What are the possible values of m in the equation 3m + 3n - 8m - 4n! = 680?
The equation 3m + 3n - 8m - 4n! = 680 requires determining possible values of m and n, both of which are positive integers. Participants discussed strategies, including moving terms to isolate m and n, and using trial and error to find valid pairs. It was suggested that one of the variables must equal 6 to reach the target of 680, with n being less than 5. Ultimately, the conclusion drawn was that m = 6 is the only solution that satisfies the equation, emphasizing the importance of understanding the parity of the expressions involved. The discussion highlighted various approaches and insights into solving the problem effectively.
timetraveller123
Member warned that some attempt must be shown
this problem came out in the math olympiad i took today and i got completely wrecked by this
consider the following equation where m and n are positive integers:
determine the sum all possible values of m:
not sure which
no attempt my mind is completely blank give me some hints please
Try moving everything with m to one side and n to the other side. What can you say about the values of the m-function and n function ?
Likes timetraveller123
Were you allowed to use a calculator ? :smile:
Code:
    n: 1 2 3 4 5 6
  m 1 -6 -4 -2 -20 -242 -2156
    2 -8 -6 -4 -22 -244 -2158
    3 2 4 6 -12 -234 -2148
    4 48 50 52 34 -188 -2102
    5 202 204 206 188 -34 -1948
    6 680 682 684 666 444 -1470
vishnu 73 said:
@BvU
no calculator
Just kidding. But from the brute force results you should be able to extract some restrictions on the (m,n) pairs to check. Especially in combination with a list of powers of 3:
81
243
729
and a list of 4n! helps a lot too!
96
480
2880
These don't take long to set up, even without a calculator.
subsequent hypotheses:
  • one of the two has to be 6
  • m has to be 6, n has to be smaller than 5
I think the hard part is to find the one (6,1) combination that does yield 680. Then 'conclude' that there can be no others.
Likes scottdave
@BvU
not to offend you but i am not really fan of brute force approaches
and why do you say n has to be 6
based on what scottdave said
i inferred m > n is this true
and if it is does it help to write m = k + n
not sure which
##3^m + 3^n = 680 + 8m + 4n!## or ##3^m + 3^n = 4(170 + 2m + n!)##
Since ##170 + 2m + n!## is divisible by ##3## what does this tell you about parity of ##170 + 2m + n!## ? and for what values of ##n## it is possible ?
Likes scottdave
No offence taken. I'm just interested, and to be sure: I don't know the proper way to deal with this one, so I just did trial and error. 4n! goes real fast as you can see, so n can't be 6. You need at least one of the two with a value of 6 to get over 680 .
I hadn't pulled out the factor 4 Buffu mentions. Hats off !
Likes timetraveller123 and Buffu
oh wow that is interesting so 2m + n! ≡ 1 mod3
if n≥3 then m must be multiple of 3
if n <3 then 2m ≡ 2 mod 3
am i getting somewhere
@BvU
and more over i am a really careless boy i am sure to make lots of mistakes i probably lost 8 questions just by careless today so that's another reason i did not opt for your method without a calculator so you anyways trial and error to estimate bounds and restrictions is always uselful
You can do what you are doing but an easy way would be to check if ##170 + 2m + n!## is odd or even ?
oh is n't that always even for n bigger than 2
but what does that tell you the left hand side is also always even
But we want it odd, so what values of ##n## is available to us ?
Likes BvU and timetraveller123
why do we want it odd? please i am beginner in olympiads
but anyways the answer to your question is n =1
edit :
oh sorry now i get why it must be odd because it is divisible by 3 sorry for being so dumb
so n= 1 to give 170 + 8m + 1! to be odd
3m = 680 + 8m + 1
so m must be at least 6 and so is it only m = 6 solves it
that is very brilliant method there how did you get to it did you just play around with the expression until you got something useful
Nooo, It is wrong, since even multiples of 3 are there :).
I said that expression is odd because ##3^n + 3^m## is not divisible by 8 for any value of ##m,n## * and if ##170 + 8m + n!## is even, then ##3^m + 3^n## must be divisible by ##8##.
* ##3^n \mod 8 = 1, 3## using power rule for modulus and the fact that ##3^n = 1 ## for ##n = 0##.
So ##3^n + 3^m \mod 8 = 2, 4, 6## hence never divisible by 8.
I remember some tricks from olympiads when I used to give those.
oh okay now i get it thanks for the help
  • · Replies 34 ·
14K
