Magnetic field caused by one Electron ?
This discussion focuses on the magnetic field generated by a moving electron and its intrinsic magnetic dipole moment due to spin. The Biot-Savart law is applicable for calculating the magnetic field of a point charge, with the equation B = (μ0/4π) * (ids Sinθ/r²) being relevant for current elements. For a uniformly moving charge, the electric and magnetic fields can be derived using Lorentz transformations. The electron's intrinsic magnetic dipole moment is a quantum-mechanical property, which complicates its integration into classical magnetic field equations.
  • Understanding of Biot-Savart law
  • Familiarity with Lorentz transformations
  • Knowledge of intrinsic magnetic dipole moments
  • Basic principles of electromagnetism
  • Study the application of Biot-Savart law for point charges
  • Learn about Lorentz transformations in electromagnetism
  • Research the quantum mechanics of electron spin and magnetic dipole moments
  • Explore the relationship between electric flux and magnetic fields in dynamic systems
Physicists, electrical engineers, and students studying electromagnetism and quantum mechanics will benefit from this discussion, particularly those interested in the behavior of electrons in magnetic fields.
Mahbod|Druid
Hi
I have read Bio-Savar , Amper law (also maxwell) about Magnetic fields
but all of them had I
bio-savar :
B = \frac{\mu<sub>0</sub>}{4\pi<br /> } \frac{ids Sin\theta}{r<sup>2</sup>}
Amper :
\int B.ds = Iin \mu0
but what about a Electron moving in a line path ? how big will be its magnetic field ? it musnt be permenent though
and what about a Electron spining around itself ? this time it must be permenant but how big what are the vectors ?
Thanks
You can still use the Biot-Savart law for a point charge. You just replace the current with the appropriate equivalence. I think the wikipedia article has the equation:
http://en.wikipedia.org/wiki/Biot-Savart_law
That's for constant non-relativistic velocity though. I can't remember the equation for an arbitrary path/velocity.
For a uniformly moving charge, you can calculate the E and B fields by starting with the E field for a stationary charge, and performing a Lorentz transformation:
http://farside.ph.utexas.edu/teaching/em/lectures/node125.html
The electron has a fixed intrinsic magnetic dipole moment, but the "spin" that it arises from is quantum-mechanical in nature.
http://hyperphysics.phy-astr.gsu.edu/Hbase/spin.html
I'm not sure how much sense it makes to insert this dipole moment into the equations for the field of a magnetic dipole, because of its small size.
http://scienceworld.wolfram.com/physics/MagneticDipole.html
I'm pretty sure the moving electron gives you exactly the type of field you get from the infinitesimal current element of Boit-Savart. You can set up a loop anywhere along the axis of symmetry and there will be a rate of increase of electric flux through this loop. The magnetic field integrated around the loop (constant field x 2pi*r) is equal to the increase of electric flux.
  • · Replies 21 ·
  • · Replies 18 ·
