Mass Energy Equivalence and Kinetic Energy
The discussion revolves around the relationship between mass, energy, and kinetic energy, particularly in the context of particles moving through free space. Participants explore concepts of mass-energy equivalence, relativistic mass, and the implications of kinetic energy on atomic structure and behavior.
  • One participant questions whether a particle's kinetic energy is equivalent to its mass-energy equivalence, suggesting a potential confusion between the two concepts.
  • Another participant clarifies that the rest energy of a particle is given by mc², and that kinetic energy is defined differently, particularly at relativistic speeds.
  • A later reply proposes that the total mass of a moving particle could be viewed as the sum of its rest mass energy and kinetic energy, leading to a discussion on the concept of relativistic mass.
  • Some participants inquire about the concrete differences between mass and energy, suggesting that while they are equivalent, they should not be considered the same thing.
  • There is a question about whether an increase in relativistic mass due to kinetic energy affects the internal forces within an atom, and whether this could alter properties such as orbital radius.
  • Responses indicate that from the perspective of a moving atom, there may be no observable differences in its characteristics compared to when it is at rest, although kinetic energy is acknowledged to be higher when in motion.
  • One participant suggests that when observing an atom from a stationary frame, differences in energy levels and electron behavior may be noted due to relativistic effects.
Participants express differing views on the relationship between mass and energy, with some emphasizing their equivalency while others caution against conflating the two. The discussion remains unresolved regarding the implications of kinetic energy on atomic structure and the nature of mass.
There are limitations in the discussion regarding the definitions of mass and energy, as well as the assumptions underlying the relativistic effects mentioned. The mathematical relationships and their applicability at different speeds are also not fully resolved.
gareththegeek
If a particle is moving through free space (no forces acting upon it) should its kinetic energy equal its mass energy equivalence or am I getting confused. In other words is an object's kinetic energy absorbed within its mass?
Is the following true?
E_{kinetic} = \frac{p^{2}}{2m} = mc^{2} = E_{mass}
No.
(1) For one thing, mc², where m is the invariant mass, is the rest energy of the particle.
(2) KE = p²/2m is only approximately valid when speeds are low enough.
(3) The total energy of a free particle is given by
E = (\frac{1}{\sqrt{1 - v^2/c^2}}) mc^2
The KE energy is the total energy minus the rest energy:
KE = (\frac{1}{\sqrt{1 - v^2/c^2}} - 1) mc^2
Thanks!
Yes, I realized I asked my question badly. So to clarify the total mass of the moving particle is equal to the initial mass-energy plus the kinetic energy so the kinetic energy could be thought of as being absorbed into the total mass of the moving particle.
Correct?
Correct?
If by 'total mass' you mean the so-called relativistic mass, then yes: The relativistic mass reflects the total energy of the particle.
But I think you're better off sticking with invariant mass and thinking in terms of rest mass energy plus kinetic energy.
So has science determined if there is a concrete difference between mass and energy? If the "relativistic" mass were increased by kinetic energy on an atom rather than a particle then would that affect the internal balance of forces of the atom? Could it alter the orbital radius &c?
Thanks for the reply!
While there is certainly an equivalency between mass and energy, I wouldn't think of them as being the same thing.
If I understand your question, it's equivalent to asking: If an atom is moving, will it have different characteristics than an atom at rest. As far as the moving atom is concerned, from its frame there is no difference.
Granted, but if I observe the atom's state when it was stationary and again when it was moving, both times from my own stationary frame, would there be any difference?
You would observe that it's moving, and it has higher energy (kinetic). for low speeds you can approximate this extra energy as 2*E(k)=mv²
Explanation of mass with Tensors
10:00 onwards, it shows how the above os derived
I definitely would however think of them as connected... or related...we strongly suspect the fource forces are all related; similarly relativity shows us energy and mass are related as are space and time...you can read more about all these related to "phase transition" associated with the big bang...or "grand unification epoch"...
Sure. Viewed semi-classically, the electrons would seem to be moving slower about the nucleus. The energy levels would be different.
All of this would conspire to support the relativistic time dilation and Doppler effects.
  • · Replies 79 ·
  • · Replies 55 ·
  • · Replies 25 ·
  • · Replies 102 ·
  • · Replies 16 ·
  • · Replies 87 ·
