How can I prove this formula for n = 2?
  • Thread starter Thread starter lovemake1
    Induction
The discussion focuses on proving the maximum overhang of stacked planks using mathematical induction for the case when n equals 2. The formula to be proven is Fn = 1/2 [1 + 1/2 + 1/3 + ... + 1/(n-1)]. The user expresses difficulty in formulating the equation for Fn and seeks guidance on establishing the base case and the induction step. They emphasize the need for a starting point to facilitate their proof. The conversation highlights the importance of understanding the induction process in solving the problem.
lovemake1
Suppose that n identical planks, each of length 1 metre, are stacked flat on top of each other, with each one shifted a little further to the right, creating an ever-larger overhang. Prove the maximum span of this overhang is Fn = 1/2 [1 +1/2 + 1/3 + 1/4 + ... + 1/(n-1) ] using induction.
for two objects of masses m1, m2 and distance r1 and r2 (measured from a fixed location):
R = (m1*r1 + m2*r2)/(m1 + m2)
I've tried this problem for 3 days but I'm still not able to come up with an equation for Fn.
so that Fn = the right side..
for example i would need an equation of Fn to check the base case and prove using induction step.
If someone can give me the beginning of the equation or even a big hint would be greatly apprecicated. I need to put an end to this problem soon..
Well, the way induction works is you prove it for the first case (in this case when n=2) and then as an entirely different step, you assume it is true for a random n and then show it is also true for the n+1' case.
9K
  • · Replies 24 ·
