Looking to buy my first telescope
  • Topic: Stargazing
  • Thread starter Thread starter Millacol88
    Telescope
11 replies · 4K views
Millacol88
Right so I'm looking to buy my first telescope and rather than start a thread I thought I'd post here. How does this look for a beginner telescope? Keeping in mind its my first and I really only want to look at the moon, some of the closer planets, and maybe some nearby galaxies or nebulae. I am not expecting Hubble-quality images, just to get started with the hobby. Thoughts?
Astronomy news on Phys.org
My opinion is that if you aren't going to use a computerized mount (AKA a GoTo Mount) then get a Dobsonian telescope, but after looking through 2 sites I can't seem to find one for the same price with the same aperture. This one here http://www.telescope.com/Telescopes.../c/12/sc/13/p/27160.uts?refineByCategoryId=13 comes with a barlow and some other stuff, but no eyepieces, so you may be better off getting the one you linked.
Also, if you head to astromart.com or the classified section of cloudynights.com you can probably snag a used scope that's similar for half the price.
I looked at that one, but it just seems to bulky to be practical at all. Why do you recommend a dobs over a regular reflector on an eq mount? Just curious.
Dobs are simple. Newts on German Equatorial Mounts generally suffer from cost-savings on the mounts. Too light, too cheap, unable to bear the weight of the OTA properly. A decent OTA on a cheap, light mount will suffer from vibration, poor damping, etc, and generally be a pain to work with.
Usually you get more aperture for the price, plus dobs are REALLY easy to use. EQ mounts are kind of weird to use at first, as you can simply move the scope up and down or left and right. Plus you have to polar align them a bit to use them correctly, but that isn't much of an issue once you do it a few times. The tube length is longer, but your EQ mount is going to be almost as much of an issue to move around and store. There's nothing wrong with the EQ mounted one though, and I think you'll be satisfied with it if you purchase it. It's a little easier to keep track of objects, as you only have to move the RA axis and many times the mounts come with a slow motion knob for this purpose. (At least that's what I've heard, I've never owned a non GoTo EQ mount)
For a first telescope, NOTHING beats a Dob in my opinion. It's the "point and shoot" of telescopes.
Edit: As Turbo said above, a good EQ mount usually cost a decent amount. While this particular one would probably work ok for you, I highly suggest a Dob, as it will be much more stable and easier to use. You won't be kicking the legs around in the dark and having to worry too terribly much about a little wind.
Honestly I probably wouldn't even notice any vibration until I got a second telescope that didn't have the same problem. :P I don't need perfection, just something a little bit cheaper and smaller than a dob.
Right, I think I'll go with this one if you think the EQ mount would be bearable. Believe me, I gravitated towards Dobs immediately when I started looking at telescopes, but I just don't really have that much space to store it. At least the one I'm looking at has a relatively short tube and a collapsible tripod. Perhaps for my second scope a few years down the road I'll look at a 10" dob and try and make room for it. No reviews I've read on this one have mentioned any problems with the mount, just a little shaking/vibration.
"just"?
That's the primary complaint about mounts.
DaveC426913 said:
"just"?
Is it? As you can probably tell, I'm new at this. :P I wish I knew someone on here who owns this one so I could figure out how big of an issue it will be...
EDIT: Just curious Dave, would you recommend a dobs as well?
Let me put it this way. Any scope will make you happy if you've never owned one before. The one on the EQ mount looks like it takes up a little less floor space and is probably a tad lighter overall, so if your really pressed for space then it will be better. However the dob will be sturdier and easier to use. It's your scope, you buy what you want. I think you will be happy with either of them.
Well since it doesn't seem there are any enormous differences between the two, and I found my original one for cheaper and with better eyepieces, I think I'm going to pull the trigger on that one. Thanks everyone for your help!
It is highly dependent on what you want. Dobs gives you great bang for your buck at the cost of awkwardness. For someone like me, who likes to haul his scope down to the lake where there's darker skies, it's not the best. Dobs have no tracking controls on their mounts, so you're freely wheeling the thing around the sky by the seat of your pants.
But for light-gathering ability (which is what you want in order to see dim objects), they cannot be beat.
If you find the mount vibrates too much, you might try to improve the tripod legs as was done here. I did it on my son's '102 with great results. Looks a whole lot better too!
