Mathematica truncates my curves
1 reply · 5K views · last reply
Barnak
I'm ploting a simple function (the effective gravitationnal potentiel with angular momentum part) with Mathematica, and I'm getting some truncated curves close to the vertical asymptote located at r = 0 (see the picture below). Of course, this is normal since the function V(r) diverges at r = 0, but why Mathematica is truncating the first two curves that much ? How can I tell it to draw the curves more closely to the left ?
I'm ploting the curves in the range r = 0 to r = 10, so I should get some better extended curves...
What Mathematica command should I add to get better curves ?
  • Plot titled 'Le potentiel gravitationnel effectif': curves of V against r/a from about 0 to 10, labelled 1 to 5, with V falling toward 1 for large r and rising steeply near small r.
Aaah ! I've found it ! Just use ParametricPlot instead of a simple Plot.
See the picture below :
  • Line graph titled "Le potentiel gravitationnel effectif" plotting V against r/a from 0 to 10, with six curves labelled 1 to 6; curve 1 dips below zero near r/a = 0.5 then rises, while curves 2 to 6 decrease from high values toward a common asymptote near V = 1.
