Make a matrix defective if possible
  • Thread starter Thread starter Dustinsfl
    Matrix
To make the given matrix defective, it is necessary for the parameter alpha to equal 0 or 2, as these values lead to dependent column vectors. The determinant equation indicates that the eigenvalues are 0, alpha, and 2, with a requirement for an eigenvalue to have greater than one algebraic multiplicity for defectiveness. To confirm if the matrix is indeed defective at these values, one must check for an incomplete basis of eigenvectors. The discussion emphasizes that while alpha=0 or 2 are potential candidates, it is not guaranteed that these are the only values that could result in a defective matrix. Ultimately, verifying the eigenvector basis is crucial for determining the defectiveness of the matrix.
Dustinsfl
\begin{bmatrix}<br /> 1 &amp; 1 &amp; 0\\ <br /> 1 &amp; 1 &amp; 0\\ <br /> 0 &amp; 0 &amp; \alpha<br /> \end{bmatrix} and det(A-\lambda I)=\lambda(\alpha-\lambda)(\lambda-2)=0
Therefore, \lambda_1=0, \lambda_2=\alpha, and \lambda_3=2.
In order to make this matrix defective, I need to make the left two column vectors dependent\begin{bmatrix}<br /> 1-\alpha &amp; 1 &amp; 0\\ <br /> 1 &amp; 1-\alpha &amp; 0\\ <br /> 0 &amp; 0 &amp; 0<br /> \end{bmatrix}.
Is there an easy way to find or determine if this can be done for a given matrix?
I am thinking the only way this will work if alpha=0 or 2? Then I need to check those values to see if the eigenspace has only one eigenvector. However, is that necessarily true that it will only work at those values or is it possible that another value besides 0 or 2 will work?
well to be defective it must have an eigenvalue with >1 algebraic multiplicity, but looking at
http://en.wikipedia.org/wiki/Defective_matrix
says normal matricies are not defective, and your matrix is real & symmetric as far as I can tell...
If a matrix has an eigenvalue, then it has at least one eigenvector corresponding to that eigenvalue. So, yes, the only way it can be defective is if alpha=0 or alpha=2.
Thanks
Careful, what Dick said was that the matrix can be defective if \alpha=0 or \alpha=2...In order to determine if it actually is defective for either of those two values, you need to check whether or not they yield an incomplete basis of eigenvectors.
Right. I should have emphasized the 'CAN'. In fact, for those two values, if you think about lanedance's general observation, you don't actually have to compute the eigenvectors.
  • · Replies 19 ·
