What Forces Act on a Mass Sliding Inside a Hoop?
  • Thread starter Thread starter Becca93
    Mass
A mass M of 0.52 kg slides inside a hoop with a radius of 1.40 m and an initial speed of 5.27 m/s. The calculation of the force exerted by the mass on the hoop at an angle of 27 degrees requires consideration of both the centripetal force and the gravitational force acting on the mass. The correct approach involves adding the gravitational component mg cos(θ) to the centripetal force calculation, leading to a total force of 29.59 N when properly accounting for these forces.
  • Understanding of Newton's laws of motion
  • Knowledge of centripetal acceleration and forces
  • Familiarity with gravitational force calculations
  • Basic trigonometry for resolving forces
  • Study the principles of circular motion and centripetal force
  • Learn how to resolve forces using trigonometric functions
  • Explore the effects of friction in circular motion scenarios
  • Investigate energy conservation in mechanical systems
Physics students, educators, and anyone interested in understanding dynamics in circular motion and force interactions in mechanical systems.
Becca93
A mass M of 5.20E-1 kg slides inside a hoop of radius R=1.40 m with negligible friction. When M is at the top, it has a speed of 5.27 m/s. Calculate size of the force with which the M pushes on the hoop when M is at an angle of 27.0 degrees.
Picture attached at the bottom.
The attempt at a solution
E at the top of the circle should equal the energy at that particular part of the circle. So,
mg(2r) + (1/2)mvtop2 = mg(r-rcosθ) + (1/2)mv^2
m's cancel, so
g(2r) + (1/2)vtop2 = g(r-rcosθ) + (1/2)v^2
2(g(2r) + (1/2)vtop2 - g(r-rcosθ) = v^2
a = v^2/r
F = ma
When I plug everything in, I get
2(39.831) = v^2
v^2 = 79.66
a = 79.66/1.4
a = 56.90
F = (.52)(56.90)
F = 29.59 N
This answer is incorrect.
Please, can someone let me know where I'm going wrong?
You've calculated the force due to the circular motion, but what other force is also working on the mass?
Okay. I'm forgetting the force of gravity acting on the mass, aren't I?
Should I add mgcosθ to my answer? Is that all I'm missing?
That looks right. Since the hoop has "negligible friction", only the component of the force due to gravity that is normal to the hoop's surface should matter -- the other component acts to accelerate the mass tangentially.
  • · Replies 27 ·
  • · Replies 21 ·
