.
The NOR gate combination in Figure 1 acts as an AND gate. Copy and complete the truth table.
Partially completed truth table with columns A, B, C, D, E; rows for A and B show 0 0, 0 1, 1 0, 1 1, with C, D and E columns blank.
(b) An aircraft door is locked by two bolts A and B each of which operates a sensor giving a logic 1 when the bolt is fully inserted. A further sensor C gives a logic 0 output when the door is shut.
A circuit using logic gates is required to give logic output 1 only when both bolts are inserted and the door is shut.
Logic circuit diagram: inputs A and B feed an AND gate giving output D; D and the output E of a NOT gate fed from input C go into a second AND gate giving output F.
By completing a copy of its truth table, show that the circuit of Figure 2 meets this requirement.
Partly completed truth table with inputs A, B, C in columns on the left, all eight binary combinations listed, and empty output columns D, E and F to the right.
(c) Draw a circuit using two-input NOR gates only that performs the same logic function.
2. The attempt at a solution
(a) The truth table:
Truth table with columns A, B, C, D, E and four rows of binary values: 0 0 1 1 0; 0 1 1 0 0; 1 0 0 1 0; 1 1 0 0 1.
(b) I don't quite understand what is required. This is the truth table:
Truth table with columns A, B, C, D, E and F and eight rows of 0s and 1s, with F equal to 1 only in the last row where all inputs are 1.
(c) I don't quite understand this part either. This is the graph:
Hand-drawn logic circuit: inputs A and B feed a NOR gate giving output C, which feeds a second NOR gate with both inputs tied together (a NOT configuration) giving output D.
and its truth table:
Truth table with columns A, B, C and D and four rows of binary values: A and B vary across rows, C is 1, 0, 0, 1 and D is 0, 1, 1, 1 in the rows shown.
What is correct / wrong? I am not sure on (b) and (c) parts, but would also like to know whether (a) is correct or not.
All your work looks correct to me. It might be good in (b) to add a statement that only row 7 (A=1, B=1, C=0: both bolts A&B closed and closed door sensor C=closed) gives 1, which is what they want.
CORRECTION: The diagram in part (c) is wrong.
So, regarding (b) we can rephrase the problem:
as like: the door is locked when the output is 1 and bolts A and B have a logic of 1 and the C sensor has a logic of 0.
And then the answer is: when the only output is 1 in the seventh row, both A and B are having a logic of 1 and the C sensor has a logic of 0. Right?
And regarding (c): don't we need to get the same answer? I mean A and B should be 1, C should be 0 and the only output should be 1. And in my case I have everything the other way around: the only output is zero, A and B have 0 and C has 1. Is this OK? I am mostly unsure on (c). And putting two NORs means putting them in series, like I did, not somehow in parallel, correct?
Oh, sorry. I take it back. I disagree with your diagram (c). You need to use an input signal C, that is not in your diagram.
So, (a) and (b) are correct?
Could you please explain what an input signal is?
Yes. I think so.
It would be a completely independent signal with values like in part (b). It should have rows with 0,1 values for every possible combination of the A and B values. The C in your original diagram was determined by A and B. That is wrong.
Sorry, still don't understand it. I searched for "input signal logic gate", didn't get much relevant information.
How do I need to change my graph?
C should be an external input on the left side, just like in the diagram (b). It should not be the result of a logic gate. You should have the exact same table A, B, C values as in (b) and your NOR-only diagram should have the exact same final values as column F in (b).
Hm, let's fix the graph first.
Something like this?
Logic circuit diagram with inputs A, B and C. A and B feed a two-input OR gate whose output goes into a second two-input OR gate, which also takes C, producing Output.
You are using OR gates. Your diagram should only use 2 input NOR gates.
I just found a similar picture online, didn't want to upoload another mine poor drawing of mine here : ).
I am mostly interested is the connection correct in the graph? (Imagine a same graph buth with circles.)
Update
Is this graph correct?
Logic circuit diagram: inputs A, B feed a NOR-style gate (XNOR-like shape with bubble) producing node D, which together with input C feeds a second gate with an output bubble producing output E.
If in doubt, label some signals and check the truth table. I have done as much as I should on a homework question.
Thank you for your time.
That's what I have, I guess it's correct.
Truth table with columns A, B, C, D and E, listing five rows of binary values (0 and 1).
Once again, thank you!
No. For A=0 and B=0, you need one row for C=0 and another row for C=1. Same for all other combinations of A and B. As I said before, see the truth table of (b)
Also, the end result values of E are not what you want them to be. They should be the same as column F in your answer for (b)
The columns for A, B, C, and the final signal must be identical to the columns of A, B, C, and F in your answer for (b)
I don't quite see a way to make E identical to F. Maybe the graph is wrong and I missed something?
Truth table with input columns A, B, C, D and output column E, listing eight rows of 0s and 1s.
This diagram is wrong if E does not match F of your answer to (b).
Part (a) has some examples of how to use NOR gates to negate a signal and combine signals. You need to study that and use those techniques.
I can only think of
Logic circuit schematic: inputs A and B each feed a NOR gate with both inputs tied together (acting as NOT). Outputs C and D feed a final NOR gate whose output is E.
Truth table with inputs A, B, C, D and output E, listing 16 rows of 0s and 1s as a binary count from 0000 to 1111, with E equal to 0 for most rows and 1 for the rows 0011 (rows where C and D are 1 and A and B are 0), 1001 and 1111.
Update
And also of this:
Hand-drawn logic circuit diagram with inputs A, B and C on the left, gates labelled D, E, F, G and H in between, and output I on the right.
Truth table with input columns A through H and output column I, listing all 256 rows of binary values; shown as 9 columns of 0s and 1s with headers A, B, C, D, E, F, G, H, I.
and this:
Hand-drawn logic circuit with inputs A, B, C, D feeding two NOR-shaped gates whose outputs are labelled E and F, which feed a final NOR-shaped gate with output G.
Truth table with columns A, B, C, D, E, F, G and eight rows of binary values 0 and 1, with output columns E, F and G.
The last one has input D that does not exist and its values in the truth table are wrong. Keep trying. Be methodical, there are too many options to guess at anything. You may try working backward. You want the final signal to be 1 only when A=1 and B=1 and C=0. The NOR is only 1 when both inputs are 0. Make the NOR for the final signal and manipulate the inputs as required. Then check it with a truth table.
I made an A B C | F table, tried to make a Boolean formula F = A * B * C' from the only 1 output present, and tried to derive a graph from it, but it all goes to a three input AND gate, there isn't much information on NOR-only gates online.
And reverse structuring isn't helping at all. How many columns are there between ABC and F? One? Two? Ten?
This link shows how you can use NOR gate logic to make other types of logic: https://en.wikipedia.org/wiki/NOR_logic.
You can use these to piece together any logic you need.
That depends on how many intermediate steps you need to use NOR gates to get the correct logic. You may want to leave space for several intermediate logic columns between the first three inputs (A,B,C) and the final output F. Or you can start the truth table with columns (A,B,C,F) and keep tacking on columns for intermediate logic.
You can use these to piece together any logic you need.That depends on how many intermediate steps you need to use NOR gates to get the correct logic. You may want to leave space for several intermediate logic columns between the first three inputs (A,B,C) and the final output F. Or you can start the truth table with columns (A,B,C,F) and keep tacking on columns for intermediate logic.
Thank you for the link. I wish I saw it earlier, could save me much time yesterday : ).
Hand-drawn logic circuit of NOR and NOR-type gates with inputs A, B and C, intermediate outputs D, E, F, G, H and I, and final output J.
Truth table with input columns A, B, C and output columns D through J, containing rows of binary 0 and 1 values.
The table has 6 columns between C and J, I don't think I would manage to get the answer by going backwards.
Again, thank you for the link!
Excellent!
I have a small suggestion to clean it up. You are negating the C input twice in a row. That is unnecessary.
FactChecker said:
Excellent!
Yes, that's an improvement. "I" could be skipped and connected directly to "F". Thank you for the tip : ).
I don't think so. C doesn't need any changes. I think C can go directly into the last NOR.
Oh, yes, I looked at C but somehow wrote I.
Truth table with eight input columns A, B, C, D, E, F, G and H, showing 8 rows of binary 0 and 1 values.
