Majorana Neutrinos: Different Physics than Oscillation
  • Context: Undergrad
  • Thread starter Thread starter Vanadium 50
    Majorana Neutrinos
The discussion revolves around the concept of Majorana neutrinos and their distinction from neutrino oscillations. Participants explore the implications of Majorana mass terms, the nature of neutrinos as potential Majorana particles, and the historical context of Majorana's work in particle physics.
  • Some participants assert that a Majorana mass term represents fundamentally different physics than neutrino oscillations or the idea of neutrinos and antineutrinos being the same particle.
  • Others propose that if neutrinos are indeed Majorana particles, they would be their own antiparticles, raising questions about how this could occur without self-annihilation.
  • One participant mentions that photons are known to be their own antiparticles, suggesting a precedent for such behavior in other particles.
  • There is a discussion about the historical context of Majorana's postulations regarding fermions and whether there is a specific reason for considering fermions as potential self-antiparticles.
  • Some participants highlight the complexities of the Standard Model, noting that neutrinos are treated as Dirac fermions and thus not their own antiparticles under current understanding.
  • A later reply emphasizes the need for clarity in distinguishing between Majorana mass terms and neutrino oscillations, suggesting that the confusion arises from misinterpretations of earlier statements.
  • Concerns are raised about the sensitivity of detectors to neutrinos versus antineutrinos, with implications for the interpretation of historical supernova observations.
Participants express differing views on the nature of Majorana neutrinos and the implications of their properties. There is no consensus on whether neutrinos can be classified as Majorana particles or the significance of this classification in relation to oscillation phenomena.
Participants note that the discussion has diverged from the original topic of neutrino oscillations, leading to a suggestion for a more focused discussion in a different subforum. Additionally, the historical context of Majorana's work is acknowledged, with references to the limitations of the Standard Model in accommodating Majorana mass terms.
  • #151
PeterDonis said:
"Tiny" as in "none has yet been measured", correct? I.e., this is an experimental constraint.
I think "hopeless"m, as @vanhees71 called it is more appropriet.
Because an actual physical beam is not pure, you find yourself looking for a part per zillion effect on top of a percent-level effect. If a paper published, "We expected the bean to be 98% neutrinos but it's actually only 97.99999999%. Discovery!" would that be credible? I think not.
  • #152
Eventually it might be if detection technology advanced far enough. We already know of some theoretical predictions that have been confirmed to 13 or 14 decimal places.
  • #153
It's not a technology issue. It's physics.
Neutrino beamlines work by takint a beam of pions, letting them decay to muons (which live ~100x longer) and neutrinos, and then stopping the muons. The problem is that they only live 100x longer, so ~1% of the time they decay in the same volume as the pion. Muons give neutrinos of the opposite sign than pions., If I make the decay pipe shorter by a factor or 2, I reducxe the numbers of muons that decay by a factor of 2, but I also reduce the number of pions that decay by a factor of 2, so the contamination is pretty much constant.
Furthermore, the highhest rate neutrino detector proposed is the DUNE near detector, which will say a few million events per day. That's with a beam power of over a megawatt. If you want to see a 10-9 effect, you need 1018 events to do it. Run for a year means terawatt scale beams, Not only does nobody know how to do this, not only does the target magically need to survive this much power without evaporating, not only would it take up all the US electrical production capacity and then some, but this is probably optimistic by several orders of magnitude.
This is what drives people to giant underground tanks of xenon.
  • #154
PeterDonis said:
This is misstating things. Consider the simplest Feynman diagram for, say, electron-positron annihilation. How many electron/positron lines does it have? The answer is not two. It's one. The ingoing electron and ingoing positron lines are the same line. (Inside the diagram, if we are considering annihilation in isolation with no other particles present, this single line passes through two vertices that have photon lines; those are the outgoing photon lines. But it's the same, single electron/positron line all the way through.)
You could, in principle, have a "neutrino annihilation" diagram that worked the same way (although the lines coming out could not be photon lines, since neutrinos are uncharged; I think you could do it with Z bosons), and that would be true regardless of whether neutrinos turn out to be Majorana or Dirac fermions; it would be the same diagram in either case. In short, this type of diagram doesn't care about the Majorana/Dirac distinction, and can't tell you anything useful about it.
I take your point, but I think the key issue is what the leftward and rightward parts of that single neutrino line connect to. That's what distinguishes the electron/positron side of the diagram you describe, from the photon/photon side. In other words, the reason we take your diagram and decide we have a positron and electron on one side is the need to change charge, which changes the behaviors at the two ends of that line, whereas the photon side doesn't need that. But neutrinos also don't need to change charge, so we would need some other reason to decide we need to call them a neutrino and an antineutrino. That seems to be the crux of the matter-- if the processes that those ends of the neutrino line connect to can be the same process, as can be true for the photons on the other side of the diagram, then that's what I mean by "annihilating with another particle like itself." That's what happens in neutrinoless double beta decay, the two beta decays that "anchor" the ends of the neutrino line you are describing are exactly the same process, so there's no need to say the neutrino turns into an antineutrino when it emerges from those vertices.
So even though that process is very rare, it is a process that requires the neutrinos not be interpreted as neutrino/antineutrino, whereas there is no process that requires they do be interpreted that way. In fact, maybe we've been going about this all wrong-- we've been asking for the Majorana neutrino camp to show an experiment that proves neutrinos are Majorana particles. Why have we not asked the Dirac neutrino camp to show an experiment that proves they are Dirac particles? Again the aether analogy comes to mind-- SR did not come from an experiment that tried to show there wasn't an aether, it came from an experiment that tried to show that the aether that was widely being assumed was there was actually there-- and failed to do so. If someone would claim there is such a thing as an antineutrino, let them design an experiment that proves such a particle exists, and if they fail to do so enough times, eventually we say "I guess we don't need the idea after all."
  • #155
They don't connect to anything. They are the two incoming external legs.
That automatically gets taken care of because, since they are the two incoming external legs, the two ends of the same line must be CPT conjugates (since they're the same line). It doesn't matter what quantum numbers (if any) the CPT conjugation changes.
It doesn't need "that" because the two outgoing photon external lines are not the same line. They are photon lines coming from two different vertices inside the diagram and they never connect to each other. So they aren't the same as the external electron lines.
This can't possibly be the "crux" of the matter because it is true for the electron annihilation diagram: both vertices that the single electron line goes through are the same process--the same kind of vertex. So you can't distinguish between electrons and neutrinos this way.
  • #156
Just to be clear, here is the electron-positron annihilation Feynman diagram I have been describing:
  • #157
I know, I mean the way you define what those particles are is all the processes they could connect to. You just label the lines, but that's what the label implies-- all those processes left off the end.
It matters to the labels of the lines, that are the implied particles-- they have those quantum numbers. What we are deciding is whether it is necessary (given current observations), or even makes sense (in the case of future neutrinoless double beta decay), to label one of the lines as a particle and the other an antiparticle in the case where a diagram like that would apply to neutrinos.
Ah, I had not appreciated the subtlety that the central line is attributed to the electron/positron and not to the photon. I presume because the electron/positron has rest mass so if we go into the COM frame, we see something there that is kind of instantaneously stationary, though I'm not quite sure what that "thing" is that corresponds to that central line! But all I mean is that the photon lines are not labeled photon and antiphoton because there are no processes that connect to the ends of the photon lines, and define those labels, that require or can even define that distinction.
It's not the vertices in the diagram I'm talking about, it's the hypothetical vertices left off the ends of the lines that define the meaning of those particles, the meaning of the labels that go with the lines. That's what is different for the electrons and positrons, they spiral in different directions about magnetic fields and so on. But that's what would not be different for Majorana neutrinos, if they both come from precisely the same process like beta decays.
  • #158
It's because QED (and a fortiori the Standard Model) has a vertex with two electron legs (one with the arrow pointing into the vertex and one with the arrow pointing out) and one photon leg, but does not have a vertex with two photon legs and one electron leg.
This would be equally true for a massless fermion interacting with a massless boson. The constraint is not the fermion having nonzero rest mass but the kinds of vertices that can occur in a Lorentz invariant Lagrangian.
  • #159
The "meaning" of the particles isn't defined by hypothetical vertices, it's defined by what asymptotic free particle states exist in the theory. For both electrons and neutrinos, these will be mass eigenstates. For electrons we know these are Dirac mass eigenstates. For neutrinos, what kind of states they are will depend on how the question of whether neutrino masses are Dirac or Majorana is finally resolved.
  • #160
Ok thanks, fair enough.
  • #161
But what can that possibly mean other than the types of vertices those states can participate in? What else could possibly define a theoretical construct that can only make its presence felt by what it interacts with, in any empirical science? The reason I'm bringing this up is it is essential to the empirical meaning of any concept of an "antineutrino." I can call it "Bob", but if it does not have specific interactions that define its meaning, it's just a word. Same for the theory that describes the free states-- more words and equations that are a mathematical game unless they have interactions that can be tracked and observed. That's what I mean by "hypothetical vertices at the ends of the lines", the things that make this a testable science-- crucial for the issue of what it means to claim "antineutrinos exist."
Precisely, which is why I pointed out that it is odd the Majorana camp is being asked to serve up neutrinoless double beta decay, but the Dirac camp has been presented with no equivalent challenge. It seems there is no way at all to test that neutrinos are of Dirac nature, which is already a significant problem in an empirical science. In other words, it's worse than saying the Majorana interpretation requires observing a rare event, we have the Dirac interpretation with no observation to point to at all!
Normally we adjudicate such issues using Occam's Razor, so we attach no unnecessary parts to a theory. That's why there is no aether any more, not that observations showed it doesn't exist, but observations did not require it. It's hard for me to see the concept of an antineutrino, instead of merely a chiral state of a neutrino, in that exact same light. Hence my analogy with left- and right-circularly polarized photons having no reason to be considered as photons and antiphotons. (I realize the neutrino physics is more complicated, but it's an analogy.)
  • #162
I believe @vanhees71 explained that in a post a while back.
  • #163
One of the papers linked to in the thread, IIRC, described experimental tests that could only be passed by Dirac neutrinos.
  • #164
OK, good to know such tests exist. If such tests are conducted, and the neutrinos don't pass, I presume there will be a tendency to become skeptical of the "antineutrino" concept-- with no damage to QM or SR or supernova theory.
  • #165
Any explanation based on theory is of course just going to trace right back to what I'm talking about-- the vertices are the experiments that tested the theory. This is just science. If I'm not being clear, let me put it another way: where is the experimental apparatus in the Feynman diagram? Of course it would be unwieldy to include them, but they must certainly be implied, or there is no test of the theory included in the theory.
  • #166
As in the early days of neutrino observations, in the early-mid 1950ies, the way to proceed is to write down the most general effective theory and then figure out, how to test the parameters with dedicated experiments.
The history of the neutrino is pretty interesting and paradigmatic for how research in physics and the interplay between theory and experiment works. In 1930 Pauli stated the neutrino hypothesis in an informal letter to some people attending a conference on ##\beta## decay, which was quite a riddle in these days. One must remember that the neutron wasn't discovered yet, and there where ideas around that a nucleus consists of protons and electrons, and the electrons come out somehow, leading to ##\beta## decay. That didn't work out, because the electrons had a continuous spectrum and not a line spectrum you'd expect from electrons somehow bound within the nuclei.
Then in 1934 Fermi came up with his QFT for neutrinos, and in these days it was clear that parity had to be conserved. He could explain the ##\beta## spectrum by assuming a three-body decay.
Then more and more details about neutrino interactions were discovered, and the picture of the original Fermi theory didn't fit anymore. There also also the famous "##\theta \tau## puzzle". There were apparently two particles called ##\theta## and ##\tau## which looked pretty much the same except that one decayed to 2 pions, the other to 3 pions. The resolution was the hypothesis that in fact there's only one particle, which we call ##\text{K}^+## today, which decays in both channels, ##2 \pi## (parity even) and ##3 \pi## (parity odd), and that implies the violation of parity conservation, i.e., the invariance under space reflection must be broken by the weak interaction.
This opened the way to adapt the theory. Feynman and Gell-Mann wrote down the most general Lagrangian with all kinds of couplings of neutrinos and antineutrinos. Experimentalists, as always with neutrinos, had a hard time to figure out, which coupling is right. A while the situation was pretty ambigous, but after some time the famous "vector-minus-axial-vector coupling", i.e., maximal violation of chiral symmetry with purely left-handed neutrinos (right-handed anti-neutrinos) turned out to be right, and the parity violation was established, e.g., by the Wu experiment, leading to one of the quickest Nobel prizes in history for Lee and Yang just one year after the experimental discovery.
Then in the mid 60ies the Standard Model started to take its so far final form, with the neutrinos conjectured to be massless and the assumption of lepton-number conservation with only left-handed neutrinos and the charge-conjugated neutrino being distinguished from the neutrino by lepton number (+1 for neutrinos, -1 for antineutrinos).
This, however lead to the famous "solar-neutrino puzzle", which lasted for decades, until in the 1990ies neutrino-flavor oscillations have been discovered, leading to the conclusion that neutrinos must have a non-zero mass and that there must be flavor-mixing matrix.
The question today is, whether the neutrinos are Dirac fermions with the corresponding mass terms and there's a conserved lepton number. Then with the weak coupling being strictly V-A, still only left-handed neutrinos (and right-handed anti-neutrinos) are interacting, and the right-handed parts which are coupled to the game solely by the Dirac masses are in this sense "sterile neutrinos".
The other possibility is that lepton number is not conserved and that the charge conjugated neutrinos are identical with the neutrinos, i.e., that the only difference in the neutrino and the charge-conjugated "anti-neutrinos" is their chirality. The masses are then given by the Majorana mass terms, which violates lepton-number conservation and with the possibility of "neutrino-less double ##\beta## decay", which seems to be considered the most promising way to discover that neutrinos are Majorana particles. This picture has the appealing effect that there are no "sterile neutrinos". Just recently the hints at sterile neutrinos in various neutrino experiments seem to get weakter again, and maybe that's a hint that maybe after all the neutrinos might be Majorana fermions.
Finally there's also the possibility to have both, Dirac and Majorana mass terms. Then lepton number is not conserved but there are sterile right-handed neutrinos.
It's clear that the question, which is the right neutrino model is still open!
  • #167
Vanadium 50 said:
You did, but...
I don't think this is right. Go back to the Weyl fields:
$$C | \psi_L> = \overline{\psi_L} \neq \psi_R $$
I would say it is nothing uncer C or at least sterile.
Let's follow Coleman's lectures, which are most lucid on this topic.
The most simple way to treat Majorana Fermions is to use a Majorana representation of the ##\gamma## matrices, which are then purely imaginary, i.e., ##\gamma^{\mu *}=-\gamma^{\mu}## (where the star of a matrix means just take the conjugate complex values of its matrix elements) Then charge conjugation is given simply by ##\psi^c=\psi^*##, where the star on the field operator means to just take the conjugate complex of the entries in the operator-valued column spinor, i.e., ##\psi^*=\psi^{\dagger \text{T}}##.
Then obviously the free Dirac equation is invariant under charge conjugation, and the corresponding unitary charge-conjugation operator maps particle annihilation operators to antiparticle-annihilation operators and vice versa, and the same holds for the creation operators. By definition the vacuum state is invariant under ##C##.
Now since the ##\gamma^{\mu}## are purely imaginary matrices, ##\gamma_5=\mathrm{i} \gamma^0 \gamma^1 \gamma^2 \gamma^3## is also purely imaginary. Now
$$\psi_L=\frac{1}{2}(1-\gamma_5) \psi$$
and
$$\psi_L^c=\psi_L^* = \frac{1}{2} (1-\gamma^5)^* \psi^*=\frac{1}{2} (1+\gamma^5) \psi^*,$$
i.e., it is right-handed.
A Majorana fermion is now a fermion with mass, i.e., it must have both left- and right-handed components, i.e., it's not a Weyl field. A Majorana fermion is its own charge-conjugated state, i.e., ##\psi^c=\psi^*=\psi##. So you can represent it by a left-handed Weyl spinor, ##\chi_L## and write
$$\psi=\chi_L+\chi_L^c=\chi_L+\chi_L^*,$$
and ##\chi_L^*## is a right-handed Weyl spinor (note that I work in a Majorana representation of the Dirac matrices).
A very nice paper, working out all the features of Weyl, Dirac, and Majorana fermions, is
https://arxiv.org/abs/1006.1718
https://doi.org/10.1119/1.3549729
  • #168
Ken G said:
Perhaps one additional point to stress: transformations that normally turn particles into their antiparticles turn the Majorana neutrino into the identical state, just as for photons. So one could not say that neutrinos have one chirality and antineutrinos have another, because there would be no such thing as antineutrinos, there are just two different chiral eigenstates.
Note that for photons ##A^{\mu c}=-A^{\mu}## in order to make QED C invariant.
Ken G said:
Not sure what this means. Since pure Majorana neutrinos have zero lepton number, or no lepton number which seems like more or less the same thing, when an electron strikes a proton and makes a neutron and a Majorana neutrino, which is involved in neutronization in supernovae, lepton number violation is dramatic to say the least.
So it sounds like the answer to how they know to make leptons or antileptons is chirality, but not lepton number, and not particle vs. antiparticle.
Neglecting the neutrino masses means that there are only left-handed neutrinos and lepton number is conserved with neutrinos having lepton number 1 and anti-neutrinos lepton number -1. The violation of lepton number conservation by small Majorana mass terms is small, and thus lepton-number violation is NOT dramatic. If it were, we'd have discovered it, and (pure) dirac neutrinos were ruled out already!
  • #169
However, within the SM you can’t write down plain majorana mass terms, it would have to be via the (dimension 5) Weinberg operator. So this would only be an effective theory that still needs some UV completion. If this is via a seesaw-like mechanism, you get your ‘sterile’ neutrinos right back ;).
  • #170
Thanks for the wonderful above summary of the situation. I'm still trying to understand what it means to say that the violation of lepton number conservation is weak. I get that in accelerator experiments, it wouldn't show up often, and this is related to the fact that neutrinoless double beta decay is an incredibly rare phenomenon. But I think what you must mean is that the detection of the violation is hard to do. If neutrinos are Majorana particles, then every time we make a neutrino beam from a bunch of leptons, or what we thought was an antineutrino beam from a bunch of antileptons, isn't the neutrino beam itself an example of drastic lepton number violation? Then when the neutrino beam strikes a detector, the lepton number is in a sense recovered when new leptons and antileptons are created. So the violation "covers its tracks," but it would be there in the Majorana theory, just hard to see if we tend to regard neutrinos as being Dirac particles so able to have a lepton number as the "middlemen" in that experiment.
  • #171
But don't you "hide" those sterile neutrinos at very high mass, whereas the Dirac version doesn't have that attractive feature? I thought this was argued as an advantageous element of the Majorana picture, in the sense that it helps explain why neutrino masses are so low.
  • #172
Sure, that’s where the popularity of the seesaw mechanism comes from. My point was that while you can write down a Majorana mass term with only the experimentally observed fields, you need something additional to make it work in the whole standard model, as you need in the Dirac case.
Note that in seesaw the neutrinos fundamentally have both Dirac and Majorana mass terms (the latter one only for the sterile ones), so at that point you have not decided between those two cases. Only the effective degrees of freedom you see at low energies are purely Majorana.
  • #173
Ah, good point, so one cannot even say that Dirac neutrinos are part of the standard model and Majorana neutrinos are not, and what's more, what is actually being debated is which type is exhibited at low energies (because the standard model always involves some combination of both). So would you say that within the standard model, two contrasting types of neutrino behavior are distinguished at low energy: the Dirac type, for which the nonsterile neutrinos are most naturally massless, and the Majorana type, which by the seesaw mechanism attributes low mass to the nonsterile versions and high mass to the sterile ones? Then when neutrinos are found to have mass, you must kind of scramble to shoehorn the Dirac model into that new picture, whereas Majorana was there all along?
  • #174
If you want massive Dirac neutrinos you can just add the right handed neutrinos and write down the mass term/a corresponding higgs coupling and be done. That’s literally copy-and-paste of what you do with any other fermion in the SM. You likewise might say this is what was there all along, there is no scrambling or any ‘real’ problem.
Its a matter of taste, and preconceptions about how a fundamental model should look beyond describing observations, which of the versions appears more ‘natural’ to you.
  • #175
OK, so there is no theoretical reason to favor either type without getting into personal preferences, and both fall equally under the "standard model." So given that, would it be fair to say that characterizing a beam of neutrinos that were generated by antileptons as "a beam of antineutrinos," an extremely common phrase in the current lexicon, is purely a kind of historical accident without any strong theoretical foundation other than an arbitrary preference for lepton number conservation over the other possible theoretical preferences?
  • #176
Or equally under “beyond the standard model”, depending on who you ask ;).
There is still one field that is produced when particles decay, and its charge conjugate is produced when antiparticles decay. Its natural to call these ”neutrino” and “anti-neutrino”.
Preference for lepton number conservation is not arbitrary, it is based on lepton number being conserved either exactly or to an extremely good approximation.
  • #177
Was it not established above that what is produced when leptons decay preserves chirality? So neutrino beams preserve the chirality of the particles that created them, that much is clear. But on what basis does one claim that the fields that are produced are charge conjugations of each other, rather than chiral opposites? Does that not already assume something about the neutrino fields that has not been established experimentally?
Again that refers to the particles that have lepton number, such as the leptons that created the neutrino beam, and the leptons produced by the beam. But if antileptons produce a beam of neutrinos that turn out to be Majorana neutrinos, is that not a situation where the beam itself drastically violates lepton number conservation, even if the lepton number is recovered when the beam interacts in the detector and creates antileptons again? I thought that is what had been established above.
  • #178
Well, they have opposite (weak hyper-) charges…
I don’t understand what this phrase is supposed to mean.
  • #179
It is often said that a Majorana neutrino cannot be distinguished as a particle or an antiparticle, are you saying that is not true?
To my understanding, leptons have lepton number +1, while antileptons have lepton number -1. It is also my understanding that Majorana neutrinos would not have a lepton number (or would have lepton number zero, if there is any distinction there). Is that not correct? Because if it is correct, then when antileptons interact to create "antineutrinos" in a beam, we have particles with lepton number -1 creating no particles with lepton number -1. So that would be nothing close to lepton number conservation. However, when the "antineutrinos" are detected, they will create particles with lepton number -1, so the lepton number is in some sense recovered, even though it was not present in the beam itself. Is that not what would be happening if neutrinos are Majorana particles?
  • #180
By the way, this talk http://www.maria-laach.tp.nt.uni-siegen.de/downloads/files/2016/Mertens-2016-2.pdf was entered into a discussion on Majorana neutrinos by @vanhees71 some years ago. To my read, it's quite clear on the meaninglessness of the "antineurino" concept, if neutrinos are Majorana particles. It also makes a key distinction between chirality and helicity, which @Vanadium 50 also alluded to above, saying that to order m/E, a particle with a given chirality can mix in some opposite helicity. It seemed to say that low-mass neutrinos can be clear about their own chirality but a little ambiguous about their helicity, which relates to the issues of both creating leptons or antileptons, and also how neutrinoless double beta decay can occur (though the points it was making about helicity being a property of the particle and chirality a property of the interaction were not clear to me, helps to have the spoken part!).
But none of that seems to have much to do with the antimatter issue-- there simply appears to be no point in calling any Majorana neutrino an "antineutrino" regardless of chirality or helicity issues, the term simply doesn't seem to have any meaning.
  • · Replies 33 ·
