Magnetic Field of A Straight Conductor
The discussion focuses on calculating the magnetic field generated by a straight conductor carrying a current of 400 Amps, positioned 5.0 meters above the ground. The magnetic field at a point directly beneath the conductor is calculated using the formula B=(μ₀I)/(2πr), resulting in a value of 1.60x10^-5 Teslas directed into the plane of the paper. Additionally, it is concluded that the Earth's magnetic field, approximately 0.5 x 10^-4 Teslas, is significantly stronger than the field produced by the conductor, indicating that the current does not substantially affect compass readings.
  • Understanding of magnetic fields and their calculations
  • Familiarity with the formula for the magnetic field of a straight conductor
  • Knowledge of permeability of free space (μ₀)
  • Basic concepts of vector addition in physics
  • Study the derivation and applications of the magnetic field formula B=(μ₀I)/(2πr)
  • Learn about vector addition and how to calculate resultant magnetic fields
  • Explore the effects of nearby magnetic fields on compass readings
  • Investigate the properties of Earth's magnetic field and its variations
Physics students, electrical engineers, and anyone interested in electromagnetism and its practical applications in navigation and compass accuracy.
shikagami
Here is a problem that I don't quite understand.
P: Two hikers are reading a compass under an overhead transmission line that is 5.0 meters above the ground and carries a current of 400 Amps in a direction from south to north.
a. Find the magnitude and direction of the magnetic field at a point on the ground directly under the conductor.
b. One hiker suggests they walk on another 50 meters to avoid inaccurate compass readings caused by the current. Considering that the magnitude of the Earth's field is of the order of 0.5 x 10^-4 Teslas, is the current really a problem?
Here is how I did it:
For part A I figured I should find the permeability by the formula (k'=Mo/4pi). After finding Mo (1.26x10^-6 N/A^2), I used the formula for a magnetic field of a straight wire [B=(MoI)/(2 (pi) r)]. I got 1.60x10^-5 Teslas for the magnetic field going into the plane of the paper.
For part B I said that since the Earth's magnitude is much bigger than that of the conductor that the conductor will not cause a significant problem to the accuracy of the compass readings.
Are any of my solutions right? Is there a mathematical way to prove part B?
i see nothing about a sheet of paper in the problem.
The mathematical way to handle part B, is to find the resultant field vector, and find its angle. This angle will tell you how wrong the hikers may have gotten.
The current have a magnetic field associated with it, try finding the proper formula. What will the unit vector be? You'll probably need to also consider the magnitude and direction of the Earth's magnetic field
for b, you'll need to find the new r value
feel free to ask further questions
  • · Replies 40 ·
  • · Replies 20 ·
