Lorentz transformations in 2+1 and 3+1 dimensions
93 replies · 14K views · last reply
robwilson
[Mentors' note: This thead was forked from another thread - hence the reference to "these replies" in the first post]
I am wondering why all these replies only discuss Lorentz transformations in 1+1 spacetime dimensions. That is the easy bit. The problems in understanding arise in 2+1 dimensions, and even more so in 3+1 dimensions. I understand Lorentz transformations in 1+1 dimensions, where we are talking about 2 independent observers. I struggle in 2+1 dimensions, where we have three independent observers. In 3+1 dimensions, with four independent observers, I cannot make any sense of the Lorentz group. And I am a group theorist.
Yes, of course, I understand all that. As I said, I am a group theorist, so there is nothing you can tell me about coordinate systems for 4-dimensional spacetime that I don't already know. But no physicist has ever been able, or willing, to give me a real physical interpretation of the Lorentz group that makes sense.
Perhaps you should set out or reference an interpretation that doesn't make sense to you and explain what you see as its deficiencies.
It's all the possibilities for inertial reference frames: boosts, rotations; and, if you add translations you get the Poincare Group.
If I'm moving inertially relative to you, then my coordinates will be a Lorentz transformation of your coordinates. This can be defined by two physical parameters:
My velocity relative to you; and then I have the choice of orientation of my coordinate system.
I will, but not here, because it will get me banned. No-one has answered my original question, in any case. The group-theoretical problem is that from the one-dimensional Lorentz transformations it is impossible to infer what the two-dimensional group is. Therefore there is a physical assumption going into the process somewhere. It is a physical assumption about the nature of spacetime, and I'd like to know explicitly what it is. I have my own ideas, but this forum is not the place for me to expound on them.
It's in fact the proper orthochronous Poincare group, which determines not only Minkowski space-time as a physical space-time model but also a general framework to build the dynamical theories that describe the physical world. Together with the concept of locality, i.e., the field description of physics, which is the most natural description within a relativistic theory (note how problematic the concept of point particles in relativistic physics indeed is, not having a fully consistent dynamical theory for interacting relativistic point particles after about 120 years since Einstein's discovery of special relativity), to formulate dynamical models compatible with the space-time description based on this symmetry group.
Of course, which (quantum) field theories successfully describe the real world cannot be deduced from group-theoretical or mathematical considerations alone but you always need observations and experiments to get the right idea which models make sense and have a chance to stand experimental tests.
For a good introduction, particularly for a mathematician who already knows group theory very well but also for physicists who want a gentle but non-trivializing introduction to Lie-group-theoretical methods, see
R. U. Sexl and H. K. Urbantke, Relativity, Groups, Particles, Springer, Wien (2001).
Thank you for this reference and for your serious response. I think you understand, as I do, that the group, whatever it is, determines the model of spacetime, and what field theories are possible, and so on. And of course I agree that group theory cannot determine these things, which can only be determined by experiment. That is why I, as a group theorist, presented with data, look for the right group to describe the data. Since I know a lot of groups very well indeed, I have a large menu to choose from, and I can look at the problem in some depth. And over the years I have collected a lot of data from the literature. And the more I look at it, the more it doesn't seem to fit. For 45 years, since I first learned the theory of special relativity, I never once questioned the appropriateness of the Lorentz group. But it doesn't seem to fit the data. In 1+1 dimensions it works, as all the textbooks prove. In 2+1 dimensions it can be made to work, with a bit of persuasion. In 3+1 dimensions, I don't see it.
  • Skeptical
What do you mean by that "it doesn't seem to fit the data"? To the contrary the more we test special and general relativity with ever more precise measurements (and the measurment of time is among the most accurate measurements possible today having all the quantum-optics technology at hand) the more the relativistic space-time model is confirmed. There is not a single high-precision measurement contradicting the assumption of (local) Poincare symmetry.
Yes, that is correct. But all the tests are carried out in 2+1 spacetime.
I think it's safe to say that no experiment has ever been conducted in 2+1 spacetime!
  • Haha
You make a joke, which is fair enough. If you address the substance of my remarks, it would be more useful.
It's simple pragmatism on the part of the physicists, who often are interested in the math only to the extent that it is needed to effectively model the universe around them. As you say, the 1+1 case is easy - and that plus an assumption of isotropy, a coordinate rotation, and a wave of the hands is enough to work with problems in the locally flat space of special relativity.
Do you mean that you are a professional mathematician who specializes in group theory?
Or something else?
If we take the transformation of the Dirac electron as an example, with different representations of the Lorentz Group for the four-momentum and the spinor components, then there is a lot more than hand-waving going on.
Outside of elementary texts on SR, the 3+1 spacetime model is the default, and in the case of the electron spin can hardly be avoided.
I think the Dirac equation maybe takes us beyond the original question (although splitting the thread may have changed the question - the post you're quoting had originally been in the B-level thread and considering only classical particles). But yes, you make a good point if we're going to dig deeper.
I must confess that I don't understand this statement. Everything we do - including all tests - is carried out in the 3+1 spacetime in which we live, so I expect you meant something else here?
I think the gist of this thread is that the Lorentz Group only works in 1D (in some sense) and that physicists generally have never taken the trouble to look at the 3D group properly.
Your comment was somewhat unfortunate in that respect, I'm sorry to say!
Or something else?
Yes, that is what I mean.
What I meant was that the third dimension of space is not of the essence in the experiments. It may be that there are some experiments on SR that do essentially use the three dimensions, but if so I am not aware of them. My impression is that most experiments use only one or two space dimensions in an essential way. Some that do use three dimensions, which includes the neutrino oscillation experiments, and the kaon oscillation experiments, are in my opinion not well explained by the standard model.
At times, it seems that aspects that are seen in Special Relativity
are actually seen elsewhere.
(That is, it may not really be a "special relativity" problem that "special relativity" has to resolve.)
Sometimes, it may be helpful (as a "toy problem") to consider what happens in those other cases.
Specifically,
  • How does 2-dimensional Euclidean geometry generalize to 3-dimensional Euclidean geometry?
    ...possibly, first keeping the first direction invariant as one considers extensions to the "second dimension"
  • How does the 1+1 Galilean geometry of nonrelativistic physics along the x-direction
    generalize to 2+1 and 3+1 Galilean geometry to the xy-plane and to 3-d space?
These (Euclidean, Galilean, and Minkowskian) are examples of the Cayley-Klein affine geometries
https://en.wikipedia.org/wiki/Cayley–Klein_metric
which are related by an underlying projective geometry.
Possibly useful reference:
https://www.springer.com/gp/book/9783642172854
Perspectives on Projective Geometry
A Guided Tour Through Real and Complex Geometry
by
Jürgen Richter-Gebert
The most general Lorentz transformation can be represented as
$$\left(
\begin{array}{c|c}
\gamma & -\gamma \textbf{v}^T / c\\
\hline
-\gamma \textbf{v} / c & \textbf{I} + (\gamma - 1) \textbf{v} \textbf{v}^T / (\textbf{v}^T\textbf{v}) \\
\end{array}
\right)
\left(
\begin{array}{c|c}
1 & \textbf{0}^T \\
\hline
\textbf{0} & \textbf{U} \\
\end{array}
\right)
$$ where
  • ##\textbf{v}## is the velocity of one observer relative to another, as a 3×1 column vector
  • ##\gamma## is the usual Lorentz factor ##1 / \sqrt{1 - \textbf{v}^T\textbf{v} / c^2} ##
  • ##\textbf{U}## is any orthogonal 3×3 matrix, representing a rotation of one observer's spatial axes relative to the other
(You can verify it by considering the special case ##\textbf{v} = (v, 0, 0)^T##.)
That transformation represents a transformation between a pair of observers' coordinates. The whole group represents all possible transformations between pairs of observers, an infinite number of observers in total. I don't understand why you talk about 3 observers in 2+1 spacetime or 4 observers in 3+1 spacetime.
$$\left(
\begin{array}{c|c}
\hline
\end{array}
\right)
\left(
\begin{array}{c|c}
1 & \textbf{0}^T \\
\hline
\end{array}
\right)
$$ where
I'm sorry, I'm not expressing myself well. Observer 1 and observer 2 understand each other via Lorentz transformations. Observer 1 and observer 3 likewise. The problem is for observer 1 to understand how observer 2 and observer 3 see each other, without talking to both of them.
Of course, it is the electron spin that really points up the problem, although I didn't really want to get into all that. The action of the Lorentz group on the Dirac electron includes some variables that cannot be observed (e.g. spin direction), and does not include some variables that can be observed (e.g. generation). Plus the incompatibility of QM with GR is a serious mathematical problem, rather than a physical problem. But to sort out the mathematics, it is necessary to look at the experimental data with an uncluttered mind.
Specifically,
by
Yes, all this is true. The question is exactly as you say, how does the geometry generalise from 1 space dimension to 3 space dimensions. The examples you give are not the only possibilities.
If we denote the Lorentz transformation between observer ##n## and observer ##m## by ##\Lambda_{nm}## then the essential results are that
$$ \begin{align*}
\Lambda_{11} &= I \\
\Lambda_{12} \Lambda_{23} &= \Lambda_{13} \\
\Lambda_{12}^{-1} &= \Lambda_{21}
\end{align*} $$
So is your question really, what is the physical justification for this?
True. Issues like homogeneity and isotropy would restrict the possibilities.
But how you would answer
" How does 2-dimensional Euclidean geometry generalize to 3-dimensional Euclidean geometry? ".
DrGreg said:
If we denote the Lorentz transformation between observer n and observer m by Λnm then the essential results are that
$$ \begin{align*}
\Lambda_{11} &= I \
\end{align*} $$
It took me a while to put in the line breaks into your formulae, but then I have no problem with the first and third, it is the second one which needs justification. This is exactly the issue that I cannot resolve.
Apologies, there's a bug in the forum software that sometimes corrupts the LaTeX during composition and preview, I've now fixed my previous post.
Surely the second equation is an inevitable consequence of Einstein's first postulate? If you accept that, then are you looking for experimental justification of the first postulate?
This is a highly nontrivial question. If you did 2-dimensional Euclidean geometry at school, as I did, taught not quite from Euclid himself, but not far off, you will know that 3-dimensional Euclidean geometry was not taught. It is far too hard, and the generalisations are far from obvious.
Well, correct me if I'm wrong, but Einstein's first postulate seems to assume that if frame 1 and frame 2 are inertial with respect to each other, and frame 1 and frame 3 are inertial with respect to each other, then frame 2 and frame 3 are inertial with respect to each other. That isn't a mathematical theorem, so it must be a physical assumption.
