Derivation of E=mc2 from Four-Vector Definitions in Special Relativity
  • Context: Undergrad
  • Thread starter Thread starter Ziang
    Derivation
The discussion centers on deriving the equation E=mc² from four-vector definitions in Special Relativity (SR). Participants clarify that fundamental concepts such as velocity, acceleration, and momentum are defined as four-vectors, with the four-momentum being critical in establishing the energy-momentum relation. The derivation of E=γm₀c² is confirmed through the scaling of four-velocity by mass, while the energy-momentum relation is defined rather than derived. The conversation emphasizes the importance of understanding the four-vector formalism and its implications in SR.
  • Understanding of four-vectors in Special Relativity
  • Familiarity with the concepts of four-momentum and four-velocity
  • Knowledge of the Lorentz factor (γ) and its role in relativistic equations
  • Basic grasp of the Minkowski dot product and its application in SR
  • Study the derivation of the Lorentz transformations in Special Relativity
  • Explore the implications of the Minkowski metric in four-vector analysis
  • Learn about the conservation of energy and momentum in relativistic collisions
  • Investigate experimental validations of E=mc² in particle physics
Physicists, students of theoretical physics, and anyone interested in the mathematical foundations of Special Relativity and its implications for energy and mass equivalence.
  • #61
Ah, that's not usually referred to as "potential energy." It's "rest energy" / "invariant energy" / "proper energy" / "mass-energy."
  • #62
True. I used that phrasing more as an analogy since it works out to have the same form. Ambiguity aside, the derivation works like a charm. Set speed to zero and you get what OP wanted. *shrugs*
  • #63
The GR could lead to the relation too?
  • #64
For small intervals of spacetime, spacetime is approximately flat. So if it's true in SR it's true locally in GR, if I understand it correctly.
  • #65
GR is a generalisation of SR, so all results in SR can be derived using the tools of GR.
In this particular case, you'd probably start from the notion of a worldline and do a slightly more rigorous derivation of the four-velocity as the tangent to the worldline. The rest is the same.
  • #66
Could Newtonian mechanics concepts/absolute space and time lead to the relation as well?
  • #67
Sorcerer said:
Here’s my favorite way. (Ibknow the discussion has moved on, but OP asked for a quick and easy derivation, so here is one way to do it that seems to work).Start with a spatial differential dx. Then divide by proper time (so that everyone agree with what you do going foward).
From there, use the usual kinemetics. Multiply by mass to get momentum, take the time derivative to get force, integrate over distance to use the work-energy theorem to get an expression for kinetic energy, then notice that kinetic energy = total energy minus potential energy, and you’re pretty much done.
I'm sure I've seen this done for the rectilinear case (though I can't remember where), but I thought I'd give it a crack for the general case. The idea is that one has already obtained the equation for relativistic momentum ##\vec p = \gamma m \vec v## and plugs it into the "work" side of the work-energy theorem to see what pops out on the "energy" side. Using ##\vec f = \dot{\vec p} = mc^2 \, d(\gamma \vec \beta)/d(ct)##:
$$\begin{split}
\int^{\vec r_f}_{\vec r_i} \vec f \cdot d \vec r &= mc^2 \int^{\vec r_f}_{\vec r_i} \dfrac{d (\gamma \vec \beta)}{c \, dt} \cdot d \vec r \\[3pt]
&= mc^2 \int^{\vec \beta_f}_{\vec \beta_i} \vec \beta \cdot \left( \gamma \, d \vec \beta + d \gamma \, \vec \beta \right),
\end{split}$$
where
$$\begin{split}
d \gamma &= d \left[ \left( 1 - \vec \beta \cdot \vec \beta \right)^{-1/2} \right] \\[3pt]
&= \dfrac{1}{2} \left(1 - \vec \beta \cdot \vec \beta \right)^{-3/2} \, d ( \vec \beta \cdot \vec \beta ) \\[3pt]
&= \gamma^3 ( \vec \beta \cdot d \vec \beta ) ,
\end{split}$$
so
$$\begin{split}
\int^{\vec r_f}_{\vec r_i} \vec f \cdot d \vec r &= mc^2 \int^{\vec \beta_f}_{\vec \beta_i} \vec \beta \cdot \left[ \gamma \, d \vec \beta + \gamma^3 ( \vec \beta \cdot d \vec \beta ) \vec \beta \right] \\[3pt]
&= mc^2 \int^{\vec \beta_f}_{\vec \beta_i} \Bigl[ \gamma \left( 1 + \gamma^2 \beta^2 \right) \Bigr] ( \vec \beta \cdot d \vec \beta ) \\[3pt]
&= mc^2 \int^{\vec \beta_f}_{\vec \beta_i} \gamma^3 ( \vec \beta \cdot d \vec \beta ) \\[3pt]
& = mc^2 \int^{\gamma_f}_{\gamma_i} d \gamma \\[3pt]
&= mc^2 \Delta \gamma \\[3pt]
&= mc^2 + mc^2 \Delta \left( \dfrac{1}{2}\,\beta^2 + \frac {3}{8} \, \beta^4 + \frac{5}{16} \, \beta^6 + \frac{35}{128} \, \beta^8 + \dots \right),
\end{split}$$
where the ##\beta^2## term suggests calling everything in the parentheses "kinetic energy" ##E_k## and the invariant first term "rest energy" ##E_0##. Then it makes sense to define ##\gamma mc^2 = \gamma E_0 \equiv E## as the total energy, and:
$$E^2 - (pc)^2 = (\gamma E_0)^2 - (\gamma \beta E_0)^2 = E_0^2,$$
though I suppose one might like to know whether ##E## is indeed conserved before calling it "energy."
I think I prefer to "justify" the existence of rest energy by Einstein's own reasoning (from his original ##E = mc^2## paper): if a body at rest emits identical light waves in opposite directions, then its kinetic energy remains the same in this frame (zero), but it loses energy nevertheless.
  • #68
$$\begin{split}
\end{split}$$
where
$$\begin{split}
\end{split}$$
so
$$\begin{split}
\end{split}$$
I never noticed that you can do a change of variable to dγ. All the times I’ve done this I’ve had to do trig substitution. Such an obvious thing but I missed it.
  • #69
I didn't find that obvious, but in hindsight I guess I should have (since I already knew the energy equations I was working toward). Anyway, fun exercise!
  • #70
Is there any way to derive the relation based on Newtonian mechanics clearly and convincedly?
  • #71
No, because that relation does not hold in Newtonian mechanics.
  • #72
No. Starting with the Newtonian expressions for the relationships between force, momentum, and energy you can derive some approximate relations. Using the postulates of special relativity you can derive more general expressions that match very closely, when the speed is low, those approximate relations.
In other words, you can derive the Newtonian expressions from the relativistic expressions, but you can't derive the relativistic expressions from the Newtonian expressions.
  • #73
Is there any way to modify Newtonian mechanics so that the mass-energy equivalence can be derived from absolute space and time?
  • #74
No.
  • #75
Yes. By changing the transformation rule from the Galileo to the Lorentz. That is, by turning it into special relativity ;) (but no, not from absolute space and time lol)
  • #76
I heard of a modified Newtonian mechanics which could yield mechanical expressions and the mass-energy equivalence as well from absolute space and time. The theory also gives better results than Newtonian mechanics does. May I write down some of its expressions here?
  • #77
This forum only deals with established and accepted theories. If it's experimental and cutting edge, there is a sub-forum, and if it isn't peer reviewed stuff, it probably isn't welcomed here.
In any event, the only reason you get E = mc2 is because of the very assumption that time doesn't tick the same for all clocks. That is built into the Lorentz transformation itself. I suppose there are/were different interpretations of the math, but since E = mc2 was discovered, and even before it, no one really doubted the math (Lorentz himself accepted his own transformations, despite his slowness in warming to Einstein's interpretation, including his equation that leads to length contraction, but Lorentz attributed it to the moving matter being deformed).
  • #78
Ziang said:
I heard of
Can you give a valid reference (textbook or peer-reviewed paper)?
  • #79
I found it on Amazon. A thin book titled "Beyond the world of relativity". Mathematics in the book is simple. I think scientists will get interested in the way it leads to the equivalence from absolute space and time.
  • #80
Can you give a link?
  • #81
Partial (I think) copy at Google Books edit: removed the link because I'm pretty sure it doesn't meet our standards - you can find it easily enough by googling for the title.
I haven't had a proper look - Google Books doesn't seem to get along with my phone's browser.
  • #82
Now I have (don't know why I can scroll around now - I couldn't before - such are the mysteries of computers). If that is the book that Ziang is talking about then I very much doubt it meets our acceptable reference standards. It apparently simply assumes that Newtonian gravity is correct without any supporting argument, then concludes that event horizons don't exist (around equation 9).
  • #83
Seems the author’s motivation is religious:
“In 1987, Nguyen resettled in the United States. Once his new life became stable, he tried to find the answers to his questions in Buddhism, and he recognized and accepted the Buddhist beliefs of space and time are absolute.”Poor fellow. If only he would have realized that relativity says SPACETIME intervals are absolute.
  • #84
All theories have some assumptions or postulates. So I thought this assumption could be accepted. And because of this assumption, I called it a modified Newtonian mechanics.
Compare to SR, it gives more expressions as potential energy and gravitational red/blue shift.
Compare to Newtonian mechanics, it also gives more expressions as Doppler effect and mass-energy equivalence.
Anyway, it shows a way to derive the equivalence from fundamental definitions of natural concepts in Newtonian mechanics, in absolute space and time.
  • #85
What about relativistic kinetic energy? How does he derive that, which has the Lorentz factor?
  • #86
It appears that the reference @Ibix found is indeed the one you were referring to. That reference is not a valid source for PF discussion; it is not a textbook or peer-reviewed paper and appears to be the author's personal speculation.
Thread closed.
  • · Replies 17 ·
  • · Replies 44 ·
