Malus law in quantum mechanics
The discussion centers on Malus's law in quantum mechanics, specifically regarding the intensity of polarized light passing through a polarizer at a 45-degree angle. When sending the state |y> = 1/sqrt{2}( |H> + |V> ) into the polarizer, the intensity loss depends on the diagonal basis chosen. The intensity of light transmitted through the polarizer can be calculated using the formula | |^2. For objects with different spins, the polarization vector must be rotated into the polarizer's basis, which involves understanding angular momentum operators and their role in rotations.
  • Understanding of quantum mechanics concepts, particularly polarization and Malus's law.
  • Familiarity with quantum state notation, such as kets and basis transformations.
  • Knowledge of angular momentum operators and their application in quantum mechanics.
  • Access to graduate-level quantum mechanics textbooks, such as Sakurai's Modern Quantum Mechanics.
  • Study the derivation and implications of Malus's law in quantum mechanics.
  • Learn about the mathematical representation of polarization states and their transformations.
  • Explore angular momentum operators and their role in quantum state rotations.
  • Read Sakurai's Modern Quantum Mechanics for a deeper understanding of polarization and spin systems.
Students and professionals in quantum mechanics, physicists studying light polarization, and anyone interested in the mathematical foundations of quantum state transformations.
AlexHT
Hi,
For example, if I were to send |y> = 1/sqrt{2}( |H> + |V> ) photons into a polarizer with a 45 degre angle from horizontal, would the beam loose intensity? How can I calculate it on my own?
EDIT: The picture below illustrate what is happening. I am changing the base from x-y to a diagonal base. Do I loose intensity?
No. Or rather, it depends on which diagonal you're talking about. One will allow |H>+|V> through and completely block |H>-|V> ; the other will do the reverse. You can pretty much see what happens here just by looking at things: the lower-left to upper-right diagonal clearly corresponds to |H>+|V> -- that line is given by c (\hat{x}+\hat{y}) ,\ c \in R after all -- and so a polarizer along that lines corresponds to a projection onto |H>+|V>. The intensity of light getting through is given by | <\mbox{light}|\mbox{polarizer}>|^2 where light is the normalized polarization vector of the light, and polarizer is the normalized vector of the polarizer.
In a more general situation -- I mean when you're dealing with polarization of objects which are not spin-1 like light -- what you'd want to do is rotate the object's polarization vector into the basis of the polarizer. To do this you need to know how the object transforms under rotations; that can be found by exponentiating the angular momentum operators (which are the generators of rotations.) If this sounds like gobbedy-gook, you can study a good (grad-level) quantum mechanics textbooks. They will go into this in some depth. IIRC Sakurai's Modern Quantum Mechanics is particularly good on this topic. For a spin-m object polarized perpendicularly to the plane of the polarizer, this turns out to be pretty simple; you get roughly the same result as for light, except the rotation angle that shows up is proportional to m*theta, ie
|\mbox{rotated ket}> = \left( \begin{array}{cc} \cos(m\theta) & \sin(m\theta) \\ -\sin(m\theta) & \cos(m\theta) \end{array} \right) |\mbox{original ket}>
  • · Replies 44 ·
  • · Replies 22 ·
  • · Replies 21 ·
  • · Replies 19 ·
