Lorentz transformations formulas
6 replies · 4K views
blueberrynerd
I'm slowly trying to understand sp relativity. I admit I got lost in the last thread I posted :blushing:. But thanks to all who replied!
I have a question about the Lorentz transformations formulas. This is more of a mathematical question about how the formulas are derived.
If you have the two formulas,
x'= γ( x- vt) and x= γ(x' + vt')
which represent the x components for two reference frames S and S', and where γ is the Lorentz factor,
and you combine them to solve for t:
x'= γ[γ(x' + vt') - vt]
how do you arrive at the formula
t= γ(t' + vx'/c^2) ?
I know that you simply solve for t from the other formula, but I really cannot figure out how. Sorry, I realize this is more of a math-related problem, but I'm wondering if anybody can give me some tips? :smile:
hi blueberrynerd! :smile:
(try using the X2 icon just above the Reply box :wink:)
γvt = (γ2 - 1)x' + γvt'
t = (γ2 - 1)x'/γv + t' :smile:
(the https://www.physicsforums.com/library.php?do=view_item&itemid=19" is often easier to understand if you use the rapidity, α, defined by tanhα = v
then coshα = 1/√(1 - v2), sinhα = v/√(1 - v2), cosh2α - sinh2α = 1 :wink:)​
Oops, just a small mistake there. It should be
γvt = (γ2 - 1)x' + γ^2 vt'
t = (γ2 - 1)x'/γv + yt'
Using y = 1 / sqrt(1 - (v/c)^2), it can then be reduced further to
t = (y - 1 / y) x' / v + y t'
t / y = (1 - 1 / y^2) x' / v + t'
t / y = (1 - (1 - (v/c)^2)) x' / v + t'
t / y = x' v / c^2 + t'
t = y (t' + x' v / c^2)
Blueberrynerd,
This may be the easiest way. You start with this ...
. x = γ(x' + vt')
and since x = ct, then ...
. x = γ(x' + vt')
. ct = γ(x' + vt')
and t' = x'/c, so ...
. ct = γ(x' + vt')
. ct = γ(x' + v(x'/c)
and x' = ct', so ...
. ct = γ(x' + vx'/c)
. ct = γ(ct' + vx'/c)
dividing thru by c ...
. t = γ(t' + vx'/c2))
GrayGhost
GrayGhost said:
...and since x = ct, then ...
Er, why should that be? The Lorentz transform applies to all values of x and t, not just the subset you consider.
This reply is almost a month delayed, but THANK YOU! You helped a lot! :biggrin:
