MHB How can we compare the lower envelope of a function with the function itself?
  • Thread starter Thread starter joypav
    Function
The discussion focuses on comparing the lower envelope function g of a real-valued function f defined on [a,b]. It establishes that g(x) is always less than or equal to f(x), with equality occurring if f is lower semi-continuous at x. Additionally, it is shown that if f is bounded, then g is also lower semi-continuous. The conversation also clarifies the notation used in the definition of g, emphasizing that g(x) can be expressed in terms of the infimum of f over a neighborhood around x. Overall, the relationship between g and f is crucial for understanding the properties of lower semi-continuity.
joypav
Problem:
Let f be a real-valued function defined on [a,b]. We define the lower envelope of f to be the function g defined by
$g(y) = sup_{\delta>0}inf_{\left| x-y \right|<\delta} f(x)$
(a) Show that for each $x \in [a,b]$, $g(x) \leq f(x)$ and $g(x) = f(x)$ if and only if f is lower semi-continuous at x.
(b) If f is bounded, then g is lower semi-continuous.
(c) If $\phi$ is any lower semi-continuous function such that $\phi(x) \leq f(x)$ for all $x \in [a,b]$, then $\phi(x) \leq g(x)$ for all $x \in [a,b]$.
Proof:
Part (a).
I am confused by the definition for the lower envelope. How do we compare g(x) and f(x)? I am confused about what x would be approaching in our definition for g(y), which is basically the liminf.
Part (b).
Let $\epsilon > 0$.
Then, $\exists \delta > 0$ such that,
$f(x) > g(x_0) + \epsilon$ for $x \in (x_0-\delta, x_0+\delta)$
Let $x \in (x_0-\delta, x_0+\delta)$ be given and let $n = \delta - \left| x-x_0 \right|$.
Then,
$g(x) = lim_{y \rightarrow x}inf f(y) \geq inf_{y \in (x_0-\delta, x_0+\delta)} f(y) \geq g(x_0) + \epsilon$
x arbitrary in $ (x_0-\delta, x_0+\delta) $
$\implies lim_{x\rightarrow x_0}inf g(x) \geq inf_{x \in (x_0-\delta, x_0+\delta)} g(x) \geq g(x_0) + \epsilon$
$\epsilon$ arbitrary
$\implies lim_{x\rightarrow x_0} g(x) \geq g(x_0)$.
Hi joypav,
I agree that it can be a bit confusing on how to compare $g(x)$ with $f(x)$, especially since we are using $y$ to define the function $g$ and $x$ as a dummy variable in $g$'s definition. Nevertheless, in order to match the notation of part (a), let's first make the changes $y \mapsto x$ and $x\mapsto t.$ Now $t$ is the dummy variable instead of $x$ so that $$g(x)=\sup_{\delta >0}\inf_{|t-x|<\delta}f(t).$$ Now, note that for each $\delta >0$, $$\inf_{|t-x|<\delta}f(t)\leq f(x), \qquad\qquad (*)$$ because $t=x$ will satisfy $|t-x|<\delta$ for all $\delta >0.$ Thus, since $(*)$ holds for all $\delta >0,$ $f(x)$ is an upper bound for the set $$\left\{\inf_{|t-x|<\delta} f(t):\delta >0\right\}.$$ Hence, $f(x)$ must be greater than or equal to the supremum over this set; i.e., $$g(x)\leq f(x).$$
  • · Replies 38 ·
