Mastering SI-Prefix Conversions for Easy Homework Help
  • Thread starter Thread starter bluepilotpen
    Homework
3 replies · 3K views
bluepilotpen
My question doesn't really fit into the template here, but I'll give it a shot, anyway.
How do you go about converting SI-prefixes? I understand you're supposed to convert the prefixes into associated power of ten's, but then I'm stuck. How do you continue? Sometimes I get it right, sometimes wrong.
Any help would be much appreciated. Thanks! Oh, and sorry if I posted this in the wrong section. I blame it on a bad night's sleep.
The problem could look like this:
Convert 4 uL (microlitres) to mL (millilitres).
Try it this way:
Convert 8L (litres) into ml (millilitres).
8L * (1000ml/1L) = 8000ml
See what happened? You've got a unit, L, for your 8 litres, and you want to change that into ml, so you multiply it by ml/L, as you know that there are 1000ml in a litre. You're essentially multiplying by 1, which doesn't change anything =)
Your example:
The easiest way to go about this is to apply a unit factor/conversion. When I was in the military they taught me a good little (albeit non p/c) mnemonic.
Texas Girls Must Know Base Marines Use No Protection
T G M k base m u n p
Just remember that each one of those (working out from the base) is 3 more to the exponent.
So T is 10^12, and m is 10^3 etc..
Aside from that, you have to remember deci and centi between the base and m.
For your example, take the given value and apply a unit factor:
[tex]4uL\frac{1L}{10^6 uL}[/tex]
This gives you the "base", and you must them convert it to mL by multiplying in another unit factor.
[tex]4uL\frac{1L}{10^6 uL}\frac{10^3 mL}{1L} = .004 mL[/tex]
Pay close attention to the unit, and treat it like a variable. When you want to convert from one to the other, apply the unit factor in such a way where the original unit cancels out.
Both SI prefixes and units are items that you multiply with.
In your example you have:
4 uL
= 4 x micro x L
= 4 x 10-6 x L
= 4 x 10-3 x 10-3 x L
= 4 x 10-3 x milli x L
= 4 x 10-3 mL
