Magnetic field around an infinitely long wire
8 replies · 7K views
ehrenfest
Hello, I am trying to integrate
[tex]\int \mu_0 I (dl X r) /4 \pi r^2[/tex]
in order to get the magnetic field at a point a distance R from a wire with current I. r is the distance between the differential length and the point. I integrate over the entire wire (which becomes an angle from 0 to 2 pi).
I am off by a factor of 1/pi from the correct answer of of mu_0 I/2 pi R. Is my integral or my integration wrong?
Your integral is wrong... in the numerator it should be ([tex]\vec{dl}X\hat{r}[/tex])
[tex]\hat{r}[/tex] is different from [tex]\vec{r}[/tex]
[tex]\hat{r}[/tex] denotes a unit vector in the direction of [tex]\vec{r}[/tex]
You're right. That is what I meant. I still am off by the factor of 1/pi.
I tried to change to change it to an integral with respect to an angle and got:
[tex]\mu_0 I/4\pi \int_0^{2\pi} \sin \theta d\theta r/r^2[/tex]
Is that correct?
no why do u take the angle to be [tex]0[/tex] to [tex]2 \pi[/tex]
the angles should be [tex]\theta_{1}[/tex] to [tex]\theta_{2}[/tex] where tehse are the angles made by the wire's end points with point
in case of infinite wire they turn out to be [tex]\frac{\pi}{2},\frac{\pi}{2}[/tex] or
[tex]\frac{- \pi}{2},\frac{\pi}{2}[/tex] depending on how u integrate
Is that correct?
Are you mixing up the big R with the little r? If that is supposed to be r (which is varying) then the integral is wrong. And the limits should be 0 and pi.
I get [tex]\frac{\mu_0 I}{4\pi R}\int_0^{\pi} \sin \theta d\theta[/tex]
write everything in terms of R (which is constant) and [tex]\theta[/tex] and after taking all the constants outside, inside the integral you should just get [tex]sin(\theta)[/tex]
The way I did was setting:
x = -R/tan(theta)
calculate dx (which is dl) in terms of d(theta)
also set r = R/sin(theta)
For some reason latex is messing up for me.
[/tex]
[tex]x = \frac{-R}{tan theta}[/tex]
calculate dx (which is dl) in terms of [tex]d \theta[/tex] set [tex]r = \frac{R}{sin\theta}[/tex].
OK. So my integral should be
[tex]\int \mu_0 I (dl X r) /4 \pi r^2[/tex] = [tex]\int \mu_0 I sin(\theta)dl r /4 \pi r^2[/tex]
I just had a dtheta instead of a dl.
I am confused about your solution. I am not sure why you introduced x. Anyway I get with your trig substitution,
dx = R csc^2(x) dtheta
then all the sines cancel!
There shouldn't be an r in the numerator for the fraction on the right. I think that's what's causing the trouble.
There shouldn't be an r in the numerator. I think that's what's causing the trouble.
YES! Because r-hat is the unit vector. I see. Thanks.
