Low-Cost Object Detection System Using ESP32-CAM – Approach, Challenges
Danieldsouza
TL;DR
DIY ESP32-CAM object detection system using motion detection and lightweight processing. Covers setup, challenges like memory and false triggers, and practical optimizations, with a discussion on improving accuracy on constrained hardware.
Hello everyone,
I wanted to share a compact DIY project I’ve been working on recently—an object detection system using the ESP32-CAM module. The goal was to build something low-cost that can perform basic visual detection tasks without relying heavily on cloud processing.
Project Overview
https://www.handsontec.com/dataspecs/module/ESP32-CAM.pdf
The idea is to use the ESP32-CAM for:
  • Capturing images/video
  • Running lightweight object detection
  • Triggering an action (like LED, buzzer, or notification)
This is useful for:
  • Basic surveillance setups
  • Smart door monitoring
  • Entry/exit detection systems
Hardware Used
  • FTDI programmer (for uploading code)
  • ESP32-CAM module (OV2640 camera)
  • Optional: Buzzer / LED for alerts
  • Stable 5V power supply (important for reliability)
Working Principle
Since ESP32-CAM has limited processing power, full-scale ML models aren’t practical. Instead, I explored:
1. Basic Motion Detection
  • Frame differencing between consecutive images
  • Thresholding to detect changes
2. Lightweight Object Detection
  • Using pre-trained tiny models (where feasible)
  • Or offloading processing to a local server (optional hybrid approach)
3. Trigger Mechanism
  • If motion/object is detected → GPIO triggers output
Challenges Faced
Some practical issues I ran into:
Memory Constraints:
Running ML models directly is very limited
Power Stability:
ESP32-CAM is sensitive to voltage drops (caused random resets)
False Positives:
Lighting changes often triggered motion detection
Wi-Fi Latency:
Streaming or sending images can introduce delay
What Helped Improve Results
A few optimizations that made a noticeable difference:
  • Adding basic filtering for lighting variation
  • Using region-of-interest (ROI) instead of full-frame detection
  • External 5V regulated supply instead of FTDI power
  • Reducing frame resolution for faster processing
Possible Improvements
I’m currently exploring:
  • Integrating with a Raspberry Pi for edge processing
  • Using TensorFlow Lite Micro (very limited use cases)
  • Event-based image capture instead of continuous streaming
  • Better algorithms for distinguishing motion vs actual objects
Looking for Suggestions
I’d love to hear from the community:
  1. Any efficient object detection approaches for constrained devices?
  2. Better ways to reduce false positives in motion detection?
  3. Has anyone successfully deployed TinyML on ESP32-CAM in real scenarios?
This project is still evolving, but it’s been a great exercise in balancing hardware limitations vs functionality. Hopefully this helps someone working on similar low-cost vision systems.
Looking forward to your thoughts and suggestions!
