Magnetic Field Intensity Question
The discussion centers on calculating magnetic field intensity around a cylindrical conductor and an outer shell conductor with opposing currents. The inner conductor has a radius 'a', while the outer shell extends from radius 'b' to 'c'. Participants clarify that in regions where only one conductor exists, only the current from that conductor should be considered. In the free space region (a < ρ < b), only the inner conductor's current affects the magnetic field intensity, while outside the outer shell (ρ > c), the net magnetic field intensity is zero due to equal and opposite currents.
  • Understanding of Ampère's Law
  • Familiarity with the principle of superposition in electromagnetism
  • Knowledge of cylindrical coordinates in magnetic field calculations
  • Basic concepts of electric current and magnetic fields
  • Study Ampère's Law and its applications in cylindrical geometries
  • Research the principle of superposition in electromagnetic fields
  • Learn how to calculate magnetic field intensity using Biot-Savart Law
  • Explore examples of magnetic field calculations in multi-conductor systems
Students studying electromagnetism, electrical engineers, and anyone involved in calculating magnetic fields in cylindrical conductor systems.
sillucius
This is for an assignment that is due next Monday for me. I'm kind of confused here for how to calculate the magnetic field intensity at all points for the conductor(s) in the diagram I have attached. First, there is a cylindrical conductor of radius a, then surrounding it is another conductor from radius b to c. They call this the outer shell. The question also states that there is a current, I, flowing in the inner conductor and outter conductor but in opposite directions. I have an idea for how to do this, but there are still a lot of things I can't figure out.
Firstly, how does the current effect each region? In the regions where there is only a conductor (ρ > a and b < ρ < c), do I only consider the current by the one conductor? For example, would the conductor of radius a's current affect the magnetic field intensity where ρ is in the conductor between radius b and c? And oppositely, would the current of the outter shell's conductor effect the magnetic field intensity of the inner conductor?
Also, for the region where a < ρ < b, where it's free space, do both conductors affect the magnetic field intensity in this region? Or just the inner conductor?
And on the outside, where ρ > c, would the magnetic field intensity be 0? I'm guessing because because I think the net current be 0 since the current are in equal but in opposite directions in the conductors, however I am not too confident in my answer.
I know this is quite lengthy, but the book I am using doesn't offer much insight into this question. Any help would be greatly appreciated, thanks.
sillucius,
Think about electric current, the magnetic filed it creates, and the line integral of that magnetic field around a closed loop.
Does that help?
Oh, I know how to do the calculations themselves and derive the equations for Magnetic Field Intensity. It's just that I don't know exactly how the current will affect each region. Like in between region a < ρ < b, does the current from both conductors affect it, or just one?
sillucius,
What does the principle of superposition say about the field from two sources?
i believe at a< p <b you would only consider the inside current, since for everything we seem to use the current enclosed. so i would also guess at p>c the net current enclosed would be 0. I'm just not sure what to do to get the current enclosed...
  • · Replies 40 ·
  • · Replies 23 ·
