How Does InSight Distinguish Marsquakes from Meteor Impacts?
  • Thread starter Thread starter RJ Emery
    Identification
The InSight Lander on Mars detects marsquake signals, which need to be distinguished from meteor impacts due to Mars' lack of a significant atmosphere. NASA has experience analyzing moonquakes to differentiate between seismic activity and impacts, as both Mars and the Moon share geological characteristics such as the absence of plate tectonics and active volcanism. The seismic signatures of quakes differ from those of impacts, allowing scientists to identify the origin of the signals. Any significant impact that generates a planet-wide seismic signature would likely create a crater, which could be observed by the Mars Reconnaissance Orbiter, monitoring surface changes on Mars. Despite some similarities, the interior compositions of Mars and the Moon differ, meaning not all lunar observations can be directly applied to Martian geology.
RJ Emery
Every day the Earth is bombarded with meteors both large and small, most disintegrating in the atmosphere. A few strike the surface. Mars has no significant atmosphere. Thus, how is the marsquake signal detected by the InSight Lander distinguished from a true marsquake versus a meteor impact somewhere else on the Martian surface?
http://www.sci-news.com/space/insight-first-marsquake-07122.html
Likes davenn
Good question. I assume the signals from an impact event are different from geologic activity, but I'd like to know as well.
Likes davenn
Agreed. That may take some help from @davenn and others...
Likes davenn
Greetings @RJ Emery
Welcome to PF :smile:
This is the good bit from that article ...
“The Sol 128 event is exciting because its size and longer duration fit the profile of moonquakes detected on the lunar surface during NASA’s Apollo missions,” said Dr. Lori Glaze, Planetary Science Division director at NASA Headquarters.
Fortunately NASA/JPL have had many years of experience of recording and analysing moonquakes to determine the differences between
actual quakes and meteorite impacts and because the geology of Mars will be sort of similar to the Moon ...eg. no plate tectonics,
no known current active volcanism or oceans, therefore the types of quakes detected will likely to be quite similar.
Tho there are still unanswered questions :wink:
Here is some more info on them from my own www site that I posted so many years ago...
http://www.sydneystormcity.com/moonqk.htm
and a .pdf file with good info...
https://www.lpi.usra.edu/meetings/lpsc2004/pdf/2093.pdf
Basically they discovered differences in the seismic signatures of quakes compared to impacts when analysing the seismogramscheers
Dave
Likes Astronuc, BillTre, berkeman and 3 others
The interior compositions of the Moon and Mars are dissimilar. Thus, observational experience with the Moon is not necessarily transferable to Mars. Nevertheless, any impact on the surface sufficiently large to create a planet-wide seismic signature would probably leave a crater, to be eventually detected by the Mars Reconnaissance Orbiter, which is continually searching for surface changes.
not completely ... they are both thought to be cold ... that single fact makes a big similarity between them
well, if you read the papers you will find that there are things that are transferrable
hmmm, you really didn't read any of the info did you :frown:
I gave you some insight into what they saw and you completely dismissed itDave
Indonesia evacuates stranded climbers after Semeru volcano erupts https://www.reuters.com/business/environment/indonesia-evacuates-stranded-climbers-after-semeru-volcano-erupts-2025-11-20/ https://www.bbc.com/news/videos/clyzy88l87no Indonesia’s Mount Semeru erupts, blanketing villages with ash and prompting evacuations https://apnews.com/article/indonesia-volcano-mount-semeru-east-java-004472fe274828ceac7c4d48ddd7abc6 More than 170 people rescued off Mount Semeru after eruption as 1,000...
28K
