Logical partitions for an external disk
  • Thread starter Thread starter mech-eng
    Disk partitions
14 replies · 3K views · last reply
mech-eng
Hello. Is it possible to create logical partitions for an external storage such as an SD Card? When I take a back up, I format the disk instead of deleting the old data because deletion takes too much time compared to formatting. Then I do a copy-and-paste new data to the disk evacuated from old data. If I have logical parts on the disk I could just format that parts so I can take better and faster backups.
Thank you.
You could also use a backup program. Then you only have to transfer the changed data.
BoB
Would you please check and explain what is wrong?
I cannot see J even though it has been formatted.
I can only see F. What configurations should I choose to make disk divided into partitions?
Thank you.
What is wrong I am doing to create a partition? When I try I take this notification
I searched for that notification but I didn't find a good explanation for my case.
Thank you.
It seems clear. It says the a Windows limitation prevents the recognition of multiple partitions in a removable disk. Is this related to your other posts about making backups of an SD card?
The reason I ask is that I have horror stories about home-grown backup procedures failing. Simple is better and your approach is getting complicated. Using professional backup tools is always recommended.
Does this mean there is no way to do such a thing? I watch a video doing this I will add.
FactChecker said:
Is this related to your other posts about making backups of an SD card? The reason I ask is that I have horror stories about home-grown backup procedures failing. Simple is better and your approach is getting complicated. Using professional backup tools is always recommended.
Yes, all posts under this thread are related to each other. What do you mean by home-grown backup procedures? Do you mean amateurishly invented backup methods? I will ask about backup procedures in another thread. Here let's discuss about partitions.
In this video it is being done.
Thank you.
We all understand you want to talk about partitions here but you are asking about using them for some sort of DIY backup scheme. We don't want to encourage you to do something that is illogical.
That said Windows does not support the thing you want to do. Kludging together a system level thing that the OS doesn't really want to do is asking for trouble. Even if you get it to work it may fail catastrophically after some future system update.
BoB
Yeah. What he said.
Actually I misrepresented the situation. We had a very professional system administration group. Unfortunately, the computers that we used were very specialized and the current operating systems like Unix and Windows with backup utilities were not available then. Even with professional programmers, there were some very serious errors in the backup processes they used. If you create your own process, my advice is to test it thoroughly and don't allow any hardware or OS changes without thoroughly testing it first.
That being said, if you keep full copies occasionally and will not suffer terribly if all changes except the last full copy are lost, then feel free to do your own thing. Just make sure that your full copy process is simple and foolproof. Backups are a subject where errors can cause a lot of grief, depending on the situation.
BoB
Did you watch the vid I added? How can people do this with that program, not taking that notification: The new created partition does not used in Windows ...?
Windows have a in-built tool to create partitions in internal hard drive. So if the special program cannot do this for extrernal ones, isn't it a little tomfoolery to develop and release such programs?
Thank you.
Why would anyone want to help someone who a) consistently ignores our advice, and b) gets snotty when things don't go his way when the advice is ignored? The thing that is standing in your way more than any other is your attitude. If you change it, things will go better. If you keep doing what you're doing, you will have similar results to what you are having now. Up to you.
This is important.
Thank you.
Your intellectual curiosity is a good thing. But please be cautious. Your original goal was to improve the security of your data. This seems to be getting into some dangerous areas that may not improve the security of your data. So experiment in ways that do not jeopardize your data.
PS. I don't know if you have ever experienced the feeling that you may have just wiped out half a year of work. I have experienced it more times than I want to admit. At that point in time, the backups either make your day or ruin your day. Please be careful.
Yes. The person that made the video is using a specific set of hardware and OS version. You are using a different set of hardware and OS version.
The third party software may or may not work as well for you as it did him. If this was just for general use I would say go for it. For backup it is a really bad idea.
BoB
