Lorentz-Invariance of Photons travelling parallel to each other
  • Thread starter Thread starter VVS
    Parallel Photons
The discussion focuses on demonstrating the Lorentz-Invariance of two photons traveling parallel to each other, specifically analyzing their 4-Momentum vectors. The participants utilize the notation p_1=\hbar k and p_2=\hbar \left(\omega,\alpha k,0,0\right) to represent the photons. A key point raised is the need to establish the time component of the 4-vector connecting the two photons, with emphasis on the orthogonality of the 4-momentum to the relative position vector under Lorentz transformations.
  • Understanding of 4-Momentum vectors in special relativity
  • Familiarity with Lorentz transformations
  • Knowledge of the properties of photons and their behavior in spacetime
  • Basic grasp of vector mathematics and orthogonality
  • Study the derivation of 4-Momentum vectors for massless particles
  • Explore Lorentz transformation equations in detail
  • Investigate the implications of orthogonality in relativistic physics
  • Review examples of photon interactions and their momentum conservation laws
This discussion is beneficial for physics students, researchers in theoretical physics, and anyone interested in the principles of special relativity and the behavior of light in a relativistic framework.
VVS
Show the Lorentz-Invariance of the following spatial statement: Two photons are traveling parallel to each other. The relative position vector of the two photons is orthogonal to the velocity and has length d.
/ The attempt at a solution[/B]
The first thing that comes to my mind is to represent the two photons with 4-Momentum Vectors.
So this is done the following way:
p_1=\hbar k=\hbar \left(\omega,k,0,0\right)
p_2=\hbar k=\hbar \left(\omega,\alpha k,0,0\right)
Now I need a 4-vector that connects the two photons. It is easy to see that the spatial component of that vector is just
\vec{d}=\left(0,0,d\right)
But I am not sure what the first (time) component of that corresponding 4-vector would be?
From here on I guess it is simple. All I need to do is show that under a Lorentz-Transformation for arbitrary \vec{v} the four-momentum of the photons is always orthogonal to the relative position vector. I might be wrong here.
What you wrote is antiparallel, i.e the direction reversed.
Parallel would be multiplying by a positive factor the expression k.
Thanks you're right. I edited it.
  • · Replies 16 ·
