Mass dialation for space drive
  • Thread starter Thread starter adamsmith56
    Drive Mass Space
The discussion revolves around the theoretical concept of using a spinning metal disk to manipulate mass for propulsion in space. Participants question the feasibility of increasing mass at the disk's rim while oscillating it in a tube to achieve motion without losing reaction mass, potentially violating conservation of momentum. Concerns are raised about how to spin the disk without causing the entire system to move in the opposite direction, highlighting the need for energy exchange during the process. Suggestions include using two disks spinning in opposite directions to balance angular momentum, but the energy required for spinning remains a critical issue. Ultimately, the conversation emphasizes that conservation laws must be respected, and no method can bypass the fundamental principles of physics.
adamsmith56
Question to the physicists in here:
Would it be possible to spin a metal disk such that it increases mass along the outer rim(as all objects increase mass up to infinite mass near the speed of light)? Then oscillate the disk in a tube such that it is spinning while it travels in one direction(having increased mass), stationary as it travels in the other direction(having decreased mass), so that no reaction mass is lost as in a rocket.
In theory this would negate the conservation of momentum as the disk while spinning has MORE mass than the disk while resting. The disk while spinning would only travel in one direction while the resting disk would travel in the other during it's oscillation in a tube.
Obviously the type of material, maximum rpm for the material, and relativity equations would apply.
Hope to hear from someone!
http://en.wikipedia.org/wiki/Mass_in_special_relativity
Opposite and equal reactions, remember! How will you make your disc spin in one direction without making the rocket spin in the other with the same angular momentum?
As you then push the heavier spinning mass in one direction, the heavier spinning rocket in turn will move in the other direction. The centre of gravity will not move.
Mike
I think that problem would be easily solved by having two discs of equal mass spinning in opposite directions--and moving them both up and down the tube together. But, I have no idea if this plan would work or not because of some more fundamental reason. Good thinking, though!
This should be a big red flag. If you think you've violated a conservation law, it means you've left something out.
In this case, as Mike Holland pointed out, you're leaving out how the disk gets spun up at one end and then spun down at the other. It has to exchange energy and angular momentum with *something* to do that. Include that in your scenario and you will see that overall momentum is conserved.
cephron's idea of having two disks spinning in opposite directions would take care of the angular momentum part (the net angular momentum of the two disks would be zero), but not the energy part: it takes energy to spin up the disks, and they have to give up energy to spin down. Where does that energy come from, and where does it go? Again, when you include that you'll find that the conservation laws hold up just fine. There ain't no such thing as a free lunch; sorry. :wink:
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
  • · Replies 95 ·
10K
  • · Replies 33 ·
  • · Replies 17 ·
