yungman
- 5,741
- 291
As the tittle, I am looking for off line switching supply of about 400VDC output. Anyone know who make this?
Thanks
Alan
Thanks
Alan
This discussion focuses on sourcing or designing an offline switching power supply that outputs approximately 400V DC with a current rating of 200mA. Participants recommend several suppliers, including Direct Power Technologies and Emerson Network Power, while also discussing the feasibility of using existing components like the NCP1606BOOSTGEVB from On Semi. The conversation highlights the challenges of transformer design and isolation requirements, with suggestions for DIY solutions involving high-voltage rectifiers and voltage multipliers. The UCC28517 EVM module from Texas Instruments is also mentioned as a potential reference for designing a suitable power supply.
PREREQUISITESElectrical engineers, power supply designers, and hobbyists interested in high-voltage applications or those looking to create compact, efficient power supplies for devices such as guitar amplifiers.
I so wish I had stop and talk to my engineer those days. I just let him did all the high voltage supply designs. The electronics part is quite easy, it's the transformer, I just never design transformers before.mdjensen22 said:Does something like this http://www.powerint.com/sites/default/files/PDFFiles/rdr236.pdf work? (380V).
It's overkill in terms of current, but it can be purchased which saves you some trouble if you only need a one-off. http://www.digikey.com/product-detail/en/RDK-236/596-1418-ND/2533771
My bad - I just went by their little check box that said "isolated". I guess I could have looked at the doc. On Semi has one they are marketing as isolated as well. This may be worth looking at as well...yungman said:Thanks for you input. I read over the doc quickly. I think it is not isolated. I need a true off line supply that isolate from the AC side.
Thanks
Alan
mdjensen22 said:My bad - I just went by their little check box that said "isolated". I guess I could have looked at the doc.
http://www.digikey.com/product-detail/en/NCP1606BOOSTGEVB/NCP1606BOOSTGEVBOS-ND/2337352
es1 said:Not sure if you prefer to make or buy.
To Buy:
http://www.home.agilent.com/agilent...ng&ckey=839427&nid=-35687.384733.00&id=839427
About $7K
To Make:
At the 80W range the typical solution is to use a PFC boost fed from the line to get a large intermediate voltage, like 500V. Then drop that down with an isolated flyback.
These data sheets give you most of what you need to design the application circuit.
http://www.irf.com/technical-info/appnotes/an-1077.pdf
http://cds.linear.com/docs/Datasheet/3748fa.pdf
dittoYes I am cheap...very cheap!
jim hardy said:ditto400V 200ma ,, only 80 watts?
is there enough room in a PC 200 watt supply to remove one or more of the high current 5volt windings from the donut and replace them with 400 volt windings of tiny wire?
Or disconnect one and use it to energize another donut with your hv windings?
Obviously you'd not pick the one that's used for regulation feedback.
Seems to me you get a volt or two per turn on those things
Tedious, but you can't beat that for cheap.
you'll need fast high voltage rectifiers... i am not fluent in those.
1 Introduction
The UCC28517 module is a 100-W offline ac-to-dc voltage converter with power factor correction (PFC). The
prototype was designed to show how the UCC28517 could be configured to control two dc-regulated outputs
offline with one control integrated circuit. The module was design to operate over a universal input range of 85
V to 265 V with two dc regulated outputs. Output B is a 12-V, 8-W regulated output intended to be used as a
bias supply and output A is a 385-V, 100-W regulated output.
jim hardy said:Yungman
among the debirs on my hard drive was an appnote for this TI IC
UCC28517 EVM
document number is SLUU117C − September 2002 − Revised July 2003
has partslist including the inductor and pcb layout
