Mach-Zehnder Interferometer interpretation
7 replies · 2K views · last reply
WWCY
HW Template missing as it was moved from another forum
Hi all,
I have a problem trying to interpret the mathematics of this experiment and would like some help. I think it's best I write out all my ideas (and misconceptions) so that I can be corrected. An illustration of the setup is below. Thanks in advance for any assistance!
Let the following vectors represent "right-moving" and "upwards-moving" states of photons respectively
$$|r> \ = (1,0)$$
$$|u> \ = (0,1)$$
A beam of photons purely in the "right" state enters the first beam-splitter (represented by the matrix) and exits in a mix of "r" and "u" states
$$\frac{1}{\sqrt{2}}
\left( \begin{array}{cc}
1 & 1 \\
-1 & 1
\end{array} \right)
1 \\
\end{array} \right)
= \frac{1}{\sqrt{2}} \big ( (1,0) + (0,-1) \big)
Assumption 1: ##\frac{1}{\sqrt{2}}(1,0)## represents the beam taking the right-wards path, and ##\frac{1}{\sqrt{2}}(0,-1)## is the beam moving upwards.
In the setup shown, both beams under go a "state-flip" as they hit the mirrors, and change direction and fly towards the second beam-splitter.
However, just for fun, I only want the "u" beam to hit a mirror, while the "r" beam just keeps flying right.
Assumption 2: I can do this by performing the "flip" on the "u" beam only. The "flipper" is represented by the matrix and the resulting state is
0 & 1 \\
-1 & 0
\end{array} \right)
0 \\
-\frac{1}{\sqrt{2}}
\end{array} \right)
= -\frac{1}{\sqrt{2}} (1,0)
Assumption 3: Because both my beams are now "r" states, the probability of finding them as "r" states should be a sweet 1. And thus, summing the two "r-wards" vectors should give me ##(1,0)##. But
$$\frac{1}{\sqrt{2}} \big[ (1,0) + (-1,0) \big] = 0$$
Assumption 4: I could remove the negative sign from the "u" state vector, since the sign plays no physical significance. But this gives me ##\frac{1}{\sqrt{2}}(2,0)## which does not make sense either.
Assistance is greatly appreciated!
First, if you want to compute a probability or generally "weigh" your states, you have to square amplitudes before adding them. Second, when the qubit your are focusing on (the direction) is part of a system with a second qubit (the position), you have to properly trace out the other qubit before adding. Otherwise you'll have problems.
For example, the state ##|0\rangle|0\rangle## looks fine, but apply a Hadamard gate to the second qubit and you get ##|0\rangle (\frac{1}{\sqrt{2}} |0\rangle + \frac{1}{\sqrt{2}} |1\rangle)##. If you simply ignore the second qubit, by replacing its kets with 1s, you'd get ##|0>(\frac{1}{\sqrt{2}} \cdot 1 + \frac{1}{\sqrt{2}} \cdot 1) = |0\rangle\cdot\sqrt{2}##. But that's nonsensical. You can't just ignore the second qubit by replacing its kets with the scalar 1! This is exactly what's happening in your example: the first qubit is the direction of the photon and the second qubit is the position of the photon.
To correctly remove the second qubit from the system you have to "trace it out". Convert your kets into density matrices, and http://www.thphy.uni-duesseldorf.de/~ls3/teaching/1515-QOQI/Additional/partial_trace.pdf. The resulting single-qubit density matrix tells you about the first qubit.
Hi @Strilanc , thank you for your reply!
Unfortunately I have really only just learned this formalism and I don't understand your post. If you don't mind, could you dumb it down for me?
Perhaps I should have mentioned that I only know stuff like representing states as vectors, transformations as matrices, and the idea that two-state systems can be described by this formalism. Apologies!
You don't have two photons in the state ##|r\rangle##. You have one photon in the state ##|r\rangle \otimes |\text{top path}\rangle## and one photon in the state ##|r\rangle \otimes |\text{bottom path}\rangle##. Your vector space needs to be four dimensional, not two dimensional, to account for both the direction and the path. In the larger four dimensional space, you will find that the two vectors no longer add up to zero.
So let's say I wish to perform some transformation on one of the paths, without performing it on the other, how should I go about doing it?
Also, may I know which one of my assumptions were faulty and how I should have approached them instead?
Thank you for your patience.
Hi all, I'd be grateful for some assistance regarding these concepts.
Either that or some advice regarding how I should restructure my post will be greatly appreciated!
