Making Paper Longer: Tips to Break a Record
  • Thread starter Thread starter Sarai
    Paper
The discussion revolves around strategies for maximizing the length of a single piece of paper for an applied tech lab project, with the goal of breaking a record of 115 feet. Participants explore various cutting techniques and considerations for achieving the desired length without using tape or additional materials.
  • Homework-related
  • One participant suggests cutting strips and folding the paper, but expresses uncertainty about the effectiveness of this method.
  • Another participant proposes using a razor blade and ruler to create a long thin sliver, but acknowledges restrictions on bringing such tools to school.
  • Scissors are suggested as an alternative cutting tool, with a note that folding may lead to loss of paper length as cuts get shorter.
  • A circular or spiral cutting technique is recommended as a compromise to avoid folding and maximize length.
  • One participant advises practicing different techniques to find the most effective method and warns about the possibility of receiving paper in unexpected shapes.
  • A calculation is provided estimating the number of strips needed to reach 80 feet, highlighting the challenge of cutting strips narrow enough to achieve the goal.
Participants express various ideas and techniques, but there is no consensus on the best method to achieve the desired length. The discussion remains open-ended with multiple competing approaches presented.
Participants mention limitations regarding the tools they can use in school, as well as the potential variability in the shape of the paper provided, which may affect their strategies.
Sarai
Okay, so for my applied tech lab class we have to take a piece of paper and make it as long as possible without breaking off the paper in any way. We aren't aloud to use tape and only one piece of paper. We get two practice sheets, in the class. Of course I a, aloud to do things outside of class but I'm not aloud to use it. The record is 115 feet and me and my partner ours to be at least 80 feet. I had the idea of cutting strips and folding it over but I don't know if there would be another way? Do any of you have any ideas?
Thanks for your answers, they are much appreciated!
Hi Sarai. :welcome:
Is it permissible to make use of a razor blade and ruler, to convert your page into a long thin sliver? [emoji196]
NascentOxygen said:
Hi Sarai. :welcome:
See, that's what I was thinking, but I can't bring things like that into school, as I'd get expelled because it'd be a weapon.
Scissors, then.
While folding might be okay when the cuts are long, you'll be losing an increasing percentage of paper as the cuts get shorter towards the centre. A compromse might be to turn your cutting circular (i.e., spiral) towards the centre so there is no folding.
NascentOxygen said:
Sizzors, then.
Okay, for a minute I was really lost on what you meant but I figured it out and I think that that is probably the best solution. Thank you so much.
Carry out some practice exercises beforehand, to determine a technique which looks most promising. Also, allow for the possibility that they may surprise you by distributing paper of some unexpected shape, e.g., cloud-shaped, P-shaped, whatever.
I assume your paper is 11" x 8.5". If you make long cuts and unfold then each strip adds around 10-10.5" to the length. In that case to reach 80feet you need 80 * 12/10.5 = 91 strips. If the width of paper is 8.5" each trip can only be around 8.5/91 = 0.093" wide, less than 1/10th inch. Have a go but I think it will be hard to do with scissors.
  • · Replies 62 ·
16K
