Induction Proof for A^n = 1 2^nProve your formula by mathematical induction.
The discussion revolves around proving the formula A^n = [1, 2n; 0, 1] using mathematical induction. Participants clarify the induction process, emphasizing the need to establish a base case, assume the proposition for k, and prove it for k + 1. The matrix A is defined as [1, 2; 0, 1], and as n increases, the value in the matrix's second column increases by 2 for each successive power. The conversation highlights the importance of recognizing patterns in matrix powers and constructing a clear inductive proof. Ultimately, participants work towards formulating a coherent proof based on their observations.
Robb
<Moderator's note: Moved from a technical forum and thus no template.>
A^n = 1 2^n
0 1
I began by taking A to successive powers but not sure of what my formula should be.
A^0 = 1 0 , A^1 = 1 2 , A^2 = 1 4 , A^3 = 1 6 , A^4 = 1 8 , A^5 = 1 8
0 1 0 1 0 1 0 1 0 1 0 1
Obviously the a(12) element increases by two with each successive power but I'm not sure how to proceed from here. The induction proof isn't very intuitive to me either. Please help.
There are two parts to an induction proof.
Prove it’s true for one case.
Assume it’s true for case k and then prove it’s true for case k+1.
I don’t understand what you wrote. Does A have a value?
I don’t understand the 0 1 or 0 1 0 1... values.
Sorry, looks like the matrices didn't go through the way I typed them out. With each successive power the a12component increases by two.
1 2 = A
0 1
1 2 = A
0 1
1 2 = A2
0 1
Robb said:
1 2 = A2
0 1
I apologize, I'm a bit out of sorts
1 2 = A^n
0 1
1 2 = A
0 1
Okay, I think I can see what you have to prove. What do you know about induction?
@Robb Try using the following:
##A = \begin{bmatrix}
1 & 2 \\
0 & 1
\end{bmatrix}##
If you reply to my post, you'll get the latex.
We went over it very briefly the other day which was my first intro to it. Basically prove an initial case then prove the k + 1 case.
Not quite. Prove the ##k+1## case, assuming the ##k## case.
Can you have a try at that?
We were told to develop an equation based on A^n, where n = 1, 2, 3,..., n. Then prove the equation. I guess this is my first stumbling block. I'm not sure of the equation. The example used was n(n+1)/2.
Induction is logic. It goes like this. Suppose you check that something is true for ##k = 1## and then you prove that if it is true for ##k##, it is true for ##k +1##. Then, you can reason as follows
It's true for ##k = 1##, hence it's true for ##k = 1 + 1 = 2##; and
since it's true for ##k = 2## it's true for ##k = 2 + 1 = 3##; and,
since it's true for ##k = 3##, it's true for ##k = 3 + 1 = 4##; and,
hence it must be true for all ##k##.
That's the principle of induction.
Does that make sense?
Likes jedishrfu
Yes. I guess where I'm not connecting the points is how to apply it to this particular problem. Is it as simple as above,
so, A^k
K =1
so, k+1 = 1+1 = 2
k = 2+1 = 3, and so on?
so, A^k
K =1
so, k+1 = 1+1 = 2
Can you check whether it's true for ##k = 1##?
When k=1 I get the original matrix A so, I assume that it is true.
Let's go with that. What happens if you assume it is true for ##k##? Can you write down what that assumption means? And, can you show that - with that assumption - the statement is true for ##k + 1##?
When k=1, A^k = A
When k=k+1=1+1, A^k = A^2
when k=2+1, A^k = A^3
and so on
Robb said:
When k=1, A^k = A
and so on
Okay, so you haven't understood it at all! Probably best to try the above material. See if you can get a grip in induction somehow.
Crap! Ok, I'll check it out. I appreciate the help!
You can see from the cases you tried that only one number changes. So you know the general form is
##A^n= \begin{bmatrix}
1 & f_n\\
0 & 1
\end{bmatrix}##
Can you get a recurrence relation for fn?
Prove true for k=1. Then rewrite Ak+1 in terms of Ak and use the assumption that it is true for k to deal with Ak. That should let you prove it for all 1 (prove), 2, ..., k (assume), k+1 (prove), ...
Yes, that's induction, but it seems the immediate difficulty is in constructing the formula to be proved.
This is the step that I don't see him making any attempt at: rewrite Ak+1 in terms of Ak.
So I thought it was worth asking for it directly. Maybe I missed it, but I have trouble understanding his posts.
1 & f_n\\
0 & 1
\end{bmatrix}##
fn = 2n
Robb said:
fn = 2n
Later edit: No.
Let's get back to the original problem, with ##A = \begin{bmatrix}1 & 2 \\ 0 & 1 \end{bmatrix}##
What is A2?
What is A3?
Continue until you can see a pattern develop.
I'm assuming you know how to multiply two 2 x 2 matrices.
Robb said:
fn = 2n
No. Please show your working.
Edit: Sorry, you are right.
Mark44 said:
No.
What is A2?
What is A3?
##A2 = \begin{bmatrix} 1 & 4 \\ 0 & 1\end{bmatrix}##
##A3 = \begin{bmatrix} 1 & 6 \\ 0 & 1\end{bmatrix}##
so,
n = 1, fn = 2
n = 2, fn = 4
n = 3, fn = 6
n =4, fn = 8
and so on. As n increases in value by increments of 1, fn increases by 2n. All other values of the matrices remain unchanged.
You mean it increases by 2. So yes, it does equal 2n, as you posted. My mistake.
So now you have your inductive hypothesis. Can you write the inductive proof?
My mistake, as well. My apologies for any confusion.
  • · Replies 19 ·
  • · Replies 17 ·
  • · Replies 24 ·
