What are the effects of gyromotion on changing magnetic fields?
The discussion centers on the effects of gyromotion on changing magnetic fields, specifically regarding electron beams and magnets entering coils. When an electron beam is injected perpendicular to a magnetic field, the Lorentz force causes the electrons to revolve, leading to oscillations in the magnetic field strength due to the gyroradius changes. This phenomenon is also observed when a magnet moves into a coil, where Lenz's law applies, resulting in a counter electromotive force (emf) that opposes the change in magnetic flux. The conversation highlights the importance of understanding these interactions to clarify misconceptions about magnetic field behavior.
  • Understanding of Lorentz force and its effects on charged particles
  • Familiarity with Lenz's law and Faraday's Law of electromagnetic induction
  • Knowledge of gyroradius in the context of charged particle motion
  • Basic principles of electromagnetism and magnetic fields
  • Study the mathematical derivation of Lorentz force and its implications on electron motion
  • Explore Lenz's law in depth, particularly its applications in electromagnetic systems
  • Investigate the concept of gyroradius and its significance in plasma physics
  • Examine the relationship between induced emf and changing magnetic fields through practical experiments
Physicists, electrical engineers, and students studying electromagnetism who seek to deepen their understanding of magnetic field interactions and their implications in various applications.
TESL@
Hello,
I am stuck with this problem:
An electron beam is injected perpendicular to a magnetic field. The electrons feel Lorentz force and start to revolve. This movement reduces the magnetic field, therefore the gyroradius gets higher, which in turn increases the magnetic field again. So the electrons again get closer, and they keep oscillating. This seems wrong. I have probably made a wrong assumption.
This also applies to a magnet entering a coil. As the magnetic field strength increases inside the coil, a current is driven "resisting" the increment. So does the field strength remain zero (the magnet is still moving), drop to a constant value, or oscillate like I mentioned above?
Thank you.
up!
TESL@ said:
Hello,
There would be some equilibrium. An electric current produces it's own magnetic field. One could calculate a magnetic field due the current of an electron beam and compare the induced field with the applied/imposed external field.
Thank you.
Lenz's law applies to a magnet moving into a coil (solenoid). There would be backward emf, or counter emf due to the magnetic field of the solenoid current.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/farlaw.html#c2
When an emf is generated by a change in magnetic flux according to Faraday's Law, the polarity of the induced emf is such that it produces a current whose magnetic field opposes the change which produces it.
Thanks Astronuc.
  • · Replies 42 ·
  • · Replies 20 ·
  • · Replies 17 ·
13K
