Looking for a Gearmotor; How Much Torque to Close this door?
  • Thread starter Thread starter Hes
    Torque
The discussion revolves around determining the appropriate gearmotor torque required to close a specific door, considering its mass, dimensions, and closure time. Participants explore the mechanics involved, including the moment of inertia and angular acceleration, while seeking additional details about the door's configuration.
  • One participant inquires about the specific door design and hinge axis to better assess the torque requirements.
  • Another participant questions the feasibility of the proposed gearmotor's operation as a door closer, noting the slow closure speed and potential engineering concerns.
  • Several participants emphasize the need for detailed information regarding the door's hinge location and the axis of rotation to accurately calculate the moment of inertia and torque.
  • Participants discuss the formula for torque, suggesting that the mass moment of inertia and angular acceleration must be considered, along with various safety factors.
  • One participant expresses gratitude for the clarification on the moment of inertia, indicating it will aid in their calculations.
  • There is a reiteration that without knowing the axis of rotation, it is challenging to provide assistance on the moment of inertia calculation.
Participants generally agree on the importance of understanding the door's configuration and the need for specific measurements to calculate the required torque. However, there is no consensus on the exact torque value or the best approach to determine it, as multiple viewpoints and uncertainties remain.
Participants highlight the need for precise definitions and measurements, such as the door's hinge location and the axis of rotation, which are critical for accurate torque calculations. There are also mentions of various factors that could influence the torque requirements, including friction and safety considerations.
Hes
I'm trying to find a gearmotor that applies enough torque to close this door.
Door Mass = 136lbs
Door Dims = 40in width x 85in height
Time to close = 60sec
Door's rotation = 180 degrees
Any tips and advice would truly be appreciated.
Do you have an actual door in mind?
Where is the door hinge axis?
If this is a real door you might simply measure the force needed to close it at the point where you plan to connect the lever arm.
I can't see from the drawing how this could operate as a door closer. Is the gearmotor supposed to have a rotary output?
Is closure speed fixed? 180° open to closed in 60 seconds (2°/second) is rather slow over much of the closure range.
Take care to rescue the angel; crushing one in a door mechanism is considered poor engineering practice.
Much more info needed for any kind of intelligent answer:
  • This figure is plan (top) view, correct? If not, specify it so the community can determine the direction of the gravity vector. Gravity may add force requirements.
  • Is the door hinged? If hinged, where is the hinge? Specify it.
  • If no hinged, about what axis does the door pivot? Specify it.
  • door mass ≠ lbs. You better figure that out first.
  • Torque = (mass moment of inertia) x (angular acceleration)
  • (mass moment of inertia) will likely be estimated from inertia primitive formulas and modified with parallel axis theorem. Look 'em both up.
  • (angular accel) is estimated α ≅ Δ(angular velocity)/Δ(time to accelerate)
  • Add a bunch of fudge factors for safety, friction, gravity effects, windage effects, robustness, etc., and that will give your peak torque. Size the gearmotor for that.
  • This figure is plan (top) view, correct? If not, specify it so the community can determine the direction of the gravity vector. Gravity may add force requirements. Yes this is top view
  • Is the door hinged? If hinged, where is the hinge? Specify it. Yes on the right side.
Thank you very much for your help. I kept struggling with finding the torque, using a different equation. That mass moment of inertia is going to help me a lot
The moment of inertia won't anyone here wanting to help if we don’t know the axis of rotation for the door.
the axis of rotation is the end of the door on the right side
  • · Replies 22 ·
