Looking for equation for change in momentum
The discussion centers on calculating the change in momentum of a baseball with a mass of 0.2 kg, initially traveling at 40 m/s and then returning at 60 m/s. The correct approach involves using the formula for momentum, which is mass multiplied by velocity. The final momentum is calculated as -12 kg-m/s, the initial momentum as 8 kg-m/s, leading to a change in momentum of 20 kg-m/s when considering magnitude. The key takeaway is the importance of correctly identifying initial and final states in momentum calculations.
  • Understanding of basic physics concepts, specifically momentum
  • Familiarity with the formula for momentum (mass x velocity)
  • Knowledge of vector direction and its impact on calculations
  • Ability to perform arithmetic operations with negative numbers
  • Study the principles of momentum conservation in physics
  • Learn about vector quantities and their significance in physics
  • Explore examples of momentum change in various sports scenarios
  • Review the concept of impulse and its relationship to momentum
This discussion is beneficial for physics students, educators, and anyone seeking to deepen their understanding of momentum and its calculations in real-world scenarios.
jjg242
One of the questions on my test review tells me to look for the equation in the book, but i have a different book because my backpack got stolen and I can only get my hands on a old physics book at the moment. can someone help me out and let me know what equation I am looking for here? thanks,
A pitched baseball, of mass 0.2 kg, arrives at home plate with a speed of 40 m/s and is batted straight back to the pitcher with a return speed of 60 m/s. What is the magnitude of change in the ball's momentum?
a. 40 kg-m/s b. 8.0 kg-m/s c. 18 kg-m/s d. 20 kg-m/s
You shouldn't need a special formula here. Do you understand that momentum is mass x velocity? The change in anything will be final value minus initial value. (Tricky part: Direction--and signs--matter.)
so simply:
(0.2*40)-(0.2* -60) = 20 kg-m/s
is this correct?
No. Your main mistake is getting the signs wrong. But you also got initial and final reversed. Fill this out:
Final momentum =
Initial momentum =
Change (Final - Initial) =
Final momentum =
Initial momentum =
maybe I am finding the momentum wrong?
Final momentum = -12
Initial momentum = 8
Change (-12 - 8) = -20 since it's magnitude, just 20. I don't see how it could be anything else.
Exactly right! (I misread your answer before :redface:--sorry about that. You didn't make the sign error I thought you did! The only mistake was reversing initial and final, but that didn't really matter.)
thanks, this forum is so helpful.
  • · Replies 19 ·
  • · Replies 19 ·
