Mass spectrometer with a Lead element
40 replies · 6K views · last reply
Was the difference between m1 and m2 supposed to be 1.67x10-27? I wonder if I made the wrong calculation.
m2 - m1 = 0.02x10-25 = 2x10-27. Does a 0.33 slip cause a problem? I hope does not :)
In Post #27 you wrote:
m1 = 3.42*10-27x205.974 = 3.42*10-25
Where did 3.42*10^-27 come from? Also, the result is not what my calculator says. And you should be including units.
Oh, I thought I fixed it when I see it first time. So, actually 1AMU = 1.66X10-27 and m1 = 205.974*1.66x10-27 = 3.4191684×10-25 = 3.42x10-25. But I can't edit the post #27 now.
It may says the same result now I guess.
I'm going to take care of it. Thanks for notice.
edit: I think only latest posts can be edited. So #27 will not be able to be changed.
I was talking about the same thing at #31. And because of we can't use these as m2-m1 in ##
(r_2 - r_1) = r_2 (1 - \sqrt{\frac{m_1}{m_2}})## I calculated these m2 and m1 one by one. So in this way, we don't have to use actual mneutron I think. What do you think?
You're right. The original problem didn't ask you to use the neutron mass, it just said, "The mass difference between two isotopes is sometimes just a neutron mass. The spectrometer should separate them very well."
Would you like to add something else? Because I am starting over to do the homework.
I think you've got the idea. A couple of things to remember:
(1) Clearly state the assumptions you are making.
(2) Make sure to keep enough significant figures so the error in your final answer is less than 10%, especially when subtracting two similar sized numbers like r2-r1.
(3) Always include the units!
Thanks for everything ! All the best
In velocity selector region, the question says "determine" but I did it like this below. I chose the voltage necessarily. Is there another way to determine these values?
Handwritten velocity selector diagram with parallel plates marked + on the left and − on the right, electric field lines pointing right, magnetic field into the page, and forces F_E and F_B balancing a moving ion; handwritten equations include E = 0.51x10^6 N/C and E = V/d.
And also, how can I calculate power of this voltage supply? This can be thought of a capacitor?
