Which Collision Results in Greater Momentum and Energy Loss?
  • Thread starter Thread starter justagirl
    Magnitude Momentum
The discussion analyzes two collision scenarios involving two identical mass carts to determine which results in greater momentum and energy loss. In the first scenario, cart A, starting at height h, collides with stationary cart B, resulting in a combined momentum that is non-zero. In the second scenario, both carts start at height h/2 and collide after falling in opposite directions, resulting in zero total momentum due to vector addition. The mechanical energy loss is greater in case 2, as all mechanical energy is converted to heat when the carts become stationary after the collision.
  • Understanding of momentum as a vector quantity
  • Knowledge of mechanical energy concepts, including potential and kinetic energy
  • Familiarity with conservation laws in physics
  • Basic principles of collisions in classical mechanics
  • Study vector addition in momentum calculations
  • Explore the conservation of mechanical energy in different collision types
  • Investigate the effects of inelastic collisions on energy loss
  • Learn about the principles of energy transformation during collisions
Physics students, educators, and anyone interested in understanding the principles of momentum and energy conservation in collision scenarios.
justagirl
Say there was 2 collisions. There are 2 carts of identical mass. In the first case cart A starts at height h above the ground and crashes into cart B which is stationary on the flat ground. They stick together.
In the second case, cart A starts at height h/2 above the ground, cart B starts at height h/2 above on the ground on the other side. They fall in opposite directions and collide and stick together.
The problem asks that when the carts reach the flat ground, in which case is the magnitude of the total momentum greater.
When they ask about the magnitude, in case 2, should the momentum be
M(a)V(a) + M(b)V(b) = 2M(a)V(a) (which would be greater than case 1), or should I factor in the fact that they are traveling in opposite directions, in which case the total momentum would be zero?
The second question asks whether the total energy lost in greater in case 1 or case 2. The energy lost would be greater in case 2 if the momentum was 2M(a)V(a)... but then again this goes to question 1.
Thanks!
At the time of writing, this is a 17+ year old question. So I'm giving a fairly complete answer/explanation.
You must account for the opposite directions. The total momentum for case-2 is therefore zero. That's because momenta are vectors; they must be added as vectors. (If the magnitude of the resultant is needed, this is found after the vector-addition.)
That means forcase-2, the carts (now stuck together) will end-up stationary. You can reach the same conclusion by thinking about symmetry. There is no preferred direction of motion for the combined carts in case-2.
This is badly worded (or maybe a trick) question. Energy is always conserved. So the total energy loss in both cases is zero.
However, the question was probably intended to be about loss of mechanical energy (ME). Mechanical energy is potential energy + kinetic energy.
In both cases, the starting ME is the same:
- for case-1 it is mgh+ 0 = mgh
- for case-2 it is mg(h/2) + mg(h/2) = mgh
In case-2 all the ME is lost, as the carts end-up stationary. (The ME gets entirely converted to heat (and maybe a little sound energy) as a result of the collision.)
In case 1, the stuck-together cars are still moving. So not all of the ME has been converted to heat.
So the loss of ME is greater in case 2.
  • · Replies 32 ·
  • · Replies 40 ·
  • · Replies 24 ·
