Lumped v. distributed parameter
Lumped and distributed parameters are two approaches to modeling electrical components. Lumped parameters simplify a system by combining all resistances and capacitances into single equivalent components, suitable for less complex models. In contrast, distributed parameters treat each small segment of a system, like a transmission line, as having its own resistance and capacitance, which is necessary for accurate modeling at high frequencies. For example, when the length of a cable is comparable to the wavelength of a signal, distributed parameters must be used to account for effects like standing waves. Understanding the distinction between these two approaches is crucial for effective modeling in electrical engineering.
Cyrus
This was mentioned casually in my controls book concerning differential equations.
Using simple english please describe to me what the two are. Please avoid any and all equations unless absolutely necessary.
Thanks!
When you have a long metal cylinder, each little bit of cylinder has some resistance and some resistance.
If you don't need a good model, you can lump all the little bits of resistance into one resistor, and all the little bits of capacitance into one capacitor. That's lumping.
If you need a really good model, then you should treat all the little bits of resistance and capacitance as little bits connected to each other. That's distributed.
Another example would be a transmission line of some sort, e.g. a cable.
If the cable is much shorter than the wavelength of the signal passing through it you can model the influence of the cable (e.g its attenuation) using lumped element parameters, i.e th impedance Z is a simple function of R, C, L and S.
However, if the frequency is so high that the length of the cable is of the same order of magnitude as the wavelength of the signal this obviously won't work, simply because phenomena like standing waves (and more generally impedance missmatch) etc become important.
You then have to use disitributed parameters to describe the cable and properites like the impedance is now a function of postion Z(x), i.e. the parameters are distributed.
I do not have a good working knowledge of physics yet. I tried to piece this together but after researching this, I couldn’t figure out the correct laws of physics to combine to develop a formula to answer this question. Ex. 1 - A moving object impacts a static object at a constant velocity. Ex. 2 - A moving object impacts a static object at the same velocity but is accelerating at the moment of impact. Assuming the mass of the objects is the same and the velocity at the moment of impact...
11K
9K
