Mass oscillating on spring
  • Thread starter veitch
The position of a mass that is oscillating on a spring is given by x(t) = (14.5cm)cos[(14.0s-1)t].
What is the speed of the mass when t = 0.820 s?
A= Amplitude
W= Angular frequency
x(t) = ACos(Wt)
v(t) = -WASin(Wt)
v(0.820) = (-14.0)(14.5)Sin[(14.0)(0.820)]
= (-203)Sin[11.48]
= -40.4 cm/s
This seems so easy and yet apparently I have the wrong answer... any insight? :/ Thanks in advance
Answers and Replies
fluidistic
112
What you did seems right to me.
Check the units of your frequency. It looks like you have the value in Hertz (or oscillations per second); try converting the instances of frequency to radians per second (and if you're carrying out the sine calculation on a calculator then change the mode to radians instead of degrees).
Okay, that makes more sense...
W=2 x pi x freq
thus v(t) = -(2 pi 14)(14.5)Sin[(2 pi 14)(0.82)]
which gives -160 cm/s (with 3 sig figs)... but it still isn't right.
I suppose there shouldn't be a negative should there? Since speed is scalar... but 160 isn't the right answer either. :/
Related Threads on Mass oscillating on spring
  • Last Post
  • Last Post
16K
  • Last Post
  • Last Post
