Mathematica Why Doesn't Mathematica Produce an Explicit Inverse for My Function?
The discussion revolves around finding the inverse of the function f(x)=(2x+1)/(x-1) using Mathematica. The user initially attempts to use the InverseFunction command but receives an output that does not provide a clear solution. It is clarified that InverseFunction primarily works with built-in functions, such as trigonometric functions. The recommended approach is to use the Solve function with the equation y == (2 x + 1)/(x - 1) to find the inverse. This advice successfully resolves the user's issue.
roam
I'm trying to find the inverse of a function, for instance: f(x)=(2x+1)/(x-1) using Mathematica but it doesn't produce any answers.
This is my input:
> f(x)=(2x+1)/(x-1)
> InverseFunction[f]
The output is always something like:
"InverseFunction[(1+2x)/(-1+x)]"
So, does anyone know what the problem is?
Thanks,
InverseFunction only evaluates for built-in functions like trig functions. I think you want:
Solve[y == (2 x + 1)/(x - 1), x]
Oh I see... Thank you! :smile:
Thank you very much roam, you've helped me to solve a big problem.
