Looking to understand time dilation
373 replies · 56K views
ghwellsjr said:
But there are no frame dependent measurements in the Twin Paradox, just like in the real world. In fact, there can be no frame dependent measurements in any scenario, or else we would have a preferred frame and relativity would not be a viable theory about reality.
The meaning of "frame dependent" is the same as "dependent on relative velocity". The observations of the twins depend on their relative velocity at the time of the observation.
It doesn't matter which frame you use, you will determine that each twin makes the same measurements.
The time-dilation between the two frames is the result of the LT of coordinates between frames. But each twin realizes that the others clock is actually working properly in its rest frame, so how can the time-dilation be given any credence ? What is indisputable is the fact that they will have different ages.
I don't see the paradox.
What you need to do is pick ONE frame. Use time dilation and length contraction as appropriate for each twin as they measure the other one's clock, then you'll see the paradox.
No, I won't see a paradox because there isn't one. It sounds as if you're mixing measurements between frames.
I think it's time to bring on the muon. As you know, this particle decays after a short time and it's life-span can be estimated. When the life-span of a muon is measured in the lab, it is found to be much larger than calculated. This is a space-time diagram of a muon being created from a collision, then decaying a short time later into two other particles. Read the diagram from the bottom up which is how time is flowing. All the spatial movement is on the horizontal line, i.e. left-to-right or right-to-left.
In the lab frame the time measured is 8.9 units, but along the muons worldline the interval is 2.9 units. So what is the life-span of the muon ? I go for the time along the muons line for a very good reason, which I will now give, if you're still following me.
The case I've illustrated shows the muon traveling at 0.8c. Suppose in another lab a similar experiment is done where the muon travels at a different speed. The lab clocks now will give something different from the 8.9 I got but they will get the same value along the muons line. So, do we argue about the lab clock reading, or agree on the muons own time, which will be the same ?
You are the one who is mixing measurements between frames. If you won't do what I'm asking you to do, your eyes will never be open.
I don't think this is the twin (non) paradox that we all love so much and never get tired of.
Matheinste.
GHWells, I think we've said all that can be said and we're not getting through to each other so it's probably best to leave it there.
Grimble said:
But why do you say that a and b are moving? It is just as true to say that A,B & C are moving at 0.8c relative to a or b.
That's the way you set it up, with A,B, & C in the reference (zero) frame, and a & b moving at .8c relative to it!
We're not dealing with frames in general, but this specific one which you proposed.
a and b are stationary and located at the same point and their clocks are synchronized.
b accelerates away at gamma=2
each sees the others clock as time dilated up to the point (call it 'x') that b starts to decelerate.
b reaches 'x' and decelerates to a complete stop
after b stops a perceives that b's clock has ticked half as many times as a's clock.
b agrees.
ghwellsjr said:
Mentz, you don't think that each twin observing and measuring the other one's clock as running slower than his own during both legs of the trip but yet only the traveler's clock ends up with a lower time is a paradox?
It's not a paradox, because the traveler (he) concludes the home twin (she) suddenly ages during his turnaround. When he adds her ageing during his inertial outbound leg, to her ageing during his turnaround, and then to her ageing during his inbound inertial leg, he gets her correct total ageing at the end of his trip (which of course must agree with HER conclusions about her own ageing during his entire trip).
Take the gamma = 2 case, and suppose he ages 20 years on each of his inertial legs, for a total of 40 years. Then she (according to her) ages 40 years during each of his inertial legs, with no ageing during his turnaround, for a total of 80 years.
According to him, she ages 10 years during each of his inertial legs, for a total on the inertial legs of 20 years, plus 60 years during his turnaround, for a total of 80 years during his entire trip (which agrees with her conclusion, as it of course must). No paradox, no inconsistency.
Anyone who insists that there can be no sudden ageing of the home twin, according to the traveler, during his turnaround, must then conclude that the traveler in NOT actually inertial during his constant-velocity legs. I.e., they must conclude that he isn't allowed to use the time-dilation result during his constant-velocity legs.
Mike Fontenot
b agrees.
Not if b uses the SR clock synch method, which results in reciprocal measurements, i.e., b will conclude the a clock is running at half rate. SR is symmetrical/reciprocal by design.
I insist that there can be no sudden aging of anyone and I do not come to either of your other two conclusions. If you will pay attention to what I am going to explain to you here, then you will also be able to understand what is now evading you. OK? Please pay close attention.
First off, you have to understand how an observer in relative motion to another observer measures the time-dilation of the other observer. It has to do with relativistic doppler. It simply means that each twin has an identical clock that the other one can observe. An easy way to make this happen is for each of them to have a clock that flashes at some interval, say, once per second or once per minute. Each observer will count their own flashes and will count their twin's flashes when they see them. They will also calculate the ratio of the clock rate of their twin's clock compared to their own. As long as they are stationary with respect to each other, their own outgoing flash will occur as often as their twin's incoming flash. When they see the flash rates being identical, they can conclude that there is no relative motion between them and there is no time dilation.
Now as soon as the traveling twin accelerates away and achieves a terminal speed, the ratio of the incoming flashes will be lower than the outgoing flashes. From this ratio, they can each calculate the relative speed between them and from that they can calculate the time-dilation factor. It will be symmetrical, they will both measure the same ratio and detemine the same speed and the same time dilation. While they are moving apart, this ratio will be less than one. At the turn around point, assuming the traveling twin achieves the same speed on the inbound leg as the outbound leg, the traveling twin will immediately see an increase in the doppler frequency, in fact, it will be the reciprocal of what it was before, but this new ratio will determine the same speed as before and the same time dilation as before.
However, the home twin will not see the shift in the doppler frequency (from a ratio of less than one to greater than one) until some time later because it takes time for the distant increased frequency of the flashes of light to reach him. But when it does, he will still determine that the speed of his twin is the same as it was before, just in the opposite direction (approaching instead of retreating) and the time-dilation factor is the same as it was before.
Now what accounts for the difference in the aging of the twins? It is simply that they are counting the low rate doppler versus the high rate doppler for different lengths of time. The traveling twin counts the low rate and high rate coming from the home twin for an equal amount of time (corresponding to the outgoing and incoming legs) but the home twin counts the low rate doppler for much longer than the high rate doppler of the traveling twin so his sum total will be much smaller. They both agree on the final age difference of themselves and their twins and they both agree that the traveling twin aged less.
Now if you want to say that each twin can observe the aging of the other twin, you would have to say that each twin always measures a constant aging of the other twin because the time-dilation factors never change except for the brief moments during acceleration.
Now I want to point out for the sake of others on this thread, that I have not declared any frame of reference in the analysis of the scenario. In fact, it doesn't matter which frame of reference you want to use, the analysis will be identical. All measurements and observations made by observers in a scenario will not change just because you analyze it from different reference frames.
Mentz114 said:
I think I should point out that the classical twin paradox where one remains inertial is just a special case of two worldlines starting at the same point and rejoining after they have done some travelling. In all cases, regardless of how the travellers moved, the elapsed time on their clock will be the Lorentzian length between the parting and meeting of the 4D curves that describe their journeys.
That's it. All observers agree on those elapsed times because they are the geometric invariant of Minkowski spacetime. What more can be said ? There is no paradox or confusion possible about this, surely ?
And the time measured along those those world lines, between two points/events on those world lines will be identical. That is how it seems to me. How can it be anything else?
The Lorentzian length, must be the same for each as calculated from the other, they are, after all, reciprocal journeys, one of the other.
As I clearly stated, a and b are, at that point, stationary with respect to each other.
DaleSpam said:
Yes. This is called the relativity of simultaneity.
The clock can only show one time, that is what clocks do ...
Isn't it just that different observers read/observe/record different times on that same single clock?
And what has that to do with thehttp://www.bartleby.com/173.html" ?
ghwellsjr said:
And which conclusion is that?
Before we can come to any resolution of the Twin Paradox, we have to understand what it is. The two twins start out at the same age in the same location. One of them accelerates away to some high speed. During this time, as they each observe the other's clock, they are each running slower than their own. This part is symmetrical. Eventually, the traveling twin decelerates and comes back at the same high speed. During this time, as they each observe the other's clock, they are each running slower than their own, just like before. The only time when this is not true is during the brief period of time when they observe the process of acceleration/deceleration. Eventually the traveling twin comes to a stop at the starting point and when they compare the actual times on their clocks, the traveling one has less time on it. Do you agree with this as a statement of the Twin Paradox?
Yes that is the twin paradox, but I don't see any reason at all why the acceleration should have that effect. The paradox to me is that they should each see that the other is younger than they are and that occurs in the outward leg of the journey.
acceleration changes the relativity of simultaneity which changes the accelerating twins calculated value of the present time on the stationary twins clock
Yes, it changes the angle of rotation between the FoRs?
One clock only reads a single number at any given event, and all observers in all reference frames agree on that value. But that is not the issue here. The issue here is how two different clock's times compare, and that is determined by the relativity of simultaneity.
If you agree that the traveling twin in the Twin Paradox ends up aging less than the home twin, we do you insist that the traveler, a, in your scenario ends up aging the same as the stationary observer, A?
Also, why do you think the time-dilation occurs only on the outward leg of the journey?--it occurs during the entire journey except for the brief intervals of acceleration/deceleration.
Please explain your concern about acceleration, it's just the way one twin gets to a new speed with respect to the other twin. The acceleration itself has no affect on the age, it just changes the aging rates. They have to spend time at the relative speed for the different aging rates to result in a different ages. If you don't understand that, please be more specific in your questions/comments.
No he ages the same but that age appears to be less to the other twin.
Each sees the other as younger.
Time dilation occurs for the whole time that they are moving one to the other.
The amount of time dilation is a function of the current velocity and exists only while the relative motion exists, and it changes every time their relative velocity changes. But once they come to rest with each other and there is no longer a relative velocity there is, no longer, any time dilation. As an effect of their motion it can only exist while there is motion.
Yes acceleration merely changes the apparent ageing rate;
and No, the length of time spent in motion has no effect whatsoever, the ONLY thing that affects the amount of time dilation is the current velocity.
I include a spacetime diagram of 5 twins, the elapsed time on the twins clocks depends on the length of their spacetime paths, only when the lengths are identical they will record an identical elapsed time.
[PLAIN]http://img713.imageshack.us/img713/9677/event.gif
Diagram 1. The Minkowski diagram of the twin paradox drawn to scale.
The diagram is the FoR of the resting twin. (the floater)
As it is from that FoR, the travellers times and distances are dilated and contracted respectively'
http://img707.imageshack.us/img707/3873/simultaneity.jpg
Uploaded with ImageShack.us
Diagram 2. The path of the traveller shown as rotations, the rotation changing as the traveller decelerates and returns.
http://img17.imageshack.us/img17/9214/figure5z.jpg
When the velocity is shown as rotation a change in the velocity will be shown as the rotation increasing or decreasing and the corresponding contracted length changing.
Using the gamma = 2 example I gave previously, it is indisputable that the TOTAL ageing by the home twin, during the entire trip, must be 80 years. The home twin AND the traveler can't possibly disagree about that fact.
IF you insist that, ACCORDING TO THE TRAVELER, the home twin doesn't age AT ALL during the turnaround, then he (the traveler) must conclude that ALL of her (the home twin's) ageing must occur during the two constant-velocity legs of the trip. So the sum of her ageing during his two constant-velocity legs MUST be 80 years (while he ages a total of only 40 years).
But if you consider him to be "inertial" on his OUTBOUND leg (and thus justified in using the time-dilation result), he would conclude that she ages only 10 years during his outbound leg.
Similarly, if you consider him to be "inertial" on his INBOUND leg (and thus justified in using the time-dilation result), he would conclude that she ages only 10 years during his inbound leg.
So, if you consider him to be inertial on BOTH of his constant-velocity legs, AND if you Insist that she doesn't age (according to him) during his turnaround, then he MUST conclude that her TOTAL ageing during his entire trip was only 20 years. But it is indisputable that her total ageing during his entire trip is 80 years. There is a missing 60 years. Where does it occur?
ANY proposed alternative frame for the traveler that gives zero ageing for the home twin during the traveler's turnaround, MUST get a total of 80 years for the home twin's ageing during the two constant-velocity legs. There is just no way of avoiding that (given the insistence that no ageing occurs during the turnaround).
If you insist that there is no ageing of the home twin (according to the traveler) during the turnaround, then you have various alternatives for apportioning the required 80 years of home-twin ageing, among the two constant-velocity legs.
You can adopt PassionFlower's frame for the traveler, in which the traveler is inertial (and thus justified in using the time-dilation result) during the outbound leg, but NOT on the inbound leg. So, in that alternative, the total home-twin ageing during the traveler's outbound leg is 10 years, and so her total ageing during his inbound leg must be 70 years.
Or, you can use the Dolby & Gull frame for the traveler, in which the traveler isn't inertial (and thus isn't justified in using the time-dilation result) in EITHER of the constant-velocity legs.
I consider both of those alternatives to be fatally flawed. I have critiqued both of them in another thread, starting with this posting:
https://www.physicsforums.com/showpost.php?p=2983139&postcount=76 ,
and continuing in the following two posts.
Mike Fontenot
Time dilation means the time units get stretched, not shortened. The clock slices time into longer intervals.
https://www.physicsforums.com/attachments/30116
Nonsense. Whether or not a given worldline is inertial at some event is coordinate-independent. Specifically, a worldline is inertial iff the magnitude of the proper acceleration is zero.
Grimble,
I have a digital alarm clock that I normally leave plugged into the wall when I'm at home and it keeps perfect time because it is getting its time base from the line frequency which is maintained to be accurate. However, when I take this clock on a trip, I have to unplug it from the wall and then it uses an internal battery and crystal oscillator to keep track of the time but this timebase is off and it runs 1% slow. Whenever I get where I'm going, I have to readjust the time.
For example, on my last trip, I traveled for 5 hours which is 300 minutes so it "lost" 3 minutes. If I momentarily uplug the clock and move it to another room and plug it in again, I cannot tell that it has lost any time even though I know that during that brief period of time, it was running 1% slow. We could say that while the clock is traveling, it is experiencing a time-dilation of 1%. I think you can see that the clock has to spend time traveling in order for there to be any time lost on the lock and the longer it travels, the more time is lost.
You are correct that the amount of time-dilation is a function of velocity only, but that just means the clock is running slower. If the moving clock doesn't spend much time at speed but quickly reverts back to its stationary state, then there won't be much slow-down of the clock. But if it spends a very long time at velocity, then the clock gets more and more behind and it doesn't somehow recover when it stops just like my alarm clock doesn't automatically switch back to the correct time after a long trip. It does switch back to the correct timebase but not the correct time.
Does this help you see the difference between aging rate and age? Or time-dilation and time "lost"?
ghwellsjr said:
Grimble,
No, because time dilation is only an effect seen by a remote observer moving with a relative velocity to the clock that is time dilated.
The whole idea that a clock can actually be time dilated because of it's speed is untenable!
Due to its speed relative to what?
Relative to an 'observer'? - then it would be something that only that observer would see.
The clock doesn't run any differently, it still follows its own world line and keeps proper time.
Any inertial clock in space can be considered to be stationary, it does not and cannot have any speed as a property of the clock only in respect to another body.
So time dilation is and can only be an effect observed by the moving observer caused by the way he takes his measurement. If the moving observer measures using his own clock he will find that time is not dilated.
