Magnitude of change in linear momentum
The discussion focuses on calculating the magnitude of change in linear momentum for a 0.70 kg ball that strikes a wall while moving at 9.6 m/s and rebounds at 1.3 m/s. The correct formula used is Δp = mv(f) - mv(i). The initial momentum (mv(i)) is 6.72 kg·m/s and the final momentum (mv(f)) is -0.91 kg·m/s, leading to a change in momentum of -7.63 kg·m/s. The magnitude of the change is 7.63 kg·m/s, confirming that the answer is positive as it represents magnitude.
  • Understanding of linear momentum concepts
  • Familiarity with the formula Δp = mv(f) - mv(i)
  • Knowledge of vector direction in physics
  • Basic algebra for solving equations
  • Review the concept of momentum conservation in collisions
  • Explore vector addition and subtraction in physics
  • Learn about elastic and inelastic collisions
  • Study examples of momentum change in different scenarios
Students studying physics, particularly those focusing on mechanics and momentum, as well as educators looking for practical examples of momentum calculations.
studypersist
A 0.70 kg ball is moving horizontally with speed of 9.6 m/s when it strikes a vertical wall. The ball rebounds with speed of 1.3 m/s. What is the magnitude of the change in linear momentum of the ball?
Dp = mv(f) - mv(i)
I solved for mv(f) and mv(i). Solved for Dp which I got -5.81 which is wrong.
Hint: The initial and final velocities point in opposite directions.
-.91 - 6.72 = -7.63
Is the answer positive because magnitude is positive?
That is correct.
  • · Replies 19 ·
